Elmo avatar image
Elmo asked
Can't publish new Achievements
I have two new Achievements, but I can't publish them. A popup says there was an Error and I should try later. Any tipp on how to fix this? Thanks!
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Elmo, Thank you for writing to us. Since this is specific to your app, can you please raise a ContatcUs ( https://developer.amazon.com/help/contactus.html) with the achievement ids?
Elmo avatar image
Elmo answered
I already did wrote to the team, but no answer yet.
Hi Elmo, Sorry for the inconvenience. Though I am unable to find any unanswered case from your email id in our ContactUs queue. Any way, I have found those 2 achievements what are giving you trouble to be published. I have just forwarded this case to the internal appropriate team. I will notify you shortly after getting response from them. Thanks.
Elmo avatar image
Elmo answered
Thanks a lot Sujoy!
Hi Elmo, Your pending 2 achievements are published from backend. So you can go ahead with it. Though you may face same issue if you create new achievement and try to publish it. Because there is an issue that's being actively worked on. Please post back in case of such issues so that I can get those achievements published from backend again. I will update this thread when the issue is fixed permanently in the portal. Thanks.
Elmo avatar image
Elmo answered
Thanks, all good now!
