Khoa Pham avatar image
Khoa Pham asked
Echo can't receive a response from EBS
I was following the HelloWorld sample as listed here: https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/using-the-alexa-skills-kit-samples-java#Setting%20up%20Hello%20World%20on%20Elastic%20Beanstalk. I have deployed the project to EBS and verified connection through browser. However, Echo kept complaining about issues with requested skills. Looking at the helloworld.log, here's the trace: 2015-07-18 23:34:11,777: WARN ApplicationIdVerifier - Application ID verification has been disabled, allowing request for application ID amzn1.echo-sdk-ams.app.ca2a6584-3a11-4f0d-907b-23ec5525b023 2015-07-18 23:34:11,777: WARN SpeechletServlet - Timestamp verification has been disabled, allowing request amzn1.echo-api.request.21217339-3579-4475-82f2-dfdaeb852d2d with timestamp Sat Jul 18 23:34:11 UTC 2015 2015-07-18 23:34:11,777: ERROR SpeechletServlet - Exception occurred in speechlet java.lang.NullPointerException at com.amazon.speech.speechlet.servlet.SpeechletServlet.doPost(SpeechletServlet.java:206) at javax.servlet.http.HttpServlet.service(HttpServlet.java:644) at javax.servlet.http.HttpServlet.service(HttpServlet.java:725) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:673) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:516) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1086) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:659) at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1558) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1515) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745) How do I fix that NullPointerException? HelloWorldSpeechlet and Servlet should be the same as described in the sample guide. Thanks
alexa skills kitdebugging
Nick Gardner avatar image
Nick Gardner answered
Hi, Did you add the speechletservlet to your application: https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/using-the-alexa-skills-kit-samples-java#adding-a-speechletservlet-and-setting-up-servlet-mapping That's the only thing I can think of here, other than remaking the project to make sure there aren't any typos or other syntax issues. -Nick
