dowino avatar image
dowino asked
Minimum Android version
The question is short and simple : How to limit the minimum Android version for users to buy the application? Other stores do that but I wasn't able to find it on Amazon Developer.
amazon appstore
Levon@Amazon avatar image
Levon@Amazon answered
Hi dowino, Normally developers set the android:minSdkVersion in the manifest file to an integer specifying an API level required for the application to run. The Android OS will not install the app if the host system's API level is lower than the value in the app's manifest. To set it for your project, open your Android manifest file, and set the minimum API level in the uses-sdk element: More info on versioning is available in Android reference: http://developer.android.com/guide/topics/manifest/uses-sdk-element.html#apilevel Please let us know if you have any further questions. Kind regards, Levon
