cdburns123 avatar image
cdburns123 asked
Proxy, Code, Where does it all go?
I am attempting a proxy setup. Here is the error I am getting when I try to test it on Lambda Functions Test page: { "errorMessage": "Process exited before completing request" } -and- ReferenceError: https is not defined at exports.handler Having issues as to where to put what. I have this in my Code Tab on AWS Console...not sure if I am even suppose to have this here since I am wanting to forward the request to my httplistener on my own web server: ******************************** CODE TAB ************************** var http = require("http"); var options = { host: "http:// My outside Website", // global IP goes here. I've tried a DDNS host and the address of my server port: 8080, method: 'POST', headers: { 'Content-Type': 'text' } }; var data = 'OFF'; exports.handler = function(event, context) { var req = https.request(options, function(res) { var body = ''; console.log('Status:', res.statusCode); console.log('Headers:', JSON.stringify(res.headers)); res.setEncoding('utf8'); res.on('data', function(chunk) { body += chunk; }); res.on('end', function() { console.log('Successfully processed HTTPS response'); // If we know it's JSON, parse it if (res.headers['content-type'] === 'application/json') { body = JSON.parse(body); } context.succeed(body); }); }); console.log("Before the error"); req.on('error', context.fail); req.write(data); console.log("Before req.end()"); req.end(); }; *************************************** END CODE TAB ************************************** INDEX.js FILE********************************** var https = require("https"); var MyApplicationId = " amzn1.echo-sdk-ams.app.My app ID here"; // change to your ApplicationId var MyEndpoint = "https:// My outside website"; // change to your Endpont exports.handler = function (event, context) { try { console.log("event=" + JSON.stringify(event)); /** * Uncomment this if statement and populate with your skill's application ID to * prevent someone else from configuring a skill that sends requests to this function. */ if (event.session.application.applicationId === MyApplicationId) ; // from Echo else if (event.session.application.applicationId === "amzn1.echo-sdk-ams.app. MY application ID here") ; // from Amazon Lambda Test ... or intruder else context.fail("Invalid Application ID"); console.log("new:" + event.session.new); if (event.session.new) { onSessionStarted({ requestId: event.request.requestId }, event.session, function callback(sessionAttributes, speechletResponse) { console.log("new: speechletResponse:" + speechletResponse); }); } -------------------etc....... Then I have an HTML file with: // The path is correct. My C# code states it is listening Been at this for a while now, so if anyone can point me in the right direction...I would GREATLY appreciate it. Thanks,
alexa skills kitdebugging
cdburns123 answered
Never Mind all....got it.
