BusyMom avatar image
BusyMom asked
Post to leaderboards in Unity
Ok When I test my app and get a high score I see the game circle popup saying a new high score earned and shows the icon of the correct leaderboard, but when I go to the game circle leaderboards I don't see any scores? Any Ideas? Also when I call game circle I see all the leaderboards in there as well as all achievements. only the leaderboards don't contain any scores. Thanks Message was edited by: BusyMom
BusyMom answered
In my game I use var arr2 = new Array(); if( Application.loadedLevel == 36){ Cartoon = true; arr2.push("UMG-CARTOON"); arr2.push(totalGameScore); SendMessage ("SubmitScore", arr2.join("|")); } In the Game Circle Script I use this private void SubmitScore(string data) { string[] arr2; arr2 = data.Split("|" [0]); string leaderBoardId = arr2[0]; int val = (int) System.Convert.ToSingle(arr2[1]); Debug.Log("SubmitScore: " + leaderBoardId + " " + val); AGSLeaderboardsClient.SubmitScore(leaderBoardId,val); } I just don't understand why I see the High score earned popup on my kindle but if I click on leaderboards I see no score also my debug log is getting called and all variables seem correct Thanks
BusyMom answered
BusyMom answered
Ok I think I figured out my problem I found this https://developer.amazon.com/public/community/post/Tx3DCAJ41RZGAIU/Tips-and-Best-Practices-for-the-Amazon-GameCircle-API it says "No negative leaderboard values – Leaderboards do not currently support negative scores, so you will experience errors if you submit them." But I have a golf game and the lower the score the better and someone might possibly get a negative score. So how do I handle this. Please reply I have been trying to figure this out. Thanks
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi BusyMom, Unfortunately, Leaderboards do not currently support negative scores. So you can not submit negative score in your app.
Brandon Hoskins avatar image
Brandon Hoskins answered
Is there any plans on adding negative scores in the future? I have 2 apps that could really use this, and negative scores are supported by both Apple and Google. Thanks
We generally do not answer questions about future products or services, which this falls under. However, I'm going to forward this feedback/suggestion to the concern team. Please stay tuned on Mobile App Distribution Portal or Blogs ( https://developer.amazon.com/blog/index.html) for any updates related to this. Thanks.
