Kenneth Poon avatar image
Kenneth Poon asked
WhisperSync Client is null
Hi guys, is it normal that AmazonGamesClient.getWhispersyncClient() is null?
According to the amazon api, "Whispersync data is always accessible, even when the player is not registered with Amazon or is offline."
But this doesn't seem to be true.
I was using appXplorer to test my app, and it crashes right at the following line because getWhispersyncClient is null:
AmazonGamesClient.getWhispersyncClient().getGameData();
Thanks for your help in advance!
login with amazongamecirclewhispersync
Amazon Customer avatar image
Amazon Customer answered
I am seeing a similar problem in Unity. No matter what attempts I make to init/connect/synchronize the clients, this code:
this.data = AGSWhispersyncClient.GetGameData ();
Always returns null in the windows unity editor player. Sideloading the app on the FireTV seems to not want to connect to the services at all, due to an issue between Sideloaded apps and GameCircle.
DougM@Amazon avatar image
DougM@Amazon answered
The GameCircle plugin for Unity is not designed to work within the Editor. You will need to load it on a device, and from there you will want to make sure that the AmazonGameCircleManager object is in your scene, and that your manifest entries are correct etc. Please follow the Setting Up Unity and Integrating GameCircle Features in your Games document at : https://developer.amazon.com/public/apis/engage/gamecircle/docs/unity-setup
and if you are still experiencing issues, please give us a sample project that you have setup and ADB logcat output such that we can help investigate the problem.
