Chase-Work avatar image
Chase-Work asked
accessToken not getting generated after successful Account linking
Hi, I am creating a skill which has account linking option enabled. On enabling the skill, user is redirected to login page where after successful login and generating Oauth 2.0 accessToken and passing this token to the redirect uri as mentioned in the document, a message can be seen "Your xyz skill was successfully linked". But the problem is when I test this on service simulator I am unable to see the [b]accessToken[/b] field in the json object of user returned by Alexa. What are the possible reason for this?
Chase-Work answered
After reading some other threads, I came to know that the token is getting generated when I tested it on Alexa rather than on simulator. I was able to see the token. Anyway thanks guys
Steve A avatar image
Steve A answered
Yes! For me, the simulator never shows or passes the access token. They said they've fixed this a while back -- and it was working briefly for me -- but not any more. I'm not sure if this is just a problem for people developing a skill as a web service (instead of Lambda), but I suspect the problem is connected to web service skills. It's sort of a pain, since I cannot use the simulator for development.
