James Chivers avatar image
James Chivers asked
Response->Card->Subtitle parameter removed
I just realised that the 'subtitle' Response Card object parameter has been switched off, and instead Alexa is manually setting your application Card subtitle values to the full name of the invoked application (overriding whatever you might be setting in your backend). If you have been reliant upon the subtitle to provide response details or useful information to your users, you'll need to update your app accordingly. Relevant Card documentation: https://developer.amazon.com/public/solutions/devices/echo/alexa-app-kit/docs/alexa-appkit-app-interface-reference#card-object Good to know that backwards compatibility is being maintained so you will not see any errors when sending a Response Body back to Alexa inclusive of the subtitle Card parameter, but it probably should have been announced somewhere.
