esnovikova avatar image
esnovikova asked
Comodo trial certificate (Free SSL Certificate) issue
Hello, I have an Alexa skill named CookBook (app id amzn1.echo-sdk-ams.app.2c33e7d5-71b6-4d5c-9fc4-c936b1e75e1c) I've checked "My development endpoint has a certificate from a trusted certificate authority (required for certification)" option in "SSL certificate" section of my skill configuration. My service has Comodo trial certificate(domain validated) and I see "There was an exception during the SSL hand shake. Please check the certificate you have provided." error when I try to test it. There is no certificate warnings when I call my service from browser. I've also checked my service here https://www.ssllabs.com/ssltest/ (using my service domain name alexacookbook.xyz) and it shows "B" grade which is OK. In service logs I just see "javax.net.ssl.SSLException: Received fatal alert: certificate_unknown". Could you please advise how to understand the exact cause of this issue? Are Comodo trial certificates appropriate for Alexa skill?
esnovikova answered
Lawrence Krubner avatar image
Lawrence Krubner answered
If I try this with curl: curl --verbose https://alexacookbook.xyz/ * Trying 162.255.119.251... * connect to 162.255.119.251 port 443 failed: Connection refused * Trying 159.203.31.166... * Connected to alexacookbook.xyz (159.203.31.166) port 443 (#0) * TLS 1.2 connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * Server certificate: alexacookbook.xyz * Server certificate: COMODO RSA Domain Validation Secure Server CA * Server certificate: COMODO RSA Certification Authority * Server certificate: AddTrust External CA Root > GET / HTTP/1.1 > Host: alexacookbook.xyz > User-Agent: curl/7.43.0 > Accept: */* > < HTTP/1.1 404 Not Found < Server: akka-http/2.3.12 < Date: Mon, 14 Dec 2015 21:51:28 GMT < Content-Type: application/json < Content-Length: 17 < * Connection #0 to host alexacookbook.xyz left intact Unknown resource!% This could be a repeat of this previous issue: https://forums.developer.amazon.com/forums/thread.jspa?threadID=5474 Or is it possible that the endpoint that you gave to Amazon is somewhat different? Be careful about what URL you use.
