iron59 avatar image
iron59 asked
Unity iOS Get all scores
Good day, this problem had been partially resolved in another thread but my problem is iOS specific. So I needed to retrieve all the scores of a specific leaderboard. I came across the other thread in this forum https://forums.developer.amazon.com/forums/thread.jspa?threadID=1633&tstart=0 and I was able to make this work for Android. However, this is not the case for iOS. It seems the extern function [b]_AmazonGameCircleRequestScores[/b] is nowhere to be found in the dll for GameCircle. The exact error message in Xcode is: Undefined symbols for architecture armv7: "__AmazonGameCircleRequestScores", referenced from: RegisterMonoModules() in RegisterMonoModules.o ld: symbol(s) not found for architecture armv7 clang: error: linker command failed with exit code 1 (use -v to see invocation) I would like to know what function should I use instead or if there are any other approach that I should use to resolve this. I'm assuming there should be a corresponding iOS function for the [b]getScore[/b] in Android. Looking forward to your response.
iron59 avatar image
iron59 answered
*bump*. Any progress here? At least I would like to know if this thread has been read...
DougM@Amazon avatar image
DougM@Amazon answered
Hello iron59, Sorry for the delayed response. We have read the report and are investigating the issue. We will update you when we have an answer.
iron59 avatar image
iron59 answered
Any progress in this issue?
Hello iron59, We have confirmed that the function is not a part of our current Unity iOS plugin build. We have put a request in with the appropriate internal team to implement it in a future release. However, we cannot give an estimate as to when that will be available in the plugin.
