John Marshall avatar image
John Marshall asked
Multiple Echo's
Hi Guys, I have 2 Echo's and have just pre-ordered the new Dot solely because of its 3.5mm line out. Using the Sonos Connect Line In I am hopeful finally I can stream Echo music to all the Sonos points in my house. Yes a tall order I know, on can but try these things. It occurred to me that with essentially 3 Echo's in the house only one will have the physical means to play music to an external device. so "Alexa, play jazz" will play on all 3 and the Dot being connected to Sonos via line out will play on Sonos? I guess this thread is posted in a hope that someone at Amazon has already thought about this and will reply with a reassuring have no fear all will be good! ?
alexa skills kit
cdburns123 avatar image
cdburns123 answered
From what I've read today, your three can have different names: Alexa, Amazon, and Echo. I've also read on the Sonos forum and they (Sonos) state it should work with the line-out of the Echo Dot to the line-in on the Sonos. I've ordered two of the Dots myself for other parts of the home.
Galactoise avatar image
Galactoise answered
I'd imagine cdburn's answer is the correct way you'd want to design your household setup. With the Dot being cheaper and smaller, we'll probably start seeing a lot more multi-Echo homes - it seems like Amazon really needs to get ahead of this by either opening up additional wake words, or allowing the wake word to be arbitrarily defined (side note: FFS, CAN I PLEASE JUST USE THE WORD "COMPUTER" ALREADY? I WANT MY STAR TREK). If your current setup has three devices all within earshot of a particular location in your house, and all three devices use the same wake word, then you're going to run into problems unrelated to playing music. Like if you were to say "Alexa, what time is it?", you'd get three different devices all telling you what time it is. Even worse, if you said "Alexa, order a 5 pound bag of Gummi Bears", you'd get three different devices all placing an order for Gummi Bears, and then you'd have 15lb of Gummi Bears on your hands. Nobody needs 15lb of Gummi Bears. Nobody. Even if you do name them differently, though, you could still end up in a funny situation with Sonos whole home streaming. Lets say you have a Dot, named "Amazon" in one room, and it's hooked up to your Sonos household system. You also have an Echo in another room, named "Alexa". You say "Amazon, play my Kenny G station on Pandora", because you're trying to set the mood for a romantic evening. The melodic stylings of "Careless Whispers" flow throughout your house, and all is good, but then it's commercial time (because you were too cheap to upgrade to a paid Pandora account), and all of a sudden the "Controlled by Your Voice" commercial for the Echo comes on, and that too streams throughout your house. The commercial ends with the narrator saying "Alexa, play my road trip playlist". Now all of a sudden, in the room with the second device, your Echo is blasting Chamillionaire's "Ridin' Dirty" over the top of Pandora's selection of Smooth Jazz in the style of Kenny G. Romantic vibe destroyed (but artistic masterpiece created?)...
