burkeface avatar image
burkeface asked
onMessage is never called
Trying for two days solid now to get the device to register a message from server. Have successfully registered device on server and got API in and successfully working Have successfully authorised and then posted a successful message to the amazon messaging server Have tried re-syncing, all manner of manifest changes and am using ADMManifest.checkManifestAuthoredProperly(this) which reports no errors Am logging ADMManifest.DEFAULT_MESSAGE_HANDLER_CLASS_NAME which always responds .ADMMessageHandler I can register and unregister happily from the server and it triggers all the correct behaviours which fail if i screw up the Manifest however nothing I do seems to trigger the onMessage(Intent intent)??? Help!!!
amazon device messaging
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Burkeface, What is the HTTP response code you are getting when you are sending the message from your server? Could you please check and let us know?
