leybmax avatar image
leybmax asked
Reset achievements
Hello. I tried to reset achievements in sand box. I called resetAchievements method. Method called successfully, but nothing happens – in achievements list achievements are still earned. Then I called resetAchievement. It executed successfully but with no effect. May be I doing something wrong? Please, help to write code which will reset achievements. Here is my code: public int amazon_game_circle_reset_achievement(String achievementID) { AchievementsClient acClient = m_agsGameClient.getAchievementsClient(); acClient.resetAchievement(achievementID).setCallback( new AGResponseCallback () { @Override public void onComplete(RequestResponse result) { if (result.isError()) { Log.d("AmazonGameCircle", "resetAchievement error"); } else { Log.d("AmazonGameCircle", "without error"); } } }); return 0; } Thank you
Sachin@Amazon avatar image
Sachin@Amazon answered
Hi leybmax, Resetting an Achievement feature is not yet available on Distribution Portal. If you require achievements to be reset, please send a request through the Contact form: https://developer.amazon.com/help/contactus.html, and one of the support staff can help you out.
davidbuttress avatar image
davidbuttress answered
Hi, I'm having the same problem, the resetAchievements api call doesn't seem to work. I do get a successful RequestResponse back, but the achievements are all still the same. To confirm this is for creating a "reset achievements button" in game for users, it doesn't have anything to do with resetting within the distribution portal.
Hi davidbuttress, Currently resetAchievement feature is disabled from Gamecircle. If you want to reset the achievements for any device, you will require to raise a ContactUs with us along with the game name and player alias and we can do a reset.
