ultrajones avatar image
ultrajones asked
Lambda Function, Node.JS and HTTPS
Hello, I created a test Echo application using the Alexa Getting Started Guide and implemented it using an AWS Lambda function. The sample application is working great. However, I am struggling with trying to get Node.js to do a remote HTTPS connection to a remote web services. Does anyone have a simple example on how to use Node.js to connect to a remote web server that requires basic authentication? Regards, Ultrajones
alexa skills kitdebugging
Matt Kruse avatar image
Matt Kruse answered
Can you use the request module? https://github.com/request/request
Anant avatar image
Anant answered
It's also possible to do using Node's native 'https' library. I found this snippet that communicates to the Twilio API over HTTPS in a Lambda-compatible node.js function. It includes Basic authentication as well: https://gist.github.com/stevebowman/7cff9dd80b227c899728 HTH!
John Schettino avatar image
John Schettino answered
I use request, it works, but you need to upload it with your node app See https://aws.amazon.com/blogs/compute/nodejs-packages-in-lambda/
ultrajones answered
I cannot get something as simple as this to work. Any ideas? var http = require('http'); var options = { hostname: ' www.amazon.com', method: 'GET', path: '/' }; var req = http.get(options, function(res){ console.log("statusCode: ", res.statusCode); // I am not seeing this in the logs console.log("headers: ", res.headers); res.on('data', function(data) { console.log("response data:"+data); }); res.on('end', function() { console.log("Done"); }); res.on('error', function(e) { console.log("Got error: " + e.message); }); }); Regards, Ultrajones Message was edited by: ultrajones
did you install the http module locally, and upload the zip of the directory?
Greg Crawford avatar image
Greg Crawford answered
As I noted in a different thread, you need to make sure that you are properly waiting for the external request to be made and also to wait for a response. https://forums.developer.amazon.com/forums/thread.jspa?threadID=5554&tstart=0
The http and https modules seem to be available locally.
> As I noted in a different thread, you need to make > sure that you are properly waiting for the external > request to be made and also to wait for a response. > > https://forums.developer.amazon.com/forums/thread.jspa > ?threadID=5554&tstart=0 Yeah, that's probably it - I missed that too - node is funny For those async calls, you need to put your completion callback to Alexa in the callback fn for the async call: So for example, using whatever you use to make the https call, this kinda thing is needed [pre] function getMode(intent, session, callback) { var cardTitle = "Get Smart Home Mode"; var sessionAttributes = {}; var shouldEndSession = false; var speechOutput = ""; // make the Async call, the function() callback has the completion callback to Alexa GetViaSmartThingsREST("mode", function (err, res, body) { // console.log("SUCCESS: ", err); var mode = "unknown" try { var jmodes = JSON.parse(body); mode = jmodes.mode; } catch (e) { console.log(e); console.log(body); } speechOutput = "The house is in " + mode + " mode right now."; callback(sessionAttributes, buildSpeechletResponse(cardTitle, speechOutput, repromptText, shouldEndSession)); }); } [/pre] Otherwise Node kills the async call, since nothing is waiting on it. Node. Full of fun! Message was edited by: John Schettino Message was edited by: John Schettino
Node.js is fun stuff!
