thomascoding avatar image
thomascoding asked
"There was a problem communicating with the requested skill"
One of my skills under development suddenly stopped working this morning, and is now returning only "There was a problem communicating with the requested skill". The response I'm passing to context.succeed() in my NodeJS Lambda function is pasted below. Is there something incorrect in here? My Lambda logs looks exactly as they should. Are there other issues that can cause the above error? { "version": "1.0", "sessionAttributes": null, "response": { "outputSpeech": { "type": "PlainText", "text": "debug is now responding" }, "card": { "title": "debug", "content": "debug test" }, "reprompt": { "outputSpeech": { "type": "PlainText", "text": "" } }, "shouldEndSession": true } }
April L. Hamilton avatar image
April L. Hamilton answered
The error message you describe cropped up often as a generic response to [i]any[/i] mistake in the Javascript code of the skills I was working on at the time. Try pasting your code into the Lambda code window - potential errors will be highlighted - or in an editor that has syntax error scanning.
