Will Strain avatar image
Will Strain asked
Context = undefined
Ok so I am trying to test my code on Lambda, and when I try to run it it says undefined is not a function. It looks like context isn't passing like it should. The error is in my index file and I pretty much just copied my code from the samples so it should work fine. Is anyone else having these issues? Code: exports.handler = function (event, context) { var homelogistics = new homelogistics(); homelogistics.execute(event, context); };
Matt Kruse avatar image
Matt Kruse answered
I doubt the problem is in the code snippet posted. If you post your execute() code, we might be able to find the root cause.
The Stig avatar image
The Stig answered
is the name of the function "event" or "event, context"?
