kolyosick avatar image
kolyosick asked
INVALID SENDER_ID
Hello, I receive the "INVALID SENDER_ID" error. I use this instruction https://developer.amazon.com/sdk/adm/credentials.html In Amazon Mobile App Distribution Portal I use correct MD5 and path to generate api_key. api_key doesn't contain whitespaces and etc. What do I do wrong?
amazon device messaging
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Kolyosick, Thank you for writing to us. I did not find any app/security profile associated with the account you are using to post in this thread. Have you added security profile and API key in your account in the distribution portal? Or you are using other account to create app/security profile. Also what is the certificate you are using to sign your apk? Is that debug one? If yes, what the alias name and storepass you are using while extracting MD5 fingerprint? I am sending you a mail to your registered mail id. Can you send me back the app name and the email address of the admin of the account owner. Thanks.
Hi Kolyosick, Thanks for the mail. You have said their that "Actually, all works fine if I export application in Eclipse with signing it." So whats the scenario you are getting the issue? Did you mean that while export the app in eclipse, does ADM work? Or do you still receive Invalid sender. Can you please make sure that you have extracted the MD5 finger print correctly from correct keystore file and using the correct API key (generated by same MD5 fingerprint) before any further investigation?
