Skurry avatar image
Skurry asked
GameCircle plus Insights
Hi, I'm trying to implement both GameCircle and AmazonInsights into my app. When I look at LogCat, I see that there are actually two Insights sessions started, I guess one for GameCircle and one that I'm explicitly starting. Since GameCircle is already doing it, could I somehow use that to log custom events? Or am I doing the right thing? Thanks!
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Skurry, Thank you for reaching out. You are correct that GameCircle SDK is internally dependent with insight SDK and integrating GameCircle in the app would create a separate insight session in the app. But you should not worry about it. The insight SDK what you are supposed to integrate in your app, that identifies your app with the Identifier you crate in your account and that should be used all your default and custom event tracking.
