listening-for-echos avatar image
listening-for-echos asked
service down? Experiencing "Error: Failed building the interaction model."
I am seeing this error after waiting a while for the process to return. I'm pretty sure the model is OK, as I made only a very minor change to one that worked before and also I put in a new one from the favoriteColors example which also fails. Noted that this has come up in the past but not seeing anything about it today, so I am wondering if it is the models, my account, or the system. If it is the system, then I'd suggest to Amazon to have a notice on this board of system status.
Steve A avatar image
Steve A answered
Yes, I'm seeing this, too. Steve
justin avatar image
justin answered
Hi all, We are actively working on this issue and will reply to this thread as soon as it is resolved. We apologize for any inconvenience this may have caused you! Thanks, Justin
justin avatar image
justin answered
Hi all, This issue is now fixed and you should no longer have troubles building your interaction models. Thank you so much for posting this, and we apologize again for any inconvenience this may have caused you! Thanks, Justin
comp sci major avatar image
comp sci major answered
Verified. Up and running fine now. Thanks for the fast work.
