mobivention GmbH avatar image
mobivention GmbH asked
GameCircle and Log In with Amazon API key issue
There is supposed to be one key for both services but currently we cannot get one key. Here are the facts: - GameCircle and Login With Amazon have the same package name: - GameCircle und Login With Amazon have the same signature: - Login With Amazon needs a "Amazon Appstore App ID". With developer.amazon.com he only found the "Application Key" which he has used: - GameCircle and Login With Amazon are giving seperate API Keys. The API key from GameCircle does not work for Login With Amazon and vice versa. Our question is: - How ist he process of connecting both API keys? And where does it need to be done? There does not seem to be a form or field for this. We have submitted the apk and log files to an Amazon employee already but we are not receiving any feedback. This leads to the issue that the Amazon version of our game can only use GameCircle but not the Amazon Log In. All other versions for Google Play and Samsung and other stores have the Amazon included. Thank you for your help. Best regards Bibiana Message was edited by: Sujoy@Amazon
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Mobivention, There is an outstanding issue that GameCircle and LWA can not work together since the API key used by both the SDK taken from same file and the KEY associated with one does not work for other one. We will fix this problem soon. But there is a work around that if you send us the information like App name, used Security Profile (through ContactUs), we can fix the issue from back end so that one API key would work for both the SDK. Please send the required information in order to fix the issue in your app. Thanks.
