bisqray avatar image
bisqray asked
gamecircle disabled on 1st gen kindle fire
For some reason on 1st gen kindles only we are getting these messages in logcat D/KindleFireIPCProxy(5282): Checking isWhispersyncEnabled: false D/GC_Whispersync(5282): Whispersync is DISABLED What could cause whisper sync to be disabled? On other devices registered to the same amazon account it is not disabled. And I checked on the Manage Your Kindle site -> Device Synchronization (Whispersync Settings) And it is turned on (it looks like that setting is not device specific)
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Bisgray, GameCircle system application version 2.5.2500310 is required on Kindle Fire devices in order to use the latest GameCircle SDK 2.2. Please make sure you have right client installed in the device. On Kindle Fire (1st Generation), Kindle Fire (Second Generation), Kindle Fire HD 7", and Kindle Fire HD 8.9", navigate to Settings->Applications->Installed Applications->Amazon GameCircle. If your Kindle Fire shows an earlier version of Amazon GameCircle, follow these steps to upgrade: - Ensure the device is charged to at least 40%. - Swipe down from the top of the screen to display the notification bar. - Touch Sync. - Leave your device turned on but idle.
bisqray answered
We have 4 first gen kindle devices and over the last few days have been trying to get gamecircle to update by tapping sync. The highest version we have managed to get is 1.1_1101210 But usually we only get 1.1_1101110 Can you confirm that on a first gen kindle fire that the gamecircle version should update to 2.5.2500310 ?
Hi Bisgray, Can your app detect the registered user while initializing the GameCircle? With out the user you can not use any of the feature of the GameCircle. I am following up with our team why the user is not recognized (showing as guest) for Kindle 1st Gen devices with the latest SDK. I will get back to you shortly. Thanks.
kuangzheng avatar image
kuangzheng answered
Hi Sujoy, I have a same issue. My 1st gen kindle fire's Amazon GameCircle has a version 1.1_1100910. I tried to tap the Sync button but nothing happens. Now I'm adding GameCircle to my game in Unity and the version of GameCircle API I used is 2.1 . When I run the example apk and tap Init button,it always show "Failed to initialize: CANNOT_INITIALIZE". How can I fix this? Any help at all would be appreciated. Thank you!
umairctech avatar image
umairctech answered
Hi! I'm facing the same issue as mentioned by Sujoy@Amazon. My 1st gen kindle fire is unable to detect the registered user within game and always shows the guest user. Therefore i'm not able to use game circle features (leaderboard, achievements etc.). My kindle has GameCircle application version 1.1_1100910 and i'm unable to update it to version 2.5.2500310 via Sync or by any other mean. I am using GameCircle Unity SDK (version 2.2) Anyone found a solution? Please share! Thanks,
Can you guys please provide the device Id of all yours 1st Gen devices? We are investigating the reason why OTA failed in few devices.
umairctech answered
Hi, Following is my device information: Device: Kindle Fire (1st Gen.) Serial Number: D01E C0A0 1494 0J8R Build Number: 6.3.2_user_4110520 GameCircle version: 1.1_1100910
plasticyoda avatar image
plasticyoda answered
I'm also seeing the same issue with our 1st gen KF. Cant get higher than 1.1_1101210 on this device. Device Serial Number: D01EA0A014463B8L SystemOS: 6.3.2_user_4110520
Hi Plasticyoda, 1.1_1101210 is the latest release. It should support the Game Circle 2.x. Can you please run the code, capture the log and send us through the ContactUs ( https://developer.amazon.com/help/contactus.html). Please add reference of this thread url ( https://forums.developer.amazon.com/forums/message.jspa?messageID=8723#8723) in the case you are going to raise. Thanks.
zezba9000 avatar image
zezba9000 answered
This issue still exists in Kindle Fire 1st Gen OS 6.3.3_user_4112920 with "Amazon GameCircle version 1.1_1101410" What I notice is: 1) "org.json.JSONException: No value for nativeCall" 2) Request player failure response: {"REQUEST_ID":"a95ed3bf-fd2d-4555-ba26-c31785c86038","RESPONSE_CODE":"6"} 3) AUTHENTICATION_ERROR Here is full logcat: D/Unity ( 3407): GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_vertex_half_float GL_OES_texture_float GL_OES_texture_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_fragment_precision_high GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_required_internalformat GL_OES_depth_texture GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_standard_derivatives GL_OES_vertex_array_object GL_OES_egl_sync GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_EXT_discard_framebuffer GL_EXT_shader_texture_lod GL_IMG_shader_binary GL_IMG_texture_compression_pvrtc GL_IMG_texture_stream2 GL_IMG_texture_npot GL_IMG_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_program_binary GL_IMG_multisampled_render_to_texture D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... I/Omap4ALSA( 1290): Using ping-pong! I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 90 msecs D/dalvikvm( 1397): GC_EXPLICIT freed 1132K, 53% free 5191K/10951K, external 2732K/3412K, paused 56ms I/dalvikvm( 3407): Failed resolving Lcom/amazon/ags/client/LifecycleCallbacks; interface 15 'Landroid/app/Application$ActivityLifecycleCallbacks;' W/dalvikvm( 3407): Link of class 'Lcom/amazon/ags/client/LifecycleCallbacks;' failed E/dalvikvm( 3407): Could not find class 'com.amazon.ags.client.LifecycleCallbacks', referenced from method com.amazon.ags.api.AmazonGamesClient.initialize_internal W/dalvikvm( 3407): VFY: unable to resolve new-instance 339 (Lcom/amazon/ags/client/LifecycleCallbacks;) in Lcom/amazon/ags/api/AmazonGamesClient; D/dalvikvm( 3407): VFY: replacing opcode 0x22 at 0x0078 D/dalvikvm( 3407): VFY: dead code 0x007a-0080 in Lcom/amazon/ags/api/AmazonGamesClient;.initialize_internal (Lcom/amazon/ags/api/AmazonGamesCallback;Landroid/app/Activity;ZLcom/amazon/ags/storage/StringObfuscator;Ljava/util/EnumSet;)V W/dalvikvm( 3407): No implementation found for native Lcom/amazon/ags/jni/AGSJniHandler;.isLoaded ()V I/AGSJniHandler( 3407): AmazonGamesJni is not loaded, trying to load library W/AGSJniHandler( 3407): AmazonGamesJni not found. Java Native Interface will not be available D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3407): Extracting verison incremental: D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3407): Extracting flavor: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3407): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/GameCircleClient( 3407): AmazonGamesClient not yet initialized. Initializing. D/dalvikvm( 3407): GC_CONCURRENT freed 554K, 50% free 3001K/5959K, external 849K/1181K, paused 1ms+2ms D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3407): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array V/AmazonInsightsSDK( 3407): Firing Session Event: _session.start I/AmazonInsightsSDK( 3407): Amazon Insights SDK(2.1.16.0) initialization successfully completed I/dalvikvm( 3407): Total arena pages for JIT: 11 D/GameCircleClient( 3407): initialize_internal() executing on thread:pool-2-thread-1 D/GC_Whispersync( 3407): Initial load from disk started V/GC_Whispersync( 3407): Retrieved JSON string [{"gameData":{}}] of game data map from disk W/GC_Whispersync( 3407): GameDataMap - Unable to merge from an invalid/unset GameDataMap com.amazon.ags.client.whispersync.GameDataSingleMap@405116d8 D/GC_Whispersync( 3407): Initial load from disk completed in 3 msec. I/AmazonInsightsSDK( 3407): Event: '_sess...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'WHISP...' recorded to local filestore I/AmazonInsightsSDK( 3407): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' I/AmazonInsightsSDK( 3407): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache D/dalvikvm( 3407): GC_CONCURRENT freed 459K, 49% free 3053K/5959K, external 849K/1181K, paused 2ms+4ms D/dalvikvm( 3407): GC_CONCURRENT freed 402K, 47% free 3207K/6023K, external 849K/1181K, paused 2ms+3ms D/dalvikvm( 3407): GC_CONCURRENT freed 477K, 48% free 3260K/6151K, external 849K/1181K, paused 2ms+2ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 30K, 48% free 3260K/6151K, external 849K/1181K, paused 19ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 6.453MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed <1K, 47% free 3345K/6279K, external 849K/1181K, paused 19ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 2K, 47% free 3347K/6279K, external 849K/1181K, paused 19ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 6.539MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed <1K, 47% free 3432K/6407K, external 849K/1181K, paused 20ms I/AmazonInsightsSDK( 3407): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3407): Resolved variation: 'Test' for project: 'Universal Experiment List' from server I/AmazonInsightsSDK( 3407): Attempting to retrieve variation(s) for project(s):'ManifestSrc','InitSigninAlertTest' I/AmazonInsightsSDK( 3407): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache I/AmazonInsightsSDK( 3407): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache D/dalvikvm( 3407): GC_FOR_MALLOC freed 339K, 47% free 3429K/6407K, external 849K/1181K, paused 22ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 46% free 3515K/6407K, external 849K/1181K, paused 19ms I/AmazonInsightsSDK( 3407): Resolved variation: 'Control' for project: 'ManifestSrc' from server I/AmazonInsightsSDK( 3407): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server I/AmazonInsightsSDK( 3407): Successful submission of 14 events D/dalvikvm( 3407): GC_FOR_MALLOC freed 256K, 45% free 3631K/6535K, external 849K/1181K, paused 23ms I/AmazonInsightsSDK( 3407): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: '_http...' recorded to local filestore D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3407): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: D/dalvikvm( 3407): GC_CONCURRENT freed 537K, 45% free 3711K/6663K, external 1016K/1181K, paused 2ms+3ms I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/KindleFireIPCProxy( 3407): Device appears to be a Kindle Fire. Attempting to connect to Amazon Game Services D/KindleFireIPCProxy( 3407): binding result:true V/KindleFireIPCProxy( 3407): synchronousBinder:null serviceMessengerClient:android.os.Messenger@405b7060 D/KindleFireIPCProxy( 3407): Client is bound to service D/KindleFireIPCProxy( 3407): Device has compatible version of Amazon Game Services. D/KindleFireIPCProxy( 3407): Attempting to Authorize D/KindleFireIPCProxy( 3407): Handling authorize callback D/KindleFireIPCProxy( 3407): authResult: AUTHORIZED D/KindleFireIPCProxy( 3407): Client is bound to service D/KindleFireIPCProxy( 3407): Attempting to check is authenticated D/KindleFireIPCProxy( 3407): Changing Status from:INITIALIZING to: SERVICE_CONNECTED E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 17473536, New space, used: 130776, Old pointers, used: 104504, Old data space, used: 51684, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 40960 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 32764, Old pointers, used: 152244, Old data space, used: 51692, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 86016 D/dalvikvm( 3407): GC_CONCURRENT freed 405K, 41% free 4072K/6855K, external 1016K/1181K, paused 2ms+3ms E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 131052, Old pointers, used: 172188, Old data space, used: 69024, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 86016 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 17670144, New space, used: 32764, Old pointers, used: 218920, Old data space, used: 86372, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 106496 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 131072, Old pointers, used: 302108, Old data space, used: 149052, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 65524, Old pointers, used: 315100, Old data space, used: 166120, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 262132, Old pointers, used: 330948, Old data space, used: 172972, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 65524, Old pointers, used: 429364, Old data space, used: 191220, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 262140, Old pointers, used: 471316, Old data space, used: 194712, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 19046400, New space, used: 131068, Old pointers, used: 538588, Old data space, used: 202864, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 19251200, New space, used: 523952, Old pointers, used: 563716, Old data space, used: 228988, Code space, used: 837024, Map space, used: 115744, Cell space, used: 8120, Large object space, used: 376832 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 19247104, New space, used: 0, Old pointers, used: 593080, Old data space, used: 220160, Code space, used: 661888, Map space, used: 64928, Cell space, used: 7608, Large object space, used: 372736 D/dalvikvm( 3407): GC_CONCURRENT freed 664K, 44% free 4107K/7239K, external 1016K/1181K, paused 2ms+2ms E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 20533248, New space, used: 523136, Old pointers, used: 859468, Old data space, used: 519484, Code space, used: 1150144, Map space, used: 93248, Cell space, used: 16736, Large object space, used: 479232 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 20795392, New space, used: 131064, Old pointers, used: 1006256, Old data space, used: 525016, Code space, used: 1150144, Map space, used: 93248, Cell space, used: 16736, Large object space, used: 479232 D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-5] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":true}] for request [backgroundwebview-5] D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-6] for call type [isKindleRegistered] D/KindleFireIPCProxy( 3407): Client is bound to service D/KindleFireIPCProxy( 3407): Attempting to check is authenticated D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":true}] for request [backgroundwebview-6] D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-7] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":true}] for request [backgroundwebview-7] D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-8] for call type [hasOptedIn] D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":false}] for request [backgroundwebview-8] D/GC_HttpNetworkClient( 3407): Request: GET https://ags-ext.amazon.com/services/featuredetection/getFeaturesUsage?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 21008384, New space, used: 524288, Old pointers, used: 1018712, Old data space, used: 535412, Code space, used: 1306848, Map space, used: 101792, Cell space, used: 16880, Large object space, used: 561152 D/dalvikvm( 3407): GetMethodID: method not found: Landroid/view/Display;.getRawWidth:()I E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 21098496, New space, used: 0, Old pointers, used: 1147660, Old data space, used: 529632, Code space, used: 1139296, Map space, used: 92224, Cell space, used: 16368, Large object space, used: 520192 D/GC_HttpNetworkClient( 3407): Request: PUT https://ags-ext.amazon.com/service/achievements/getAchievementsPublic D/GC_HttpNetworkClient( 3407): Request: PUT https://ags-ext.amazon.com/service/leaderboards/getLeaderboardsForGamePublic D/GC_HttpNetworkClient( 3407): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3407): GC_CONCURRENT freed 844K, 45% free 4109K/7367K, external 1016K/1181K, paused 3ms+3ms D/dalvikvm( 3407): GC_CONCURRENT freed 797K, 45% free 4123K/7367K, external 1016K/1181K, paused 2ms+3ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 212K, 47% free 3972K/7367K, external 1016K/1181K, paused 23ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.312MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed 17K, 47% free 4039K/7495K, external 1016K/1181K, paused 22ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 40K, 46% free 4067K/7495K, external 1016K/1181K, paused 24ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.405MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed 8K, 46% free 4145K/7623K, external 1016K/1181K, paused 21ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 45% free 4230K/7623K, external 1016K/1181K, paused 22ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.564MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 45% free 4315K/7751K, external 1016K/1181K, paused 22ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 26K, 44% free 4357K/7751K, external 1016K/1181K, paused 23ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.688MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed <1K, 44% free 4442K/7879K, external 1016K/1181K, paused 23ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 20K, 43% free 4553K/7879K, external 1016K/1181K, paused 23ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.879MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 43% free 4639K/8007K, external 1016K/1181K, paused 22ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 43% free 4639K/8007K, external 1016K/1181K, paused 24ms I/dalvikvm-heap( 3407): Grow heap (frag case) to 7.963MB for 87396-byte allocation D/dalvikvm( 3407): GC_FOR_MALLOC freed 0K, 42% free 4724K/8135K, external 1016K/1181K, paused 23ms D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore D/GC_ClickableToastImpl( 3407): Entering addToWindow... D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'PageV...' recorded to local filestore I/AGSJniHandler( 3407): Initializing Native Handlers D/GC_Whispersync( 3407): Starting write to file system V/GC_Whispersync( 3407): GameDataMap - Deep copy of GameDataMap with name: null V/GC_Whispersync( 3407): GameDataMap copy took 1 msec. V/GC_Whispersync( 3407): Writing game data to disk: [{"gameData":{}}] I/KindleFireSoftkeyBeachballManager( 3407): Failed to enable softkey button: java.lang.ClassNotFoundException: com.amazon.ags.app.util.SoftkeyBarWrapper I/AmazonInsightsSDK( 3407): Session Resume Failed: Session is already running. I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore D/GC_Whispersync( 3407): Completed write of 25 bytes to file system D/GC_Whispersync( 3407): posting event: DISK_WRITE_COMPLETE D/GC_Whispersync( 3407): Never synced from cloud. Attempting initial download and merge. D/GC_Whispersync( 3407): Checking whether Whispersync is enabled D/dalvikvm( 3407): GC_CONCURRENT freed 843K, 41% free 4843K/8135K, external 1016K/1181K, paused 2ms+3ms E/GC_PlayerClientImpl( 3407): Request player failure response: {"REQUEST_ID":"f1422ec7-6af6-426b-8602-2cb094281344","RESPONSE_CODE":"6"} I/Reign_Amazon_GameCircle( 3407): GameCircleGetPlayerAlias ERROR: AUTHENTICATION_ERROR D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-38] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":true}] for request [backgroundwebview-38] D/GC_NativeKindleFireStateCallHandler( 3407): Processing request [backgroundwebview-40] for call type [isWhispersyncEnabled] D/KindleFireIPCProxy( 3407): Checking isWhispersyncEnabled: true I/Unity ( 3407): Authenticated: False I/Unity ( 3407): I/Unity ( 3407): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) I/Unity ( 3407): D/GC_NativeKindleFireStateCallHandler( 3407): Returning reply [{"value":true}] for request [backgroundwebview-40] E/Unity ( 3407): AUTHENTICATION_ERROR E/Unity ( 3407): E/Unity ( 3407): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) E/Unity ( 3407): D/GC_Whispersync( 3407): Whispersync is DISABLED D/GC_Whispersync( 3407): Cannot sync with cloud because Whispersync is disabled D/GC_Whispersync( 3407): posting event: DISABLED D/GC_ClickableToastImpl( 3407): Entering runnable for hide() D/KindleFireIPCProxy( 3407): Checking isOverlaysSupported: false D/ActivityManager( 1397): Starting: Intent { act=1403634263839 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3407 I/AmazonInsightsSDK( 3407): Event: 'Objec...' recorded to local filestore I/InputQueue-JNI( 3407): Sending finished signal for input channel '405d4360 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' since it is being unregistered while an input message is still in progress. I/InputQueue-JNI( 3407): Ignoring finish signal on channel that is no longer registered. D/PhoneWindow( 3407): couldn't save which view has focus because the focused view android.view.SurfaceView@40532ca8 has no id. D/Reign ( 3407): onPause called! W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{40623da0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 21868544, New space, used: 739144, Old pointers, used: 1180128, Old data space, used: 550836, Code space, used: 1491424, Map space, used: 103872, Cell space, used: 16384, Large object space, used: 1028096 D/GC_GameCircleUserInterface( 3407): View size set to width: 512 height: 480 I/ActivityManager( 1397): Displayed com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface: +309ms E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 20983808, New space, used: 0, Old pointers, used: 1129940, Old data space, used: 540428, Code space, used: 1231744, Map space, used: 95136, Cell space, used: 16384, Large object space, used: 536576 D/dalvikvm( 3407): GC_CONCURRENT freed 855K, 40% free 5058K/8327K, external 1064K/1181K, paused 2ms+2ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 188K, 39% free 5354K/8647K, external 1064K/1181K, paused 27ms E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 21950464, New space, used: 1047780, Old pointers, used: 1296228, Old data space, used: 683808, Code space, used: 1777408, Map space, used: 181728, Cell space, used: 20440, Large object space, used: 585728 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 22212608, New space, used: 262132, Old pointers, used: 1585720, Old data space, used: 753800, Code space, used: 1777408, Map space, used: 181728, Cell space, used: 20440, Large object space, used: 585728 E/GC_WebViewFactory( 3407): JS(line 2): refreshScrollBounds called without first calling scrollify:9 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 23654400, New space, used: 1048572, Old pointers, used: 1752752, Old data space, used: 917060, Code space, used: 2471008, Map space, used: 217888, Cell space, used: 22072, Large object space, used: 978944 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 23982080, New space, used: 0, Old pointers, used: 2007784, Old data space, used: 896308, Code space, used: 2145728, Map space, used: 168768, Cell space, used: 21816, Large object space, used: 913408 E/GC_WebViewFactory( 3407): JS(line 5): Uncaught TypeError: Cannot read property 'style' of null E/Omap4ALSA( 1290): called drain&close W/GC_AsynchronousReplyMessenger( 3407): Request 5564d6da-c452-4774-9301-32c9c08c823e timed out. D/Reign ( 3407): onResume called! I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3407): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin W/GC_AsynchronousReplyMessenger( 3407): No pending message found for message id 63912c4d-f5d2-46f4-88a3-1d79b0e91aaa D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: D/com.amazon.identity.auth.device.datastore.DatabaseHelper.PII( 3407): DatabaseHelper created: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken: D/GC_NativeAuthCallHandler( 3407): Logged in: true I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3407): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/Omap4ALSA( 1290): Using ping-pong! D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken: D/GC_NativeAuthCallHandler( 3407): Logged in: true I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 152 msecs D/GC_HttpNetworkClient( 3407): Request: GET https://cortana-gateway.amazon.com/cortana/gateway/profile/isplayercountrysupported?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3407): GC_CONCURRENT freed 1333K, 42% free 5242K/9031K, external 1064K/1181K, paused 2ms+4ms D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'Accep...' recorded to local filestore D/GC_HttpNetworkClient( 3407): Request: POST https://cortana-gateway.amazon.com/cortana/gateway/profile/update?termsofservice=true&GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore E/GC_NetworkCallFactory( 3407): Unable to get nativeCall from request {"rid":67,"parameters":{"undefined":false}} E/GC_NetworkCallFactory( 3407): org.json.JSONException: No value for nativeCall E/GC_NetworkCallFactory( 3407): at org.json.JSONObject.get(JSONObject.java:354) E/GC_NetworkCallFactory( 3407): at org.json.JSONObject.getString(JSONObject.java:510) E/GC_NetworkCallFactory( 3407): at com.amazon.ags.html5.javascript.CallHandlerBase.handleMessage(CallHandlerBase.java:53) E/GC_NetworkCallFactory( 3407): at com.amazon.ags.html5.javascript.domain.JavascriptInterface$8.run(JavascriptInterface.java:235) E/GC_NetworkCallFactory( 3407): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088) E/GC_NetworkCallFactory( 3407): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581) E/GC_NetworkCallFactory( 3407): at java.lang.Thread.run(Thread.java:1019) E/GC_NetworkCallFactory( 3407): No receiver for reply associated with rid: 67 D/GC_HttpNetworkClient( 3407): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore W/GC_AsynchronousReplyMessenger( 3407): Request 7d4f5b0e-2c82-46e8-a642-c2f2a82dd973 timed out. D/dalvikvm( 3407): GC_CONCURRENT freed 1078K, 42% free 5243K/9031K, external 1064K/1181K, paused 6ms+8ms ^C Andrew-Wittes-Mac-mini:~ Andrew$ Andrew-Wittes-Mac-mini:~ Andrew$ /Users/Andrew/SDKs/adt-bundle-mac-x86_64-20130911/sdk/platform-tools/adb logcat --------- beginning of /dev/log/system I/ActivityManager( 1397): Start proc android.process.media for content provider com.android.providers.downloads/.DownloadProvider: pid=1799 uid=10011 gids={1015, 2001, 3003} I/ActivityManager( 1397): Start proc com.amazon.venezia for content provider com.amazon.venezia/com.amazon.mas.client.contentprovider.ContentProviderApps: pid=1857 uid=32018 gids={3003, 1015} I/ActivityManager( 1397): Start proc com.lab126.parentalcontrols for broadcast com.lab126.parentalcontrols/.ParentalBootBroadcastReceiver: pid=1875 uid=1000 gids={3003} W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/ActivityManager( 1397): Start proc com.amazon.email for broadcast com.amazon.email/.service.BootReceiver: pid=1889 uid=10018 gids={3003, 1015} V/AlarmManager( 1397): alarms: 1 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Dec 31 04:00:00 pm com.amazon.venezia I/ActivityManager( 1397): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=1913 uid=10021 gids={3003} I/ActivityManager( 1397): Start proc com.audible.application for broadcast com.audible.application/.BootReceiver: pid=1924 uid=10022 gids={} I/ActivityManager( 1397): Start proc com.audible.application.kindle for service com.audible.application.kindle/com.audible.application.stubservice.StubReceiverService: pid=1931 uid=32017 gids={3003, 1015, 3002} I/ActivityManager( 1397): Start proc com.amazon.dcp:UpdatesLookupService for broadcast com.amazon.dcp/.ota.UpdatesLookupService$MountStatusChangedReceiver: pid=1938 uid=32000 gids={2001, 3003, 1015, 1007, 1026} I/ActivityManager( 1397): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=1946 uid=10017 gids={1015, 3003} W/BackupManagerService( 1397): dataChanged but no participant pkg='com.android.providers.settings' uid=10011 I/InputManager-Callbacks( 1397): No virtual keys found for device ilitek_i2c. I/ActivityManager( 1397): Start proc com.amazon.dcp:TPHService for broadcast com.amazon.dcp/.tph.TPHService$WifiStatusChangeReceiver: pid=1964 uid=32000 gids={2001, 3003, 1015, 1007, 1026} I/ActivityManager( 1397): Start proc com.lab126.otter for broadcast com.lab126.otter/.AmazonMP3Receiver: pid=1978 uid=1000 gids={3003} V/AlarmManager( 1397): alarms: 1 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 25 08:55:11 am com.android.providers.calendar I/ActivityManager( 1397): No longer want android.process.acore (pid 1614): hidden #16 W/BackupManagerService( 1397): dataChanged but no participant pkg='com.android.providers.settings' uid=32005 D/WifiWatchdogService( 1397): (android.server.ServerThread) 00:00:00:00:14:74 does not require the watchdog D/ActivityManager( 1397): Starting: Intent { cmp=com.amazon.kindle.otter.oobe/.wifi.ZoneList } from pid 1679 I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 I/ActivityManager( 1397): Start proc com.amazon.avod:YVLSyncProcess for service com.amazon.avod/.service.YVLSyncService: pid=2025 uid=32020 gids={3003, 1015} I/ActivityManager( 1397): Start proc com.alphonso.pulse for broadcast com.alphonso.pulse/.background.OnTimeChangedReceiver: pid=2027 uid=10007 gids={3003, 1015} I/ActivityManager( 1397): Start proc com.amazon.dcp:CheckForOTAUpdatesService for service com.amazon.dcp/.ota.CheckForOTAUpdatesService: pid=2028 uid=32000 gids={2001, 3003, 1015, 1007, 1026} W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@409e6528 (uid=32005 pid=1679) W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40830528 I/ConnectivityService( 1397): Sending INET_CONDITION_ACTION broadcast I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/AlarmManager( 1397): alarms: 1 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 25 08:55:33 am com.android.providers.calendar I/ActivityManager( 1397): No longer want com.lab126.parentalcontrols (pid 1875): hidden #16 D/ActivityManager( 1397): Starting: Intent { cmp=com.amazon.kindle.otter.oobe/.registration.Unregistered } from pid 1679 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/AlarmManager( 1397): alarms: 2 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 24 05:54:31 pm com.amazon.venezia V/AlarmManager( 1397): 1: Jun 25 11:55:33 am com.android.providers.calendar V/AlarmManager( 1397): alarms: 2 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 24 05:54:31 pm com.amazon.venezia V/AlarmManager( 1397): 1: Jun 25 11:55:38 am com.android.providers.calendar I/ActivityManager( 1397): No longer want com.audible.application (pid 1924): hidden #16 I/ActivityManager( 1397): No longer want com.amazon.dcp:UpdatesLookupService (pid 1938): hidden #16 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40830288 I/ActivityManager( 1397): Start proc com.lab126.parentalcontrols for broadcast com.lab126.parentalcontrols/.ParentalAccountsReceiver: pid=2101 uid=1000 gids={3003} D/ActivityManager( 1397): Starting: Intent { flg=0x10000000 cmp=com.lab126.parentalcontrols/.ParentalDeregister } from pid 2101 I/LAB126 ( 1551): StatusBarService hears intent. action: com.amazon.dcp.sso.action.AmazonAccountPropertyService.property.changed D/IconMerger( 1551): sum of notifications: 0 W/ActivityManager( 1397): Duplicate finish request for HistoryRecord{406ee760 com.lab126.parentalcontrols/.ParentalDeregister} W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4085e190 I/LAB126 ( 1551): StatusBarService hears intent. action: com.amazon.dcp.sso.action.AmazonAccountPropertyService.property.changed D/ActivityManager( 1397): Starting: Intent { flg=0x24000000 cmp=com.amazon.kindle.otter.oobe/.registration.RegistrationComplete } from pid 1679 I/ActivityManager( 1397): Start proc com.amazon.windowshop for broadcast com.amazon.windowshop/.account.SSOAccountListener: pid=2108 uid=32002 gids={3003, 1015} W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@409e6528 (uid=32005 pid=1679) D/ActivityManager( 1397): Starting: Intent { flg=0x24000000 cmp=com.amazon.kindle.otter.oobe/.registration.RegistrationComplete } from pid 1679 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed E/ActivityThread( 2101): Activity com.lab126.parentalcontrols.ParentalDeregister has leaked IntentReceiver android.accounts.AccountManager$12@40521a88 that was originally registered here. Are you missing a call to unregisterReceiver()? E/ActivityThread( 2101): android.app.IntentReceiverLeaked: Activity com.lab126.parentalcontrols.ParentalDeregister has leaked IntentReceiver android.accounts.AccountManager$12@40521a88 that was originally registered here. Are you missing a call to unregisterReceiver()? E/ActivityThread( 2101): at android.app.LoadedApk$ReceiverDispatcher. (LoadedApk.java:756) E/ActivityThread( 2101): at android.app.LoadedApk.getReceiverDispatcher(LoadedApk.java:551) E/ActivityThread( 2101): at android.app.ContextImpl.registerReceiverInternal(ContextImpl.java:805) E/ActivityThread( 2101): at android.app.ContextImpl.registerReceiver(ContextImpl.java:792) E/ActivityThread( 2101): at android.app.ContextImpl.registerReceiver(ContextImpl.java:786) E/ActivityThread( 2101): at android.accounts.AccountManager.addOnAccountsUpdatedListener(AccountManager.java:1730) E/ActivityThread( 2101): at com.lab126.parentalcontrols.ParentalDeregister.onCreate(ParentalDeregister.java:33) E/ActivityThread( 2101): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1047) E/ActivityThread( 2101): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1611) E/ActivityThread( 2101): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1663) E/ActivityThread( 2101): at android.app.ActivityThread.access$1500(ActivityThread.java:117) E/ActivityThread( 2101): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:931) E/ActivityThread( 2101): at android.os.Handler.dispatchMessage(Handler.java:99) E/ActivityThread( 2101): at android.os.Looper.loop(Looper.java:130) E/ActivityThread( 2101): at android.app.ActivityThread.main(ActivityThread.java:3683) E/ActivityThread( 2101): at java.lang.reflect.Method.invokeNative(Native Method) E/ActivityThread( 2101): at java.lang.reflect.Method.invoke(Method.java:507) E/ActivityThread( 2101): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:850) E/ActivityThread( 2101): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:608) E/ActivityThread( 2101): at dalvik.system.NativeStart.main(Native Method) D/ActivityManager( 1397): Starting: Intent { act=com.amazon.tutorial.home cmp=com.amazon.otter.tutorial/.HomeTutorialActivity } from pid 1616 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/ActivityManager( 1397): Start proc com.amazon.otter.tutorial for activity com.amazon.otter.tutorial/.HomeTutorialActivity: pid=2127 uid=32003 gids={} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): Start proc com.audible.application.kindle:remote for service com.audible.application.kindle/com.audible.application.media.AudioPlayerService: pid=2140 uid=32017 gids={3003, 1015, 3002} I/LAB126 ( 1551): StatusBarService hears intent. action: com.amazon.dcp.sso.action.AmazonAccountPropertyService.property.changed W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.amazon.dcp.sso.action.AmazonAccountPropertyService.property.changed W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): No longer want com.lab126.otter (pid 1978): hidden #16 D/LAB126 ( 1551): launch settings from tap in the status bar, settings icon left = 506 D/ActivityManager( 1397): Starting: Intent { act=com.lab126.otter.launcher flg=0x10000000 cmp=com.lab126.otter/.MainScreen } from pid 1551 I/ActivityManager( 1397): Start proc com.lab126.otter for activity com.lab126.otter/.MainScreen: pid=2256 uid=1000 gids={3003} I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS V/AlarmManager( 1397): alarms: 2 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 24 04:49:03 pm com.amazon.venezia V/AlarmManager( 1397): 1: Jun 25 11:55:38 am com.android.providers.calendar I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.SETTINGS flg=0x10200000 cmp=com.android.settings/.Settings } from pid 2256 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.PrivacySettings } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/ActivityManager( 1397): Starting: Intent { cmp=com.amazon.kindle.otter.settings/.SettingsHome } from pid 1629 I/ActivityManager( 1397): Start proc com.amazon.kindle.otter.settings for activity com.amazon.kindle.otter.settings/.SettingsHome: pid=2368 uid=32006 gids={3003} I/ActivityManager( 1397): No longer want com.cooliris.media (pid 1946): hidden #16 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.ManageApplications } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.APPLICATION_DETAILS_SETTINGS dat=package:com.amazon.ags.app cmp=com.android.settings/.applications.InstalledAppDetails } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/Vold ( 1286): Ignoring unknown switch 'usb_connected' D/Vold ( 1286): USB connected D/Vold ( 1286): Share method ums now available W/Vold ( 1286): Ignoring unknown switch 'usb_mass_storage' I/StorageNotification( 1551): UMS connection changed to true (media state mounted) I/StorageNotification( 1551): In onUsbMassStorageConnectionChangedAsync, POP_UMS_ACTIVITY_ON_CONNECT=true D/StatusBarService( 1551): Notification has fullScreenIntent; sending fullScreenIntent D/ActivityManager( 1397): Starting: Intent { flg=0x10000000 cmp=com.android.systemui/.usb.UsbStorageActivity } from pid -1 I/ActivityManager( 1397): No longer want android.process.media (pid 1799): hidden #16 D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/VoldCmdListener( 1286): asec list I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window D/VoldCmdListener( 1286): storage users /mnt/sdcard D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/ActivityManager( 1397): Killing processes unmount media at adjustment 2 W/ActivityManager( 1397): Killing ProcessRecord{4070e2a8 1931:com.audible.application.kindle/32017} (adj 2): unmount media W/ActivityManager( 1397): Killing ProcessRecord{40859810 2140:com.audible.application.kindle:remote/32017} (adj 2): unmount media D/VoldCmdListener( 1286): storage users /mnt/sdcard W/ActivityManager( 1397): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.media.AudioPlayerService in 5000ms D/VoldCmdListener( 1286): volume unmount /mnt/sdcard force D/Vold ( 1286): Volume sdcard state changing 4 (Mounted) -> 5 (Unmounting) I/ActivityManager( 1397): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=2407 uid=10017 gids={1015, 3003} I/ActivityManager( 1397): No longer want com.amazon.dcp:CheckForOTAUpdatesService (pid 2028): hidden #16 I/Vold ( 1286): /mnt/secure/staging/.android_secure sucessfully unmounted I/Vold ( 1286): /mnt/secure/asec sucessfully unmounted I/Vold ( 1286): /mnt/secure/staging sucessfully unmounted I/Vold ( 1286): /mnt/sdcard unmounted sucessfully D/Vold ( 1286): Volume sdcard state changing 5 (Unmounting) -> 1 (Idle-Unmounted) I/StorageNotification( 1551): Media state changed from {mounted} -> {unmounted} I/ActivityManager( 1397): Start proc com.amazon.dcp:UpdatesLookupService for broadcast com.amazon.dcp/.ota.UpdatesLookupService$MountStatusChangedReceiver: pid=2417 uid=32000 gids={2001, 3003, 1015, 1007, 1026} D/VoldCmdListener( 1286): volume share /mnt/sdcard ums D/Vold ( 1286): Volume sdcard state changing 1 (Idle-Unmounted) -> 7 (Shared-Unmounted) W/MountService( 1397): Duplicate state transition (unmounted -> unmounted) D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums I/StorageNotification( 1551): Media state changed from {unmounted} -> {shared} D/IconMerger( 1551): sum of notifications: 0 I/ActivityManager( 1397): No longer want com.alphonso.pulse (pid 2027): hidden #16 D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 D/VoldCmdListener( 1286): volume unshare /mnt/sdcard ums D/Vold ( 1286): Volume sdcard state changing 7 (Shared-Unmounted) -> 1 (Idle-Unmounted) I/StorageNotification( 1551): Media state changed from {shared} -> {unmounted} D/VoldCmdListener( 1286): volume mount /mnt/sdcard I/Vold ( 1286): /dev/block/vold/179:12 being considered for volume sdcard D/Vold ( 1286): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking) I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): Start proc com.audible.application.kindle:remote for service com.audible.application.kindle/com.audible.application.media.AudioPlayerService: pid=2431 uid=32017 gids={3003, 1015, 3002} I/Vold ( 1286): Filesystem check completed OK I/Vold ( 1286): Device /dev/block/vold/179:12, target /mnt/sdcard mounted @ /mnt/secure/staging D/Vold ( 1286): Volume sdcard state changing 3 (Checking) -> 4 (Mounted) D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/VoldCmdListener( 1286): volume unshare /mnt/sdcard ums W/Vold ( 1286): Returning OperationFailed - no handler for errno 22 I/StorageNotification( 1551): Media state changed from {unmounted} -> {checking} E/MountService( 1397): Failed to share/unshare E/MountService( 1397): com.android.server.NativeDaemonConnectorException: Cmd {volume unshare /mnt/sdcard ums} failed with code 400 : {volume operation failed (Invalid argument)} E/MountService( 1397): at com.android.server.NativeDaemonConnector.doCommand(NativeDaemonConnector.java:259) E/MountService( 1397): at com.android.server.MountService.doShareUnshareVolume(MountService.java:508) E/MountService( 1397): at com.android.server.MountService.setUsbMassStorageEnabled(MountService.java:1231) E/MountService( 1397): at android.os.storage.IMountService$Stub.onTransact(IMountService.java:683) E/MountService( 1397): at android.os.Binder.execTransact(Binder.java:320) E/MountService( 1397): at dalvik.system.NativeStart.run(Native Method) D/VoldCmdListener( 1286): volume mount /mnt/sdcard E/MountService( 1397): Failed to remount /mnt/sdcard after disabling share method ums I/ActivityManager( 1397): Start proc android.process.media for broadcast com.android.providers.media/.MediaScannerReceiver: pid=2441 uid=10011 gids={1015, 2001, 3003} I/StorageNotification( 1551): Media state changed from {checking} -> {mounted} D/VoldCmdListener( 1286): asec list W/PackageManager( 1397): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.dcp.sso.permission.USE_DEVICE_CREDENTIALS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.dcp.settings.permission.READ_SETTINGS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.kindle.dtcp.permission.DTCP_SERVICE_ACCESS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts W/PackageManager( 1397): Unknown permission android.permission.DEVICE_ADMIN in package com.lab126.otter W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar W/PackageManager( 1397): Unknown permission org.thialfihar.android.apg.permission.READ_KEY_DETAILS in package com.amazon.email W/PackageManager( 1397): Unknown permission com.amazon.kindle.cms.CMS_ACCESS in package com.amazon.avod W/PackageManager( 1397): Not granting permission com.amazon.dcp.metrics.permission.METRICS_PERMISSION to package com.cooliris.media (protectionLevel=2 flags=0x8bc45) W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.INSTALL_SHORTCUT in package com.amazon.cloud9 W/PackageManager( 1397): Unknown permission android.webkit.permission.PLUGIN in package com.adobe.flashplayer W/PackageManager( 1397): Unknown permission com.google.android.providers.gmail.permission.WRITE_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.providers.gmail.permission.READ_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission android.permission.READ_OWNER_DATA in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.android.email.permission.ACCESS_PROVIDER in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.amzon.permission.CONFIG_SOFTKEYS in package com.lab126.parentalcontrols W/PackageManager( 1397): Not granting permission com.amazon.dcp.metrics.permission.METRICS_PERMISSION to package com.alphonso.pulse (protectionLevel=2 flags=0x8be45) D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 I/ActivityManager( 1397): No longer want com.lab126.parentalcontrols (pid 2101): hidden #16 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/ProcessStats( 1397): Skipping unknown process pid 2528 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): New temperature state Init, adjust charge current I/ChargeProtectionService( 1397): New full charge capacity, adjust charge current I/ChargeProtectionService( 1397): New charge current: 2683 mA V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/StorageNotification( 1551): LockScreen: OnReceive V/AlarmManager( 1397): alarms: 3 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 24 02:07:16 pm android V/AlarmManager( 1397): 1: Jun 24 04:49:03 pm com.amazon.venezia V/AlarmManager( 1397): 2: Jun 25 11:55:38 am com.android.providers.calendar I/ChargeProtectionService( 1397): New full charge capacity, adjust charge current I/ChargeProtectionService( 1397): New charge current: 2690 mA I/WakelockDebugService( 1397): Dumping PowerManager state I/WakelockDebugService( 1397): Power Manager State: I/WakelockDebugService( 1397): mIsPowered=true mPowerState=0 mScreenOffTime=5097 ms I/WakelockDebugService( 1397): mPartialCount=1 I/WakelockDebugService( 1397): mWakeLockState= I/WakelockDebugService( 1397): mUserState= I/WakelockDebugService( 1397): mPowerState= I/WakelockDebugService( 1397): mLocks.gather= I/WakelockDebugService( 1397): mNextTimeout=869510 now=874608 -5s from now I/WakelockDebugService( 1397): mDimScreen=true mStayOnConditions=0 I/WakelockDebugService( 1397): mScreenOffReason=3 mUserState=0 I/WakelockDebugService( 1397): mBroadcastQueue={-1,-1,-1} I/WakelockDebugService( 1397): mBroadcastWhy={0,0,0} I/WakelockDebugService( 1397): mPokey=0 mPokeAwakeonSet=false I/WakelockDebugService( 1397): mKeyboardVisible=false mUserActivityAllowed=true I/WakelockDebugService( 1397): mKeylightDelay=6000 mDimDelay=287000 mScreenOffDelay=7000 I/WakelockDebugService( 1397): mPreventScreenOn=false mScreenBrightnessOverride=-1 mButtonBrightnessOverride=-1 I/WakelockDebugService( 1397): mScreenOffTimeoutSetting=300000 mMaximumScreenOffTimeout=2147483647 I/WakelockDebugService( 1397): mLastScreenOnTime=0 I/WakelockDebugService( 1397): mBroadcastWakeLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mStayOnWhilePluggedInScreenDimLock=UnsynchronizedWakeLock(mFlags=0x6 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mStayOnWhilePluggedInPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mPreventScreenOnPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mProximityPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mProximityWakeLockCount=0 I/WakelockDebugService( 1397): mProximitySensorEnabled=false I/WakelockDebugService( 1397): mProximitySensorActive=false I/WakelockDebugService( 1397): mProximityPendingValue=-1 I/WakelockDebugService( 1397): mLastProximityEventTime=0 I/WakelockDebugService( 1397): mLightSensorEnabled=false I/WakelockDebugService( 1397): mLightSensorValue=-1.0 mLightSensorPendingValue=-1.0 I/WakelockDebugService( 1397): mLightSensorScreenBrightness=-1 mLightSensorButtonBrightness=-1 mLightSensorKeyboardBrightness=-1 I/WakelockDebugService( 1397): mUseSoftwareAutoBrightness=true I/WakelockDebugService( 1397): mAutoBrightessEnabled=false I/WakelockDebugService( 1397): mScreenBrightness: animating=false targetValue=0 curValue=0.0 delta=-5.0 I/WakelockDebugService( 1397): mLocks.size=1: I/WakelockDebugService( 1397): PARTIAL_WAKE_LOCK 'show keyguard' activated (minState=0, uid=1000, pid=1397) I/WakelockDebugService( 1397): mPokeLocks.size=0: I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 I/ActivityManager( 1397): Start proc com.audible.application.kindle for broadcast com.audible.application.kindle/com.amazon.kindle.SyncBroadcastEventTracker: pid=2619 uid=32017 gids={3003, 1015, 3002} I/ActivityManager( 1397): No longer want com.android.providers.calendar (pid 1913): hidden #16 I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/StorageNotification( 1551): LockScreen: OnReceive W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4059e8f0 I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 D/WifiWatchdogService( 1397): (android.server.ServerThread) 00:00:00:00:14:74 does not require the watchdog I/ActivityManager( 1397): Start proc com.alphonso.pulse for broadcast com.alphonso.pulse/.background.OnTimeChangedReceiver: pid=2699 uid=10007 gids={3003, 1015} I/ConnectivityService( 1397): Sending INET_CONDITION_ACTION broadcast I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 1 W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found I/ActivityManager( 1397): No longer want com.amazon.cloud9 (pid 1726): hidden #16 W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging I/ActivityManager( 1397): Start proc com.android.defcontainer for service com.android.defcontainer/.DefaultContainerService: pid=2744 uid=10019 gids={1015, 2001} W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: I/ActivityManager( 1397): No longer want com.amazon.kindle.otter.oobe (pid 1679): hidden #16 D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-1 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-1 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-1 {} 1000 D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-1 I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Start proc com.svox.pico for broadcast com.svox.pico/.VoiceDataInstallerReceiver: pid=2803 uid=10009 gids={} W/RecognitionManagerService( 1397): no available voice recognition services found I/ActivityManager( 1397): Start proc com.android.quicksearchbox for broadcast com.android.quicksearchbox/.CorporaUpdateReceiver: pid=2815 uid=10006 gids={3003} I/ActivityManager( 1397): No longer want com.amazon.otter.tutorial (pid 2127): hidden #16 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 2827 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=2836 uid=10023 gids={3003, 1015} I/WindowManager( 1397): Setting rotation to 1, animFlags=1 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435491 uiMode=17 seq=4} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): Start proc com.amazon.ags.app for service com.amazon.ags.app/.service.AmazonGamesService: pid=2877 uid=32019 gids={3003} W/ActivityManager( 1397): Unable to start service Intent { act=SetIdentity cmp=com.amazon.ags.app/com.amazon.insights.InsightsProcessingService (has extras) }: not found W/ActivityManager( 1397): Unable to start service Intent { act=PutMeasurement cmp=com.amazon.ags.app/com.amazon.insights.InsightsProcessingService (has extras) }: not found V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ActivityManager( 1397): No longer want com.lab126.otter (pid 2256): hidden #16 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{40780ee0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} W/ProcessStats( 1397): Skipping unknown process pid 2908 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@405f5150 (uid=10023 pid=2836) I/ActivityManager( 1397): No longer want com.amazon.kindle.otter.settings (pid 2368): hidden #16 I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 2836) has died. I/WindowManager( 1397): WIN DEATH: Window{405fd838 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{40780ee0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=2916 uid=10023 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/ActivityManager( 1397): Starting: Intent { act=1403633454148 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 2916 W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW dat= https://www.amazon.com/ap/oa?response_type=code&redirect_uri=amzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin&client_id=amzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1&amzn_respectRmrMeAuthState=1&amzn_showRmrMe=1&amzn_rmrMeDefaultSelected=1&state=clientId%3Damzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1%26redirectUri%3Damzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin%26clientRequestId%3D2fad4a39-1a1c-4746-910f-9e3bc25ba3e1&scope=game_circle%3Agame_data flg=0x40000000 cmp=com.amazon.cloud9/.BrowserActivity } from pid 2916 I/ActivityManager( 1397): Start proc com.amazon.cloud9 for activity com.amazon.cloud9/.BrowserActivity: pid=2974 uid=32015 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40a2a038 (uid=32015 pid=2974) W/InputManagerService( 1397): Client not active, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4086a1c0 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat= https://www.amazon.com/ap/signin?_encoding=UTF8&openid.assoc_handle=iba&openid.return_to=https%3A%2F%2Fwww.amazon.com%2Fap%2Foa%3Farb%3D7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.mode=checkid_setup&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.pape.max_auth_age=0&ie=UTF8&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&arb=7fd7ae84-be3b-45b6-8015-cabff21ae869&marketPlaceId=ATVPDKIKX0DER&showRmrMe=1&rmrMeDefaultSelected=1&language=en_US&metricIdentifier=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&signedMetricIdentifier=GOYAC9XVBt48AXcEyoRI1WkxK6riiKwjUBYx08UXDnY%3D cmp=com.amazon.cloud9/.BrowserActivity } from pid 2974 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat= https://www.amazon.com/ap/oa?arb=7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.assoc_handle=iba&aToken=5%7Cm3TMf5jrCeBJ%2F5ws2PM3HNHxiPKx6hSftv7Fb4tEOyWjUR4Fj4X17TYqG1fAcWBk9ug%2FMLsipfKbz8KdRRKn8v0ip%2B%2B957LYaj47Ipyj7EygcPh3k0T3SSqGAeHQXpy1xgtiQ7ZyzzdywbYmPlxkU1uBoFD1SfaxmKYb5UgIIPADZHv75KiAqwVbPhboxdk65f4C6lgSE5e22ApvRlWUbymxkQ2ic64M&openid.claimed_id=https%3A%2F%2Fwww.amazon.com%2Fap%2Fid%2Famzn1.account.AHD3MEARB4N6TNEP27BAFY2WVKXA&openid.identity=https%3A%2F%2Fwww.amazon.com%2Fap%2Fid%2Famzn1.account.AHD3MEARB4N6TNEP27BAFY2WVKXA&openid.mode=id_res&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.op_endpoint=https%3A%2F%2Fwww.amazon.com%2Fap%2Fsignin&openid.response_nonce=2014-06-24T18%3A11%3A49Z-3555954533292340006&openid.return_to=https%3A%2F%2Fwww.amazon.com%2Fap%2Foa%3Farb%3D7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.signed=assoc_handle%2CaToken%2Cclaimed_id%2Cidentity%2Cmode%2Cns%2Cop_endpoint%2Cresponse_nonce%2Creturn_to%2Cns.pape%2Cpape.auth_policies%2Cpape.auth_time%2Csigned&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.pape.auth_policies=http%3A%2F%2Fschemas.openid.net%2Fpape%2Fpolicies%2F2007%2F06%2Fnone&openid.pape.auth_time=2014-06-24T18%3A11%3A49Z&openid.sig=cVD8b1bZjjKRq53GZFpMoNRtIQplONCWxigOKfLqiig%3D&serial=&; cmp=com.amazon.cloud9/.BrowserActivity } from pid 2974 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat=amzn://com.ReignStudios.ReignUnityPlugin?code=ANayHDrLetWQwiLggxrW&scope=game_circle%3Agame_data&state=clientId%3Damzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1%26redirectUri%3Damzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin%26clientRequestId%3D2fad4a39-1a1c-4746-910f-9e3bc25ba3e1 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.identity.auth.device.authorization.AuthorizationActivity } from pid 2974 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40a2a038 (uid=32015 pid=2974) I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4095e840 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): No longer want com.amazon.dcp:UpdatesLookupService (pid 2417): hidden #16 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/WindowManager( 1397): WINDOW DIED Window{407062c0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 2916) has died. I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40849630 W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3100 uid=10023 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=1403633561537 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3100 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging W/ProcessStats( 1397): Skipping unknown process pid 3175 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/WindowManager( 1397): Setting rotation to 0, animFlags=0 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=1 layout=268435491 uiMode=17 seq=5} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 D/LAB126 ( 1551): launch settings from tap in the status bar, settings icon left = 506 D/ActivityManager( 1397): Starting: Intent { act=com.lab126.otter.launcher flg=0x10000000 cmp=com.lab126.otter/.MainScreen } from pid 1551 I/ActivityManager( 1397): Start proc com.lab126.otter for activity com.lab126.otter/.MainScreen: pid=3218 uid=1000 gids={3003} I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.SETTINGS flg=0x10200000 cmp=com.android.settings/.Settings } from pid 3218 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.PrivacySettings } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.ManageApplications } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.APPLICATION_DETAILS_SETTINGS dat=package:com.amazon.ags.app cmp=com.android.settings/.applications.InstalledAppDetails } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/ProcessStats( 1397): Skipping unknown process pid 3234 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.PrivacySettings } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 I/ActivityManager( 1397): No longer want com.cooliris.media (pid 2407): hidden #16 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 W/ProcessStats( 1397): Skipping unknown process pid 3353 D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-2 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-2 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-2 {} 1000 D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-2 I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 I/ActivityManager( 1397): Force finishing activity HistoryRecord{406186d0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} I/WindowManager( 1397): WIN DEATH: Window{407184b0 SurfaceView paused=false} I/WindowManager( 1397): WIN DEATH: Window{40580880 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=true} I/PackageManager( 1397): Package com.ReignStudios.ReignUnityPlugin codePath changed; Retaining data and using new I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin I/ChargeProtectionService( 1397): Battery discharging, resuming charging W/PackageManager( 1397): Code path for pkg : com.ReignStudios.ReignUnityPlugin changed. I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Resource path for pkg : com.ReignStudios.ReignUnityPlugin changed. W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/RecognitionManagerService( 1397): no available voice recognition services found D/VoldCmdListener( 1286): asec unmount com.ReignStudios.ReignUnityPlugin-1 force D/VoldCmdListener( 1286): asec destroy com.ReignStudios.ReignUnityPlugin-1 force D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 3397 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3407 uid=10023 gids={3003, 1015} I/WindowManager( 1397): Setting rotation to 1, animFlags=1 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435491 uiMode=17 seq=6} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=1403634263839 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3407 W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{40623da0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} --------- beginning of /dev/log/main D/GC_GameCircleUserInterface( 3407): View size set to width: 512 height: 480 I/ActivityManager( 1397): Displayed com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface: +309ms E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 20983808, New space, used: 0, Old pointers, used: 1129940, Old data space, used: 540428, Code space, used: 1231744, Map space, used: 95136, Cell space, used: 16384, Large object space, used: 536576 D/dalvikvm( 3407): GC_CONCURRENT freed 855K, 40% free 5058K/8327K, external 1064K/1181K, paused 2ms+2ms D/dalvikvm( 3407): GC_FOR_MALLOC freed 188K, 39% free 5354K/8647K, external 1064K/1181K, paused 27ms E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 21950464, New space, used: 1047780, Old pointers, used: 1296228, Old data space, used: 683808, Code space, used: 1777408, Map space, used: 181728, Cell space, used: 20440, Large object space, used: 585728 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 22212608, New space, used: 262132, Old pointers, used: 1585720, Old data space, used: 753800, Code space, used: 1777408, Map space, used: 181728, Cell space, used: 20440, Large object space, used: 585728 E/GC_WebViewFactory( 3407): JS(line 2): refreshScrollBounds called without first calling scrollify:9 E/v8 ( 3407): > Heap::CollectGarbage Memory allocator, used: 23654400, New space, used: 1048572, Old pointers, used: 1752752, Old data space, used: 917060, Code space, used: 2471008, Map space, used: 217888, Cell space, used: 22072, Large object space, used: 978944 E/v8 ( 3407): < Heap::CollectGarbage Memory allocator, used: 23982080, New space, used: 0, Old pointers, used: 2007784, Old data space, used: 896308, Code space, used: 2145728, Map space, used: 168768, Cell space, used: 21816, Large object space, used: 913408 E/GC_WebViewFactory( 3407): JS(line 5): Uncaught TypeError: Cannot read property 'style' of null E/Omap4ALSA( 1290): called drain&close W/GC_AsynchronousReplyMessenger( 3407): Request 5564d6da-c452-4774-9301-32c9c08c823e timed out. D/Reign ( 3407): onResume called! I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3407): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin W/GC_AsynchronousReplyMessenger( 3407): No pending message found for message id 63912c4d-f5d2-46f4-88a3-1d79b0e91aaa D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: D/com.amazon.identity.auth.device.datastore.DatabaseHelper.PII( 3407): DatabaseHelper created: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken: D/GC_NativeAuthCallHandler( 3407): Logged in: true I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3407): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3407): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3407): Finding API Key for com.ReignStudios.ReignUnityPlugin D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3407): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3407): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3407): perm has no mapping in json, returning null array I/Omap4ALSA( 1290): Using ping-pong! D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3407): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3407): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3407): GetToken: D/GC_NativeAuthCallHandler( 3407): Logged in: true I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 152 msecs D/GC_HttpNetworkClient( 3407): Request: GET https://cortana-gateway.amazon.com/cortana/gateway/profile/isplayercountrysupported?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3407): GC_CONCURRENT freed 1333K, 42% free 5242K/9031K, external 1064K/1181K, paused 2ms+4ms D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3407): Event: 'Accep...' recorded to local filestore D/GC_HttpNetworkClient( 3407): Request: POST https://cortana-gateway.amazon.com/cortana/gateway/profile/update?termsofservice=true&GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore E/GC_NetworkCallFactory( 3407): Unable to get nativeCall from request {"rid":67,"parameters":{"undefined":false}} E/GC_NetworkCallFactory( 3407): org.json.JSONException: No value for nativeCall E/GC_NetworkCallFactory( 3407): at org.json.JSONObject.get(JSONObject.java:354) E/GC_NetworkCallFactory( 3407): at org.json.JSONObject.getString(JSONObject.java:510) E/GC_NetworkCallFactory( 3407): at com.amazon.ags.html5.javascript.CallHandlerBase.handleMessage(CallHandlerBase.java:53) E/GC_NetworkCallFactory( 3407): at com.amazon.ags.html5.javascript.domain.JavascriptInterface$8.run(JavascriptInterface.java:235) E/GC_NetworkCallFactory( 3407): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088) E/GC_NetworkCallFactory( 3407): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581) E/GC_NetworkCallFactory( 3407): at java.lang.Thread.run(Thread.java:1019) E/GC_NetworkCallFactory( 3407): No receiver for reply associated with rid: 67 D/GC_HttpNetworkClient( 3407): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3407): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3407): Event: 'GameC...' recorded to local filestore W/GC_AsynchronousReplyMessenger( 3407): Request 7d4f5b0e-2c82-46e8-a642-c2f2a82dd973 timed out. D/dalvikvm( 3407): GC_CONCURRENT freed 1078K, 42% free 5243K/9031K, external 1064K/1181K, paused 6ms+8ms D/dalvikvm( 1397): GC_CONCURRENT freed 1185K, 53% free 5187K/10951K, external 2732K/3412K, paused 3ms+4ms W/GC_AsynchronousReplyMessenger( 3407): Request d83a3933-807a-4811-a1a6-d3cb49aa6ba2 timed out. D/dalvikvm( 2744): GC_EXPLICIT freed 4K, 52% free 2782K/5703K, external 847K/1181K, paused 130ms D/dalvikvm( 2803): GC_EXPLICIT freed 46K, 50% free 2729K/5379K, external 847K/1181K, paused 94ms D/dalvikvm( 3407): GC_CONCURRENT freed 1175K, 44% free 5147K/9031K, external 1064K/1181K, paused 6ms+9ms V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/dalvikvm( 2815): GC_EXPLICIT freed 77K, 49% free 2779K/5379K, external 847K/1181K, paused 99ms D/dalvikvm( 1397): GC_CONCURRENT freed 1185K, 53% free 5186K/10951K, external 2732K/3412K, paused 7ms+10ms D/dalvikvm( 3407): GC_CONCURRENT freed 1080K, 44% free 5115K/9031K, external 1064K/1181K, paused 6ms+7ms D/dalvikvm( 1397): GC_CONCURRENT freed 1241K, 53% free 5248K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1321K, 53% free 5245K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1319K, 53% free 5244K/10951K, external 2732K/3412K, paused 13ms+9ms D/dalvikvm( 1397): GC_CONCURRENT freed 1317K, 53% free 5245K/10951K, external 2732K/3412K, paused 7ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1318K, 53% free 5244K/10951K, external 2732K/3412K, paused 8ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1318K, 53% free 5244K/10951K, external 2732K/3412K, paused 7ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1301K, 53% free 5255K/10951K, external 2732K/3412K, paused 6ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1330K, 53% free 5245K/10951K, external 2732K/3412K, paused 7ms+9ms W/ProcessStats( 1397): Skipping unknown process pid 3473 D/dalvikvm( 1397): GC_CONCURRENT freed 1266K, 52% free 5296K/10951K, external 2732K/3412K, paused 8ms+11ms D/dalvikvm( 1397): GC_CONCURRENT freed 1383K, 53% free 5245K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1314K, 53% free 5241K/10951K, external 2732K/3412K, paused 3ms+5ms D/dalvikvm( 1397): GC_CONCURRENT freed 1318K, 53% free 5240K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1318K, 53% free 5230K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1315K, 53% free 5229K/10951K, external 2732K/3412K, paused 4ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1326K, 53% free 5212K/10951K, external 2732K/3412K, paused 3ms+4ms I/dalvikvm( 1397): Total arena pages for JIT: 12 D/dalvikvm( 3407): GC_CONCURRENT freed 1048K, 44% free 5098K/9031K, external 1064K/1181K, paused 3ms+2ms D/dalvikvm( 1397): GC_CONCURRENT freed 1209K, 53% free 5188K/10951K, external 2732K/3412K, paused 2ms+4ms W/ProcessStats( 1397): Skipping unknown process pid 3478 I/ActivityManager( 1397): No longer want com.amazon.windowshop (pid 2108): hidden #16 W/ActivityManager( 1397): Scheduling restart of crashed service com.amazon.windowshop/.account.SSOAccountListener$BackgroundAccountService in 5000ms D/dalvikvm( 3407): GC_CONCURRENT freed 1040K, 44% free 5089K/9031K, external 1064K/1181K, paused 6ms+9ms I/ActivityManager( 1397): Start proc com.amazon.windowshop for service com.amazon.windowshop/.account.SSOAccountListener$BackgroundAccountService: pid=3480 uid=32002 gids={3003, 1015} D/dalvikvm( 1289): GC_EXPLICIT freed 11K, 50% free 2729K/5379K, external 847K/1181K, paused 161ms D/dalvikvm( 1289): GC_EXPLICIT freed <1K, 50% free 2729K/5379K, external 847K/1181K, paused 133ms D/dalvikvm( 1289): GC_EXPLICIT freed <1K, 50% free 2729K/5379K, external 847K/1181K, paused 99ms D/dalvikvm( 1397): GC_CONCURRENT freed 1185K, 53% free 5187K/10951K, external 2732K/3412K, paused 7ms+10ms V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/dalvikvm( 3407): GC_CONCURRENT freed 1033K, 44% free 5080K/9031K, external 1064K/1181K, paused 7ms+7ms D/dalvikvm( 1397): GC_CONCURRENT freed 1185K, 53% free 5186K/10951K, external 2732K/3412K, paused 7ms+13ms D/dalvikvm( 3407): GC_CONCURRENT freed 1024K, 44% free 5081K/9031K, external 1064K/1181K, paused 7ms+7ms D/dalvikvm( 1629): GC_EXPLICIT freed 11K, 52% free 3846K/8007K, external 3133K/3861K, paused 87ms D/dalvikvm( 1397): GC_CONCURRENT freed 1250K, 53% free 5239K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1316K, 53% free 5239K/10951K, external 2732K/3412K, paused 7ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1319K, 53% free 5237K/10951K, external 2732K/3412K, paused 7ms+9ms D/dalvikvm( 1397): GC_CONCURRENT freed 1315K, 53% free 5239K/10951K, external 2732K/3412K, paused 7ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1283K, 52% free 5272K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1359K, 53% free 5238K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1315K, 53% free 5238K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1317K, 53% free 5238K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1317K, 53% free 5238K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1316K, 53% free 5238K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1289K, 52% free 5260K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1341K, 53% free 5235K/10951K, external 2732K/3412K, paused 8ms+13ms D/dalvikvm( 1397): GC_CONCURRENT freed 1321K, 53% free 5230K/10951K, external 2732K/3412K, paused 7ms+9ms D/dalvikvm( 1397): GC_CONCURRENT freed 1306K, 53% free 5238K/10951K, external 2732K/3412K, paused 7ms+11ms D/dalvikvm( 1397): GC_CONCURRENT freed 1251K, 53% free 5182K/10951K, external 2732K/3412K, paused 7ms+10ms D/dalvikvm( 3407): GC_CONCURRENT freed 1021K, 44% free 5080K/9031K, external 1064K/1181K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1173K, 53% free 5186K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 3407): GC_CONCURRENT freed 1019K, 44% free 5080K/9031K, external 1064K/1181K, paused 2ms+2ms V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/dalvikvm( 3407): GC_CONCURRENT freed 1022K, 44% free 5081K/9031K, external 1064K/1181K, paused 7ms+7ms D/dalvikvm( 1397): GC_CONCURRENT freed 1189K, 53% free 5176K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 3407): GC_CONCURRENT freed 1024K, 44% free 5081K/9031K, external 1064K/1181K, paused 6ms+6ms D/dalvikvm( 1397): GC_CONCURRENT freed 1238K, 53% free 5239K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1325K, 53% free 5226K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1305K, 53% free 5234K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1290K, 52% free 5259K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1346K, 53% free 5233K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1316K, 53% free 5233K/10951K, external 2732K/3412K, paused 4ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1281K, 52% free 5267K/10951K, external 2732K/3412K, paused 3ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1315K, 52% free 5268K/10951K, external 2732K/3412K, paused 6ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1356K, 53% free 5236K/10951K, external 2732K/3412K, paused 9ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1317K, 53% free 5234K/10951K, external 2732K/3412K, paused 7ms+9ms D/dalvikvm( 1397): GC_CONCURRENT freed 1330K, 53% free 5218K/10951K, external 2732K/3412K, paused 6ms+10ms D/dalvikvm( 1397): GC_CONCURRENT freed 1323K, 53% free 5204K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1268K, 53% free 5233K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1322K, 53% free 5226K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1300K, 53% free 5234K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1247K, 53% free 5176K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 3407): GC_CONCURRENT freed 1022K, 44% free 5079K/9031K, external 1064K/1181K, paused 2ms+3ms D/dalvikvm( 3407): GC_CONCURRENT freed 1020K, 44% free 5080K/9031K, external 1064K/1181K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1178K, 53% free 5174K/10951K, external 2732K/3412K, paused 3ms+3ms V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys E/NativeActivity( 3407): channel '4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' ~ Failed to receive dispatch signal. status=-11 W/KeyCharacterMap( 3407): No keyboard for id 0 W/KeyCharacterMap( 3407): Using default keymap: /system/usr/keychars/qwerty.kcm.bin E/NativeActivity( 3407): channel '4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' ~ Failed to receive dispatch signal. status=-11 E/NativeActivity( 3407): channel '4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' ~ Failed to receive dispatch signal. status=-11 E/NativeActivity( 3407): channel '4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' ~ Failed to receive dispatch signal. status=-11 D/Reign ( 3407): onPause called! W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed E/SensorService( 1397): dropping 1 events on the floor (Broken pipe) E/SensorService( 1397): dropping 1 events on the floor (Broken pipe) E/Omap4ALSA( 1290): called drain&close E/SensorService( 1397): dropping 1 events on the floor (Broken pipe) E/SensorService( 1397): dropping 1 events on the floor (Broken pipe) W/SurfaceFlinger( 1397): closeGlobalTransaction timed out! W/GraphicBufferAllocator( 1397): free(...) failed -14 (Bad address) I/ActivityManager( 1397): No longer want android.process.media (pid 2441): hidden #16 D/ReignUnityActivity( 3407): onDestroy called! D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeVideoFrameCallback:VILII D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSoftInputClosed:V D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetTouchDeltaY:VF D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetInputString:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetInputCanceled:VZ D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetExtras:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetDefaultDisplay:VI D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeResume:V D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeResize:VIIII D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeRequestedAA:I D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeRequested32bitDisplayBuffer:Z D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeRender:Z D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeRecreateGfxState:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativePause:Z D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeInjectEvent:ZL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeInitWWW:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeFocusChanged:VZ D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeFile:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeDone:V D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeActivityIndicatorStyle:I D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.initJni:VL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.UnitySendMessage:VLLL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetLocationStatus:VI D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeSetLocation:VFFFFDF D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeForwardEventsToDalvik:VZ D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/UnityPlayer;.nativeDeviceOrientation:VI D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodUnblockStreaming:I D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodProcess:IL D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodInitJni:I D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodGetInfo:II D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodBlockStreaming:I D/dalvikvm( 3407): Unregistering JNI method Lorg/fmod/FMODAudioDevice;.fmodProcessMicData:ILI D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/ReflectionHelper;.nativeProxyInvoke:LILL D/dalvikvm( 3407): Unregistering JNI method Lcom/unity3d/player/ReflectionHelper;.nativeProxyFinalize:VI I/Process ( 3407): Sending signal. PID: 3407 SIG: 9 I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 3407) has died. I/WindowManager( 1397): WIN DEATH: Window{4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{40623da0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/dalvikvm( 1397): GC_CONCURRENT freed 1254K, 53% free 5214K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1306K, 53% free 5217K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1293K, 53% free 5235K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1333K, 53% free 5218K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1312K, 53% free 5217K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1293K, 53% free 5236K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1289K, 53% free 5252K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1354K, 53% free 5217K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1311K, 53% free 5217K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1322K, 53% free 5206K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1295K, 53% free 5213K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1282K, 53% free 5234K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1336K, 53% free 5210K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1340K, 53% free 5178K/10951K, external 2732K/3412K, paused 2ms+3ms D/dalvikvm( 1629): GC_EXPLICIT freed 5K, 53% free 3843K/8007K, external 3133K/3861K, paused 76ms V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging D/AndroidRuntime( 3540): D/AndroidRuntime( 3540): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<< D/AndroidRuntime( 3540): CheckJNI is OFF D/dalvikvm( 3540): creating instr width table D/dalvikvm( 3540): No JNI_OnLoad found in /system/lib/ libidme.so 0x0, skipping init D/AndroidRuntime( 3540): Calling main entry com.android.commands.pm.Pm D/dalvikvm( 2744): GC_CONCURRENT freed 339K, 50% free 2902K/5703K, external 847K/1181K, paused 2ms+2ms D/dalvikvm( 2744): GC_EXPLICIT freed 26K, 50% free 2875K/5703K, external 847K/1181K, paused 24ms W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I//system/bin/newfs_msdos( 1286): /system/bin/newfs_msdos: warning, /dev/block/dm-0 is not a character device I//system/bin/newfs_msdos( 1286): /system/bin/newfs_msdos: Skipping mount checks I//system/bin/newfs_msdos( 1286): Bogus heads from kernel - setting sane value I//system/bin/newfs_msdos( 1286): Bogus sectors from kernel - setting sane value I//system/bin/newfs_msdos( 1286): /dev/block/dm-0: 56048 sectors in 7006 FAT32 clusters (4096 bytes/cluster) I//system/bin/newfs_msdos( 1286): bps=512 spc=8 res=32 nft=2 sec=56196 mid=0xf0 spt=63 hds=64 hid=0 bspf=55 rdcl=2 infs=1 bkbs=2 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 D/dalvikvm( 1397): GC_CONCURRENT freed 1188K, 52% free 5260K/10951K, external 2732K/3412K, paused 7ms+11ms D/dalvikvm( 1397): GC_CONCURRENT freed 1235K, 53% free 5227K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1315K, 53% free 5226K/10951K, external 2732K/3412K, paused 4ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1263K, 52% free 5276K/10951K, external 2732K/3412K, paused 3ms+5ms D/dalvikvm( 1397): GC_CONCURRENT freed 1376K, 53% free 5226K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1263K, 52% free 5276K/10951K, external 2732K/3412K, paused 3ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1379K, 53% free 5220K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1225K, 53% free 5226K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1310K, 53% free 5226K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1313K, 53% free 5225K/10951K, external 2732K/3412K, paused 4ms+6ms D/dalvikvm( 1397): GC_CONCURRENT freed 1259K, 52% free 5280K/10951K, external 2732K/3412K, paused 4ms+3ms D/dalvikvm( 1397): GC_CONCURRENT freed 1365K, 53% free 5239K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1333K, 53% free 5218K/10951K, external 2732K/3412K, paused 3ms+4ms D/dalvikvm( 1397): GC_CONCURRENT freed 1295K, 53% free 5227K/10951K, external 2732K/3412K, paused 3ms+4ms D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/dalvikvm( 2744): GC_EXPLICIT freed 148K, 52% free 2786K/5703K, external 847K/1181K, paused 24ms D/dalvikvm( 1397): GC_EXPLICIT freed 1073K, 53% free 5167K/10951K, external 2732K/3412K, paused 48ms D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/PackageParser( 1397): Scanning package: /mnt/asec/smdl2tmp1/pkg.apk D/VoldCmdListener( 1286): asec path smdl2tmp1 D/dalvikvm( 1397): GC_CONCURRENT freed 1021K, 52% free 5322K/10951K, external 2732K/3412K, paused 2ms+4ms D/dalvikvm( 1397): GC_EXPLICIT freed 39K, 52% free 5285K/10951K, external 2732K/3412K, paused 48ms D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-1 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-1 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-1 {} 1000 I/PackageManager( 1397): Succesfully renamed cid to com.ReignStudios.ReignUnityPlugin-1 at new path: /mnt/asec/com.ReignStudios.ReignUnityPlugin-1 I/PackageManager( 1397): Removing non-system package:com.ReignStudios.ReignUnityPlugin D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-1 I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 D/PackageManager( 1397): Scanning package com.ReignStudios.ReignUnityPlugin D/installd( 1292): DexInv: --- BEGIN '/mnt/asec/com.ReignStudios.ReignUnityPlugin-1/pkg.apk' --- I/PackageManager( 1397): Package com.ReignStudios.ReignUnityPlugin codePath changed; Retaining data and using new I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin D/dalvikvm( 3591): creating instr width table D/dalvikvm( 3591): Note: class Lcom/google/android/gms/games/internal/IGamesService$Stub; has 151 unimplemented (abstract) methods D/dalvikvm( 3591): DexOpt: couldn't find field Landroid/content/res/Configuration;.smallestScreenWidthDp D/dalvikvm( 3591): DexOpt: load 163ms, verify+opt 2044ms D/installd( 1292): DexInv: --- END '/mnt/asec/com.ReignStudios.ReignUnityPlugin-1/pkg.apk' (success) --- D/PackageManager( 1397): Receivers: com.amazon.inapp.purchasing.ResponseReceiver com.amazon.identity.auth.device.authorization.PackageIntentReceiver D/PackageManager( 1397): Activities: com.reignstudios.reignnative.ReignUnityActivity com.amazon.device.ads.AdActivity com.google.android.gms.ads.AdActivity com.amazon.ags.html5.overlay.GameCircleUserInterface com.amazon.ags.html5.overlay.GameCircleAlertUserInterface com.amazon.identity.auth.device.authorization.AuthorizationActivity I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Code path for pkg : com.ReignStudios.ReignUnityPlugin changed. W/PackageManager( 1397): Resource path for pkg : com.ReignStudios.ReignUnityPlugin changed. I/installd( 1292): move /data/dalvik-cache/mnt@asec@com.ReignStudios.ReignUnityPlugin-1@pkg.apk@classes.dex -> /data/dalvik-cache/mnt@asec@com.ReignStudios.ReignUnityPlugin-1@pkg.apk@classes.dex D/PackageManager( 1397): New package installed in /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/pkg.apk W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/RecognitionManagerService( 1397): no available voice recognition services found D/szipinf ( 1397): Initializing inflate state D/dalvikvm( 1397): GC_EXPLICIT freed 638K, 53% free 5206K/10951K, external 2732K/3412K, paused 51ms D/dalvikvm( 1397): GC_EXPLICIT freed 12K, 53% free 5194K/10951K, external 2732K/3412K, paused 46ms D/VoldCmdListener( 1286): asec unmount com.ReignStudios.ReignUnityPlugin-2 force I/installd( 1292): unlink /data/dalvik-cache/mnt@asec@com.ReignStudios.ReignUnityPlugin-2@pkg.apk@classes.dex D/dalvikvm( 1397): GC_EXPLICIT freed 93K, 53% free 5187K/10951K, external 2732K/3412K, paused 52ms D/VoldCmdListener( 1286): asec destroy com.ReignStudios.ReignUnityPlugin-2 force D/szipinf ( 1397): Initializing inflate state D/AndroidRuntime( 3540): Shutting down VM I/AndroidRuntime( 3540): NOTE: attach of thread 'Binder Thread #3' failed D/dalvikvm( 3540): GC_CONCURRENT freed 103K, 71% free 300K/1024K, external 0K/0K, paused 0ms+0ms D/jdwp ( 3540): adbd disconnected W/ResourceType( 1397): Failure getting entry for 0x7f0b0384 (t=10 e=900) in package 0 (error -75) W/ResourceType( 1397): Failure getting entry for 0x7f0b0385 (t=10 e=901) in package 0 (error -75) W/ResourceType( 1397): Failure getting entry for 0x7f0b0383 (t=10 e=899) in package 0 (error -75) D/szipinf ( 1397): Initializing inflate state D/szipinf ( 1397): Initializing inflate state D/AndroidRuntime( 3610): D/AndroidRuntime( 3610): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<< D/AndroidRuntime( 3610): CheckJNI is OFF D/dalvikvm( 3610): creating instr width table D/dalvikvm( 3610): No JNI_OnLoad found in /system/lib/ libidme.so 0x0, skipping init D/AndroidRuntime( 3610): Calling main entry com.android.commands.am.Am D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 3610 D/AndroidRuntime( 3610): Shutting down VM I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3618 uid=10023 gids={3003, 1015} D/dalvikvm( 3610): GC_CONCURRENT freed 105K, 69% free 325K/1024K, external 0K/0K, paused 1ms+1ms D/jdwp ( 3610): adbd disconnected I/AndroidRuntime( 3610): NOTE: attach of thread 'Binder Thread #3' failed I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window D/dalvikvm( 3618): Trying to load lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libmain.so 0x40512b10 D/dalvikvm( 3618): Added shared lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libmain.so 0x40512b10 D/ReignUnityActivity( 3618): onCreate called! D/Reign ( 3618): onStart called! D/Reign ( 3618): onResume called! I/ActivityManager( 1397): Displayed com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: +1s236ms I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/libEGL ( 3618): loaded /system/lib/egl/ libGLES_android.so D/libEGL ( 3618): loaded /vendor/lib/egl/ libEGL_POWERVR_SGX540_120.so D/libEGL ( 3618): loaded /vendor/lib/egl/ libGLESv1_CM_POWERVR_SGX540_120.so D/libEGL ( 3618): loaded /vendor/lib/egl/ libGLESv2_POWERVR_SGX540_120.so D/Unity ( 3618): GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_vertex_half_float GL_OES_texture_float GL_OES_texture_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_fragment_precision_high GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_required_internalformat GL_OES_depth_texture GL_OES_get_program_binary GL_OES_packed_depth_stencil GL_OES_standard_derivatives GL_OES_vertex_array_object GL_OES_egl_sync GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_EXT_discard_framebuffer GL_EXT_shader_texture_lod GL_IMG_shader_binary GL_IMG_texture_compression_pvrtc GL_IMG_texture_stream2 GL_IMG_texture_npot GL_IMG_texture_format_BGRA8888 GL_IMG_read_format GL_IMG_program_binary GL_IMG_multisampled_render_to_texture D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... I/Omap4ALSA( 1290): Using ping-pong! I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 116 msecs I/dalvikvm( 3618): Failed resolving Lcom/amazon/ags/client/LifecycleCallbacks; interface 15 'Landroid/app/Application$ActivityLifecycleCallbacks;' W/dalvikvm( 3618): Link of class 'Lcom/amazon/ags/client/LifecycleCallbacks;' failed E/dalvikvm( 3618): Could not find class 'com.amazon.ags.client.LifecycleCallbacks', referenced from method com.amazon.ags.api.AmazonGamesClient.initialize_internal W/dalvikvm( 3618): VFY: unable to resolve new-instance 339 (Lcom/amazon/ags/client/LifecycleCallbacks;) in Lcom/amazon/ags/api/AmazonGamesClient; D/dalvikvm( 3618): VFY: replacing opcode 0x22 at 0x0078 D/dalvikvm( 3618): VFY: dead code 0x007a-0080 in Lcom/amazon/ags/api/AmazonGamesClient;.initialize_internal (Lcom/amazon/ags/api/AmazonGamesCallback;Landroid/app/Activity;ZLcom/amazon/ags/storage/StringObfuscator;Ljava/util/EnumSet;)V W/dalvikvm( 3618): No implementation found for native Lcom/amazon/ags/jni/AGSJniHandler;.isLoaded ()V I/AGSJniHandler( 3618): AmazonGamesJni is not loaded, trying to load library D/dalvikvm( 3618): Trying to load lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libAmazonGamesJni.so 0x40512b10 D/dalvikvm( 3618): Added shared lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libAmazonGamesJni.so 0x40512b10 D/AGSJni ( 3618): JNI_OnLoad called D/AGSLeaderboardJni( 3618): JNI_OnLoad called D/LeaderboardToJavaInterface( 3618): initializeClient - called D/LeaderboardToJavaInterface( 3618): initializeMethodIDs - called D/LeaderboardToJavaInterface( 3618): initializeMethodIDs - initialized D/AGSAchievementJni( 3618): JNI_OnLoad called D/AchievementToJavaInterface( 3618): initializeClient - called D/AchievementToJavaInterface( 3618): initializeMethodIDs - called D/AchievementToJavaInterface( 3618): initializeMethodIDs - initialized D/AGSProfileJni( 3618): JNI_OnLoad called D/ProfileToJavaInterface( 3618): initializeClient - called D/ProfileToJavaInterface( 3618): initializeMethodIDs - called D/ProfileToJavaInterface( 3618): initializeMethodIDs - initialized D/GC_Whispersync( 3618): JNI_OnLoad called D/GC_Whispersync( 3618): initializeMethodIDs - called D/GameCircleToJavaInterface( 3618): initializeClient - called D/GameCircleToJavaInterface( 3618): initializeMethodIDs - called D/GameCircleToJavaInterface( 3618): initializeMethodIDs - initialized D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3618): Extracting verison incremental: D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3618): Extracting flavor: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/GameCircleClient( 3618): AmazonGamesClient not yet initialized. Initializing. D/dalvikvm( 3618): GC_CONCURRENT freed 523K, 50% free 3032K/5959K, external 849K/1181K, paused 2ms+3ms D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array V/AmazonInsightsSDK( 3618): Firing Session Event: _session.start I/AmazonInsightsSDK( 3618): Amazon Insights SDK(2.1.16.0) initialization successfully completed I/AmazonInsightsSDK( 3618): Event: '_sess...' recorded to local filestore I/dalvikvm( 3618): Total arena pages for JIT: 11 D/GC_Whispersync( 3618): Initial load from disk started V/GC_Whispersync( 3618): Retrieved JSON string [{"gameData":{}}] of game data map from disk D/GameCircleClient( 3618): initialize_internal() executing on thread:pool-2-thread-1 W/GC_Whispersync( 3618): GameDataMap - Unable to merge from an invalid/unset GameDataMap com.amazon.ags.client.whispersync.GameDataSingleMap@4059fe00 D/GC_Whispersync( 3618): Initial load from disk completed in 10 msec. I/AmazonInsightsSDK( 3618): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' I/AmazonInsightsSDK( 3618): Event: 'WHISP...' recorded to local filestore D/dalvikvm( 3618): GC_CONCURRENT freed 462K, 49% free 3080K/5959K, external 849K/1181K, paused 3ms+3ms I/AmazonInsightsSDK( 3618): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache D/dalvikvm( 3618): GC_CONCURRENT freed 402K, 48% free 3177K/6023K, external 849K/1181K, paused 2ms+2ms D/dalvikvm( 3618): GC_CONCURRENT freed 416K, 47% free 3288K/6151K, external 849K/1181K, paused 1ms+2ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 307K, 47% free 3304K/6151K, external 849K/1181K, paused 22ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 39K, 46% free 3440K/6279K, external 849K/1181K, paused 22ms I/AmazonInsightsSDK( 3618): Resolved variation: 'Test' for project: 'Universal Experiment List' from server I/AmazonInsightsSDK( 3618): Attempting to retrieve variation(s) for project(s):'ManifestSrc','InitSigninAlertTest' I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3618): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache I/AmazonInsightsSDK( 3618): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3618): Successful submission of 16 events D/dalvikvm( 3618): GC_CONCURRENT freed 273K, 43% free 3662K/6407K, external 849K/1181K, paused 1ms+2ms I/AmazonInsightsSDK( 3618): Resolved variation: 'Control' for project: 'ManifestSrc' from server I/AmazonInsightsSDK( 3618): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: D/dalvikvm( 3618): GC_CONCURRENT freed 645K, 46% free 3667K/6727K, external 1016K/1181K, paused 2ms+3ms I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array D/KindleFireIPCProxy( 3618): Device appears to be a Kindle Fire. Attempting to connect to Amazon Game Services D/KindleFireIPCProxy( 3618): binding result:true V/KindleFireIPCProxy( 3618): synchronousBinder:null serviceMessengerClient:android.os.Messenger@40660c38 D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Device has compatible version of Amazon Game Services. D/KindleFireIPCProxy( 3618): Attempting to Authorize D/KindleFireIPCProxy( 3618): Handling authorize callback D/KindleFireIPCProxy( 3618): authResult: AUTHORIZED D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Attempting to check is authenticated D/KindleFireIPCProxy( 3618): Changing Status from:INITIALIZING to: SERVICE_CONNECTED D/dalvikvm( 3618): GC_CONCURRENT freed 535K, 44% free 3842K/6791K, external 1016K/1181K, paused 1ms+3ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 17473536, New space, used: 130776, Old pointers, used: 104504, Old data space, used: 51684, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 40960 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 32764, Old pointers, used: 152244, Old data space, used: 51692, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 86016 D/dalvikvm( 3618): GC_FOR_MALLOC freed 187K, 43% free 4008K/6983K, external 1016K/1181K, paused 22ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 131052, Old pointers, used: 172188, Old data space, used: 69024, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 86016 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 17670144, New space, used: 32764, Old pointers, used: 218920, Old data space, used: 86372, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 106496 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 131072, Old pointers, used: 302108, Old data space, used: 149052, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 65524, Old pointers, used: 315100, Old data space, used: 166120, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 262132, Old pointers, used: 330948, Old data space, used: 172972, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 65524, Old pointers, used: 429364, Old data space, used: 191220, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 262140, Old pointers, used: 471316, Old data space, used: 194712, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 19046400, New space, used: 131068, Old pointers, used: 538588, Old data space, used: 202864, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 19251200, New space, used: 523952, Old pointers, used: 563716, Old data space, used: 228988, Code space, used: 837024, Map space, used: 115744, Cell space, used: 8120, Large object space, used: 376832 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 19247104, New space, used: 0, Old pointers, used: 593080, Old data space, used: 220160, Code space, used: 661888, Map space, used: 64928, Cell space, used: 7608, Large object space, used: 372736 D/dalvikvm( 3618): GC_FOR_MALLOC freed 394K, 43% free 4138K/7239K, external 1016K/1181K, paused 24ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 20533248, New space, used: 523136, Old pointers, used: 859468, Old data space, used: 519484, Code space, used: 1150144, Map space, used: 93184, Cell space, used: 16736, Large object space, used: 479232 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 20795392, New space, used: 131064, Old pointers, used: 1006256, Old data space, used: 525016, Code space, used: 1150144, Map space, used: 93184, Cell space, used: 16736, Large object space, used: 479232 D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-5] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-5] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-6] for call type [isKindleRegistered] D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Attempting to check is authenticated D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-6] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-7] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-7] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-8] for call type [hasOptedIn] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":false}] for request [backgroundwebview-8] D/GC_HttpNetworkClient( 3618): Request: GET https://ags-ext.amazon.com/services/featuredetection/getFeaturesUsage?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21008384, New space, used: 524288, Old pointers, used: 1018712, Old data space, used: 535412, Code space, used: 1306848, Map space, used: 101728, Cell space, used: 16880, Large object space, used: 561152 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 21098496, New space, used: 0, Old pointers, used: 1147660, Old data space, used: 529632, Code space, used: 1139296, Map space, used: 92224, Cell space, used: 16368, Large object space, used: 520192 D/GC_HttpNetworkClient( 3618): Request: PUT https://ags-ext.amazon.com/service/achievements/getAchievementsPublic D/dalvikvm( 3618): GC_CONCURRENT freed 855K, 45% free 4098K/7367K, external 1016K/1181K, paused 2ms+5ms D/GC_HttpNetworkClient( 3618): Request: PUT https://ags-ext.amazon.com/service/leaderboards/getLeaderboardsForGamePublic D/GC_HttpNetworkClient( 3618): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3618): GC_FOR_MALLOC freed 482K, 46% free 3984K/7367K, external 1016K/1181K, paused 29ms I/dalvikvm-heap( 3618): Grow heap (frag case) to 7.324MB for 87396-byte allocation D/dalvikvm( 3618): GC_FOR_MALLOC freed 40K, 47% free 4029K/7495K, external 1016K/1181K, paused 22ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 75K, 44% free 4254K/7495K, external 1016K/1181K, paused 22ms I/dalvikvm-heap( 3618): Grow heap (frag case) to 7.587MB for 87396-byte allocation D/dalvikvm( 3618): GC_FOR_MALLOC freed 8K, 44% free 4331K/7623K, external 1016K/1181K, paused 24ms D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/dalvikvm( 3618): GC_FOR_MALLOC freed 712K, 42% free 4465K/7623K, external 1016K/1181K, paused 29ms D/dalvikvm( 3618): GC_CONCURRENT freed 65K, 41% free 4579K/7751K, external 1016K/1181K, paused 2ms+4ms D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AGSJniHandler( 3618): Initializing Native Handlers I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_Whispersync( 3618): Starting write to file system I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore V/GC_Whispersync( 3618): GameDataMap - Deep copy of GameDataMap with name: null V/GC_Whispersync( 3618): GameDataMap copy took 1 msec. V/GC_Whispersync( 3618): Writing game data to disk: [{"gameData":{}}] D/GC_Whispersync( 3618): Completed write of 25 bytes to file system D/GC_Whispersync( 3618): posting event: DISK_WRITE_COMPLETE D/GC_Whispersync( 3618): Never synced from cloud. Attempting initial download and merge. D/GC_Whispersync( 3618): Checking whether Whispersync is enabled I/KindleFireSoftkeyBeachballManager( 3618): Failed to enable softkey button: java.lang.ClassNotFoundException: com.amazon.ags.app.util.SoftkeyBarWrapper I/AmazonInsightsSDK( 3618): Session Resume Failed: Session is already running. D/GC_ClickableToastImpl( 3618): Entering addToWindow... I/AmazonInsightsSDK( 3618): Event: 'PageV...' recorded to local filestore D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-35] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-35] E/GC_PlayerClientImpl( 3618): Request player failure response: {"REQUEST_ID":"ad5dbfd9-e0ea-4278-8612-fef6fa445b07","RESPONSE_CODE":"6"} I/Reign_Amazon_GameCircle( 3618): GameCircleGetPlayerAlias ERROR: AUTHENTICATION_ERROR I/Unity ( 3618): Authenticated: False I/Unity ( 3618): I/Unity ( 3618): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) I/Unity ( 3618): E/Unity ( 3618): AUTHENTICATION_ERROR E/Unity ( 3618): E/Unity ( 3618): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) E/Unity ( 3618): D/dalvikvm( 3618): GC_CONCURRENT freed 666K, 40% free 4836K/7943K, external 1016K/1181K, paused 2ms+3ms D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-39] for call type [isWhispersyncEnabled] D/KindleFireIPCProxy( 3618): Checking isWhispersyncEnabled: true D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-39] D/GC_Whispersync( 3618): Whispersync is DISABLED D/GC_Whispersync( 3618): Cannot sync with cloud because Whispersync is disabled D/GC_Whispersync( 3618): posting event: DISABLED D/GC_ClickableToastImpl( 3618): Entering runnable for hide() I/InputQueue-JNI( 3618): Sending finished signal for input channel '407e8a98 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' since it is being unregistered while an input message is still in progress. I/InputQueue-JNI( 3618): Ignoring finish signal on channel that is no longer registered. D/KindleFireIPCProxy( 3618): Checking isOverlaysSupported: false D/PhoneWindow( 3618): couldn't save which view has focus because the focused view android.view.SurfaceView@405304e8 has no id. D/ActivityManager( 1397): Starting: Intent { act=1403634582514 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3618 D/Reign ( 3618): onPause called! I/AmazonInsightsSDK( 3618): Event: 'Objec...' recorded to local filestore W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{4055e5b8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21868544, New space, used: 739864, Old pointers, used: 1180128, Old data space, used: 550784, Code space, used: 1490976, Map space, used: 103872, Cell space, used: 16384, Large object space, used: 1028096 D/GC_GameCircleUserInterface( 3618): View size set to width: 512 height: 480 I/ActivityManager( 1397): Displayed com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface: +220ms E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 20983808, New space, used: 0, Old pointers, used: 1149508, Old data space, used: 540476, Code space, used: 1231744, Map space, used: 95872, Cell space, used: 16384, Large object space, used: 536576 D/dalvikvm( 3618): GC_CONCURRENT freed 648K, 37% free 5265K/8327K, external 1064K/1181K, paused 16ms+4ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21950464, New space, used: 1047780, Old pointers, used: 1315796, Old data space, used: 683856, Code space, used: 1777408, Map space, used: 182464, Cell space, used: 20440, Large object space, used: 585728 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 22343680, New space, used: 262132, Old pointers, used: 1605288, Old data space, used: 753848, Code space, used: 1777408, Map space, used: 182464, Cell space, used: 20440, Large object space, used: 585728 E/GC_WebViewFactory( 3618): JS(line 2): refreshScrollBounds called without first calling scrollify:9 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 23785472, New space, used: 1048568, Old pointers, used: 1772320, Old data space, used: 917108, Code space, used: 2471008, Map space, used: 218624, Cell space, used: 22072, Large object space, used: 978944 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 23982080, New space, used: 0, Old pointers, used: 2022444, Old data space, used: 896344, Code space, used: 2145728, Map space, used: 169280, Cell space, used: 21816, Large object space, used: 913408 E/GC_WebViewFactory( 3618): JS(line 5): Uncaught TypeError: Cannot read property 'style' of null D/Reign ( 3618): onResume called! I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3618): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory W/GC_AsynchronousReplyMessenger( 3618): No pending message found for message id 048c73a8-a869-48cc-9eeb-be617dc5e6e4 I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: E/Omap4ALSA( 1290): called drain&close I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3618): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: D/com.amazon.identity.auth.device.datastore.DatabaseHelper.PII( 3618): DatabaseHelper created: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3618): GetToken: D/GC_NativeAuthCallHandler( 3618): Logged in: true I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getToken : scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin E/com.amazon.identity.auth.device.thread.MAPCallbackFuture( 3618): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory D/dalvikvm( 3618): GetMethodID: method not found: Landroid/view/Display;.getRawWidth:()I I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/Omap4ALSA( 1290): Using ping-pong! I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3618): GetToken pkg=com.ReignStudios.ReignUnityPlugin scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Vending out token: appId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf, scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Try finding a common access token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Common access token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII( 3618): Common refresh token found.: I/com.amazon.identity.auth.device.endpoint.TokenVendor( 3618): Common token still has acceptable life, returning it back to caller D/com.amazon.identity.auth.device.authorization.TokenHelper.PII( 3618): GetToken: D/GC_NativeAuthCallHandler( 3618): Logged in: true I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 158 msecs D/dalvikvm( 3618): GC_CONCURRENT freed 1279K, 42% free 5206K/8903K, external 1064K/1181K, paused 6ms+3ms D/GC_HttpNetworkClient( 3618): Request: GET https://cortana-gateway.amazon.com/cortana/gateway/profile/isplayercountrysupported?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK( 3618): Event: 'Accep...' recorded to local filestore D/GC_HttpNetworkClient( 3618): Request: POST https://cortana-gateway.amazon.com/cortana/gateway/profile/update?termsofservice=true&GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore E/GC_NetworkCallFactory( 3618): Unable to get nativeCall from request {"rid":67,"parameters":{"undefined":false}} E/GC_NetworkCallFactory( 3618): org.json.JSONException: No value for nativeCall E/GC_NetworkCallFactory( 3618): at org.json.JSONObject.get(JSONObject.java:354) E/GC_NetworkCallFactory( 3618): at org.json.JSONObject.getString(JSONObject.java:510) E/GC_NetworkCallFactory( 3618): at com.amazon.ags.html5.javascript.CallHandlerBase.handleMessage(CallHandlerBase.java:53) E/GC_NetworkCallFactory( 3618): at com.amazon.ags.html5.javascript.domain.JavascriptInterface$8.run(JavascriptInterface.java:235) E/GC_NetworkCallFactory( 3618): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088) E/GC_NetworkCallFactory( 3618): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581) E/GC_NetworkCallFactory( 3618): at java.lang.Thread.run(Thread.java:1019) E/GC_NetworkCallFactory( 3618): No receiver for reply associated with rid: 67 D/GC_HttpNetworkClient( 3618): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3618): GC_CONCURRENT freed 1041K, 41% free 5271K/8903K, external 1064K/1181K, paused 2ms+3ms D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore W/GC_AsynchronousReplyMessenger( 3618): Request ff00a973-fecd-4eb9-b83b-bd368c725646 timed out. ^C Andrew-Wittes-Mac-mini:~ Andrew$ clear Andrew-Wittes-Mac-mini:~ Andrew$ /Users/Andrew/SDKs/adt-bundle-mac-x86_64-20130911/sdk/platform-tools/adb logcat --------- beginning of /dev/log/system W/Vold ( 1286): Ignoring unknown switch 'usb_connected' D/Vold ( 1286): USB connected D/Vold ( 1286): Share method ums now available W/Vold ( 1286): Ignoring unknown switch 'usb_mass_storage' I/StorageNotification( 1551): UMS connection changed to true (media state mounted) I/StorageNotification( 1551): In onUsbMassStorageConnectionChangedAsync, POP_UMS_ACTIVITY_ON_CONNECT=true D/StatusBarService( 1551): Notification has fullScreenIntent; sending fullScreenIntent D/ActivityManager( 1397): Starting: Intent { flg=0x10000000 cmp=com.android.systemui/.usb.UsbStorageActivity } from pid -1 I/ActivityManager( 1397): No longer want android.process.media (pid 1799): hidden #16 D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/VoldCmdListener( 1286): asec list I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window D/VoldCmdListener( 1286): storage users /mnt/sdcard D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/ActivityManager( 1397): Killing processes unmount media at adjustment 2 W/ActivityManager( 1397): Killing ProcessRecord{4070e2a8 1931:com.audible.application.kindle/32017} (adj 2): unmount media W/ActivityManager( 1397): Killing ProcessRecord{40859810 2140:com.audible.application.kindle:remote/32017} (adj 2): unmount media D/VoldCmdListener( 1286): storage users /mnt/sdcard W/ActivityManager( 1397): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.media.AudioPlayerService in 5000ms D/VoldCmdListener( 1286): volume unmount /mnt/sdcard force D/Vold ( 1286): Volume sdcard state changing 4 (Mounted) -> 5 (Unmounting) I/ActivityManager( 1397): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=2407 uid=10017 gids={1015, 3003} I/ActivityManager( 1397): No longer want com.amazon.dcp:CheckForOTAUpdatesService (pid 2028): hidden #16 I/Vold ( 1286): /mnt/secure/staging/.android_secure sucessfully unmounted I/Vold ( 1286): /mnt/secure/asec sucessfully unmounted I/Vold ( 1286): /mnt/secure/staging sucessfully unmounted I/Vold ( 1286): /mnt/sdcard unmounted sucessfully D/Vold ( 1286): Volume sdcard state changing 5 (Unmounting) -> 1 (Idle-Unmounted) I/StorageNotification( 1551): Media state changed from {mounted} -> {unmounted} I/ActivityManager( 1397): Start proc com.amazon.dcp:UpdatesLookupService for broadcast com.amazon.dcp/.ota.UpdatesLookupService$MountStatusChangedReceiver: pid=2417 uid=32000 gids={2001, 3003, 1015, 1007, 1026} D/VoldCmdListener( 1286): volume share /mnt/sdcard ums D/Vold ( 1286): Volume sdcard state changing 1 (Idle-Unmounted) -> 7 (Shared-Unmounted) W/MountService( 1397): Duplicate state transition (unmounted -> unmounted) D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums I/StorageNotification( 1551): Media state changed from {unmounted} -> {shared} D/IconMerger( 1551): sum of notifications: 0 I/ActivityManager( 1397): No longer want com.alphonso.pulse (pid 2027): hidden #16 D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 D/VoldCmdListener( 1286): volume unshare /mnt/sdcard ums D/Vold ( 1286): Volume sdcard state changing 7 (Shared-Unmounted) -> 1 (Idle-Unmounted) I/StorageNotification( 1551): Media state changed from {shared} -> {unmounted} D/VoldCmdListener( 1286): volume mount /mnt/sdcard I/Vold ( 1286): /dev/block/vold/179:12 being considered for volume sdcard D/Vold ( 1286): Volume sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking) I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): Start proc com.audible.application.kindle:remote for service com.audible.application.kindle/com.audible.application.media.AudioPlayerService: pid=2431 uid=32017 gids={3003, 1015, 3002} I/Vold ( 1286): Filesystem check completed OK I/Vold ( 1286): Device /dev/block/vold/179:12, target /mnt/sdcard mounted @ /mnt/secure/staging D/Vold ( 1286): Volume sdcard state changing 3 (Checking) -> 4 (Mounted) D/VoldCmdListener( 1286): volume shared /mnt/sdcard ums D/VoldCmdListener( 1286): volume unshare /mnt/sdcard ums W/Vold ( 1286): Returning OperationFailed - no handler for errno 22 I/StorageNotification( 1551): Media state changed from {unmounted} -> {checking} E/MountService( 1397): Failed to share/unshare E/MountService( 1397): com.android.server.NativeDaemonConnectorException: Cmd {volume unshare /mnt/sdcard ums} failed with code 400 : {volume operation failed (Invalid argument)} E/MountService( 1397): at com.android.server.NativeDaemonConnector.doCommand(NativeDaemonConnector.java:259) E/MountService( 1397): at com.android.server.MountService.doShareUnshareVolume(MountService.java:508) E/MountService( 1397): at com.android.server.MountService.setUsbMassStorageEnabled(MountService.java:1231) E/MountService( 1397): at android.os.storage.IMountService$Stub.onTransact(IMountService.java:683) E/MountService( 1397): at android.os.Binder.execTransact(Binder.java:320) E/MountService( 1397): at dalvik.system.NativeStart.run(Native Method) D/VoldCmdListener( 1286): volume mount /mnt/sdcard E/MountService( 1397): Failed to remount /mnt/sdcard after disabling share method ums I/ActivityManager( 1397): Start proc android.process.media for broadcast com.android.providers.media/.MediaScannerReceiver: pid=2441 uid=10011 gids={1015, 2001, 3003} I/StorageNotification( 1551): Media state changed from {checking} -> {mounted} D/VoldCmdListener( 1286): asec list W/PackageManager( 1397): Unknown permission com.google.android.c2dm.permission.RECEIVE in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.dcp.sso.permission.USE_DEVICE_CREDENTIALS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.dcp.settings.permission.READ_SETTINGS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.amazon.kindle.dtcp.permission.DTCP_SERVICE_ACCESS in package com.imdb.mobile W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts W/PackageManager( 1397): Unknown permission android.permission.DEVICE_ADMIN in package com.lab126.otter W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar W/PackageManager( 1397): Unknown permission org.thialfihar.android.apg.permission.READ_KEY_DETAILS in package com.amazon.email W/PackageManager( 1397): Unknown permission com.amazon.kindle.cms.CMS_ACCESS in package com.amazon.avod W/PackageManager( 1397): Not granting permission com.amazon.dcp.metrics.permission.METRICS_PERMISSION to package com.cooliris.media (protectionLevel=2 flags=0x8bc45) W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings W/PackageManager( 1397): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings W/PackageManager( 1397): Unknown permission com.android.launcher.permission.INSTALL_SHORTCUT in package com.amazon.cloud9 W/PackageManager( 1397): Unknown permission android.webkit.permission.PLUGIN in package com.adobe.flashplayer W/PackageManager( 1397): Unknown permission com.google.android.providers.gmail.permission.WRITE_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.providers.gmail.permission.READ_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission android.permission.READ_OWNER_DATA in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.android.email.permission.ACCESS_PROVIDER in package com.qo.android.oemvc W/PackageManager( 1397): Unknown permission com.amzon.permission.CONFIG_SOFTKEYS in package com.lab126.parentalcontrols W/PackageManager( 1397): Not granting permission com.amazon.dcp.metrics.permission.METRICS_PERMISSION to package com.alphonso.pulse (protectionLevel=2 flags=0x8be45) D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 I/ActivityManager( 1397): No longer want com.lab126.parentalcontrols (pid 2101): hidden #16 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/ProcessStats( 1397): Skipping unknown process pid 2528 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): New temperature state Init, adjust charge current I/ChargeProtectionService( 1397): New full charge capacity, adjust charge current I/ChargeProtectionService( 1397): New charge current: 2683 mA V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/StorageNotification( 1551): LockScreen: OnReceive V/AlarmManager( 1397): alarms: 3 type: RTC_WAKEUP V/AlarmManager( 1397): 0: Jun 24 02:07:16 pm android V/AlarmManager( 1397): 1: Jun 24 04:49:03 pm com.amazon.venezia V/AlarmManager( 1397): 2: Jun 25 11:55:38 am com.android.providers.calendar I/ChargeProtectionService( 1397): New full charge capacity, adjust charge current I/ChargeProtectionService( 1397): New charge current: 2690 mA I/WakelockDebugService( 1397): Dumping PowerManager state I/WakelockDebugService( 1397): Power Manager State: I/WakelockDebugService( 1397): mIsPowered=true mPowerState=0 mScreenOffTime=5097 ms I/WakelockDebugService( 1397): mPartialCount=1 I/WakelockDebugService( 1397): mWakeLockState= I/WakelockDebugService( 1397): mUserState= I/WakelockDebugService( 1397): mPowerState= I/WakelockDebugService( 1397): mLocks.gather= I/WakelockDebugService( 1397): mNextTimeout=869510 now=874608 -5s from now I/WakelockDebugService( 1397): mDimScreen=true mStayOnConditions=0 I/WakelockDebugService( 1397): mScreenOffReason=3 mUserState=0 I/WakelockDebugService( 1397): mBroadcastQueue={-1,-1,-1} I/WakelockDebugService( 1397): mBroadcastWhy={0,0,0} I/WakelockDebugService( 1397): mPokey=0 mPokeAwakeonSet=false I/WakelockDebugService( 1397): mKeyboardVisible=false mUserActivityAllowed=true I/WakelockDebugService( 1397): mKeylightDelay=6000 mDimDelay=287000 mScreenOffDelay=7000 I/WakelockDebugService( 1397): mPreventScreenOn=false mScreenBrightnessOverride=-1 mButtonBrightnessOverride=-1 I/WakelockDebugService( 1397): mScreenOffTimeoutSetting=300000 mMaximumScreenOffTimeout=2147483647 I/WakelockDebugService( 1397): mLastScreenOnTime=0 I/WakelockDebugService( 1397): mBroadcastWakeLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mStayOnWhilePluggedInScreenDimLock=UnsynchronizedWakeLock(mFlags=0x6 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mStayOnWhilePluggedInPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mPreventScreenOnPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mProximityPartialLock=UnsynchronizedWakeLock(mFlags=0x1 mCount=0 mHeld=false) I/WakelockDebugService( 1397): mProximityWakeLockCount=0 I/WakelockDebugService( 1397): mProximitySensorEnabled=false I/WakelockDebugService( 1397): mProximitySensorActive=false I/WakelockDebugService( 1397): mProximityPendingValue=-1 I/WakelockDebugService( 1397): mLastProximityEventTime=0 I/WakelockDebugService( 1397): mLightSensorEnabled=false I/WakelockDebugService( 1397): mLightSensorValue=-1.0 mLightSensorPendingValue=-1.0 I/WakelockDebugService( 1397): mLightSensorScreenBrightness=-1 mLightSensorButtonBrightness=-1 mLightSensorKeyboardBrightness=-1 I/WakelockDebugService( 1397): mUseSoftwareAutoBrightness=true I/WakelockDebugService( 1397): mAutoBrightessEnabled=false I/WakelockDebugService( 1397): mScreenBrightness: animating=false targetValue=0 curValue=0.0 delta=-5.0 I/WakelockDebugService( 1397): mLocks.size=1: I/WakelockDebugService( 1397): PARTIAL_WAKE_LOCK 'show keyguard' activated (minState=0, uid=1000, pid=1397) I/WakelockDebugService( 1397): mPokeLocks.size=0: I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 I/ActivityManager( 1397): Start proc com.audible.application.kindle for broadcast com.audible.application.kindle/com.amazon.kindle.SyncBroadcastEventTracker: pid=2619 uid=32017 gids={3003, 1015, 3002} I/ActivityManager( 1397): No longer want com.android.providers.calendar (pid 1913): hidden #16 I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/StorageNotification( 1551): LockScreen: OnReceive W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4059e8f0 I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 0 D/WifiWatchdogService( 1397): (android.server.ServerThread) 00:00:00:00:14:74 does not require the watchdog I/ActivityManager( 1397): Start proc com.alphonso.pulse for broadcast com.alphonso.pulse/.background.OnTimeChangedReceiver: pid=2699 uid=10007 gids={3003, 1015} I/ConnectivityService( 1397): Sending INET_CONDITION_ACTION broadcast I/StatusBarPolicy( 1551): updateConnectivity: inetCondition = 1 W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found I/ActivityManager( 1397): No longer want com.amazon.cloud9 (pid 1726): hidden #16 W/ActivityManager( 1397): Unable to start service Intent { act=com.amazon.kindle.cms.CMS_CLIENT_CONNECT }: not found V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging I/ActivityManager( 1397): Start proc com.android.defcontainer for service com.android.defcontainer/.DefaultContainerService: pid=2744 uid=10019 gids={1015, 2001} W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: I/ActivityManager( 1397): No longer want com.amazon.kindle.otter.oobe (pid 1679): hidden #16 D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-1 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-1 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-1 {} 1000 D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-1 I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Start proc com.svox.pico for broadcast com.svox.pico/.VoiceDataInstallerReceiver: pid=2803 uid=10009 gids={} W/RecognitionManagerService( 1397): no available voice recognition services found I/ActivityManager( 1397): Start proc com.android.quicksearchbox for broadcast com.android.quicksearchbox/.CorporaUpdateReceiver: pid=2815 uid=10006 gids={3003} I/ActivityManager( 1397): No longer want com.amazon.otter.tutorial (pid 2127): hidden #16 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 2827 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=2836 uid=10023 gids={3003, 1015} I/WindowManager( 1397): Setting rotation to 1, animFlags=1 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435491 uiMode=17 seq=4} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): Start proc com.amazon.ags.app for service com.amazon.ags.app/.service.AmazonGamesService: pid=2877 uid=32019 gids={3003} W/ActivityManager( 1397): Unable to start service Intent { act=SetIdentity cmp=com.amazon.ags.app/com.amazon.insights.InsightsProcessingService (has extras) }: not found W/ActivityManager( 1397): Unable to start service Intent { act=PutMeasurement cmp=com.amazon.ags.app/com.amazon.insights.InsightsProcessingService (has extras) }: not found V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ActivityManager( 1397): No longer want com.lab126.otter (pid 2256): hidden #16 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{40780ee0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} W/ProcessStats( 1397): Skipping unknown process pid 2908 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@405f5150 (uid=10023 pid=2836) I/ActivityManager( 1397): No longer want com.amazon.kindle.otter.settings (pid 2368): hidden #16 I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 2836) has died. I/WindowManager( 1397): WIN DEATH: Window{405fd838 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{40780ee0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=2916 uid=10023 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/ActivityManager( 1397): Starting: Intent { act=1403633454148 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 2916 W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW dat= https://www.amazon.com/ap/oa?response_type=code&redirect_uri=amzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin&client_id=amzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1&amzn_respectRmrMeAuthState=1&amzn_showRmrMe=1&amzn_rmrMeDefaultSelected=1&state=clientId%3Damzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1%26redirectUri%3Damzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin%26clientRequestId%3D2fad4a39-1a1c-4746-910f-9e3bc25ba3e1&scope=game_circle%3Agame_data flg=0x40000000 cmp=com.amazon.cloud9/.BrowserActivity } from pid 2916 I/ActivityManager( 1397): Start proc com.amazon.cloud9 for activity com.amazon.cloud9/.BrowserActivity: pid=2974 uid=32015 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40a2a038 (uid=32015 pid=2974) W/InputManagerService( 1397): Client not active, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4086a1c0 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat= https://www.amazon.com/ap/signin?_encoding=UTF8&openid.assoc_handle=iba&openid.return_to=https%3A%2F%2Fwww.amazon.com%2Fap%2Foa%3Farb%3D7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.mode=checkid_setup&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.pape.max_auth_age=0&ie=UTF8&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&arb=7fd7ae84-be3b-45b6-8015-cabff21ae869&marketPlaceId=ATVPDKIKX0DER&showRmrMe=1&rmrMeDefaultSelected=1&language=en_US&metricIdentifier=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&signedMetricIdentifier=GOYAC9XVBt48AXcEyoRI1WkxK6riiKwjUBYx08UXDnY%3D cmp=com.amazon.cloud9/.BrowserActivity } from pid 2974 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat= https://www.amazon.com/ap/oa?arb=7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.assoc_handle=iba&aToken=5%7Cm3TMf5jrCeBJ%2F5ws2PM3HNHxiPKx6hSftv7Fb4tEOyWjUR4Fj4X17TYqG1fAcWBk9ug%2FMLsipfKbz8KdRRKn8v0ip%2B%2B957LYaj47Ipyj7EygcPh3k0T3SSqGAeHQXpy1xgtiQ7ZyzzdywbYmPlxkU1uBoFD1SfaxmKYb5UgIIPADZHv75KiAqwVbPhboxdk65f4C6lgSE5e22ApvRlWUbymxkQ2ic64M&openid.claimed_id=https%3A%2F%2Fwww.amazon.com%2Fap%2Fid%2Famzn1.account.AHD3MEARB4N6TNEP27BAFY2WVKXA&openid.identity=https%3A%2F%2Fwww.amazon.com%2Fap%2Fid%2Famzn1.account.AHD3MEARB4N6TNEP27BAFY2WVKXA&openid.mode=id_res&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0&openid.op_endpoint=https%3A%2F%2Fwww.amazon.com%2Fap%2Fsignin&openid.response_nonce=2014-06-24T18%3A11%3A49Z-3555954533292340006&openid.return_to=https%3A%2F%2Fwww.amazon.com%2Fap%2Foa%3Farb%3D7fd7ae84-be3b-45b6-8015-cabff21ae869&openid.signed=assoc_handle%2CaToken%2Cclaimed_id%2Cidentity%2Cmode%2Cns%2Cop_endpoint%2Cresponse_nonce%2Creturn_to%2Cns.pape%2Cpape.auth_policies%2Cpape.auth_time%2Csigned&openid.ns.pape=http%3A%2F%2Fspecs.openid.net%2Fextensions%2Fpape%2F1.0&openid.pape.auth_policies=http%3A%2F%2Fschemas.openid.net%2Fpape%2Fpolicies%2F2007%2F06%2Fnone&openid.pape.auth_time=2014-06-24T18%3A11%3A49Z&openid.sig=cVD8b1bZjjKRq53GZFpMoNRtIQplONCWxigOKfLqiig%3D&serial=&; cmp=com.amazon.cloud9/.BrowserActivity } from pid 2974 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.VIEW cat=[android.intent.category.BROWSABLE] dat=amzn://com.ReignStudios.ReignUnityPlugin?code=ANayHDrLetWQwiLggxrW&scope=game_circle%3Agame_data&state=clientId%3Damzn1.application-oa2-client.7dcc575858a94daa96ce42467d3814d1%26redirectUri%3Damzn%3A%2F%2Fcom.ReignStudios.ReignUnityPlugin%26clientRequestId%3D2fad4a39-1a1c-4746-910f-9e3bc25ba3e1 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.identity.auth.device.authorization.AuthorizationActivity } from pid 2974 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/InputManagerService( 1397): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@40a2a038 (uid=32015 pid=2974) I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4095e840 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): No longer want com.amazon.dcp:UpdatesLookupService (pid 2417): hidden #16 D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/WindowManager( 1397): WINDOW DIED Window{407062c0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 2916) has died. I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/InputManagerService( 1397): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40849630 W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{405672c8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 pkg=com.ReignStudios.ReignUnityPlugin cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 1616 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3100 uid=10023 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=1403633561537 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3100 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging W/ProcessStats( 1397): Skipping unknown process pid 3175 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/WindowManager( 1397): Setting rotation to 0, animFlags=0 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=1 layout=268435491 uiMode=17 seq=5} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 D/LAB126 ( 1551): launch settings from tap in the status bar, settings icon left = 506 D/ActivityManager( 1397): Starting: Intent { act=com.lab126.otter.launcher flg=0x10000000 cmp=com.lab126.otter/.MainScreen } from pid 1551 I/ActivityManager( 1397): Start proc com.lab126.otter for activity com.lab126.otter/.MainScreen: pid=3218 uid=1000 gids={3003} I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.SETTINGS flg=0x10200000 cmp=com.android.settings/.Settings } from pid 3218 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.PrivacySettings } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.ManageApplications } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.settings.APPLICATION_DETAILS_SETTINGS dat=package:com.amazon.ags.app cmp=com.android.settings/.applications.InstalledAppDetails } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed W/ProcessStats( 1397): Skipping unknown process pid 3234 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.PrivacySettings } from pid 1629 I/LAB126 ( 1551): StatusBarService hears softkey intent. action: com.lab126.intent.ACTION_CONFIG_SOFTKEYS I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ChargeProtectionService( 1397): Battery discharging, resuming charging V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): collapse softkeys D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.amazon.kindle.otter/.Launcher } from pid 1397 I/ActivityManager( 1397): No longer want com.cooliris.media (pid 2407): hidden #16 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 W/ProcessStats( 1397): Skipping unknown process pid 3353 D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-2 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-2 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-2 {} 1000 D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-2 I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 I/ActivityManager( 1397): Force finishing activity HistoryRecord{406186d0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} I/WindowManager( 1397): WIN DEATH: Window{407184b0 SurfaceView paused=false} I/WindowManager( 1397): WIN DEATH: Window{40580880 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=true} I/PackageManager( 1397): Package com.ReignStudios.ReignUnityPlugin codePath changed; Retaining data and using new I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin I/ChargeProtectionService( 1397): Battery discharging, resuming charging W/PackageManager( 1397): Code path for pkg : com.ReignStudios.ReignUnityPlugin changed. I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Resource path for pkg : com.ReignStudios.ReignUnityPlugin changed. W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/RecognitionManagerService( 1397): no available voice recognition services found D/VoldCmdListener( 1286): asec unmount com.ReignStudios.ReignUnityPlugin-1 force D/VoldCmdListener( 1286): asec destroy com.ReignStudios.ReignUnityPlugin-1 force D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 3397 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3407 uid=10023 gids={3003, 1015} I/WindowManager( 1397): Setting rotation to 1, animFlags=1 I/ActivityManager( 1397): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=1/1/2 nav=1/1 orien=2 layout=268435491 uiMode=17 seq=6} D/IconMerger( 1551): notification for com.android.systemui (1) D/IconMerger( 1551): sum of notifications: 1 I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed D/ActivityManager( 1397): Starting: Intent { act=1403634263839 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3407 W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{40623da0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 W/ProcessStats( 1397): Skipping unknown process pid 3473 W/ProcessStats( 1397): Skipping unknown process pid 3478 I/ActivityManager( 1397): No longer want com.amazon.windowshop (pid 2108): hidden #16 W/ActivityManager( 1397): Scheduling restart of crashed service com.amazon.windowshop/.account.SSOAccountListener$BackgroundAccountService in 5000ms I/ActivityManager( 1397): Start proc com.amazon.windowshop for service com.amazon.windowshop/.account.SSOAccountListener$BackgroundAccountService: pid=3480 uid=32002 gids={3003, 1015} V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 D/LAB126 ( 1551): expand softkeys D/LAB126 ( 1551): got back button softkey click! D/LAB126 ( 1551): collapse because of back button D/LAB126 ( 1551): collapse softkeys W/ActivityManager( 1397): Unable to start service Intent { act=appStartup }: not found I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/ActivityManager( 1397): No longer want android.process.media (pid 2441): hidden #16 I/ActivityManager( 1397): Process com.ReignStudios.ReignUnityPlugin (pid 3407) has died. I/WindowManager( 1397): WIN DEATH: Window{4055fdb0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity paused=false} W/ActivityManager( 1397): Activity destroy timeout for HistoryRecord{40623da0 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} V/DeviceStorageMonitorService( 1397): mTotalMemory is 11734999 I/ChargeProtectionService( 1397): Battery discharging, resuming charging W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec list D/VoldCmdListener( 1286): asec create smdl2tmp1 27 fat {} 10019 I/Vold ( 1286): Filesystem formatted OK D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec finalize smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force W/ActivityManager( 1397): No content provider found for: D/VoldCmdListener( 1286): asec mount smdl2tmp1 {} 1000 D/VoldCmdListener( 1286): asec path smdl2tmp1 D/VoldCmdListener( 1286): asec unmount smdl2tmp1 force D/VoldCmdListener( 1286): asec rename smdl2tmp1 com.ReignStudios.ReignUnityPlugin-1 W/PackageManager( 1397): Mounting container com.ReignStudios.ReignUnityPlugin-1 D/VoldCmdListener( 1286): asec mount com.ReignStudios.ReignUnityPlugin-1 {} 1000 D/VoldCmdListener( 1286): asec path com.ReignStudios.ReignUnityPlugin-1 I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 I/PackageManager( 1397): Package com.ReignStudios.ReignUnityPlugin codePath changed; Retaining data and using new I/PackageManager( 1397): Linking native library dir for package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/PackageManager( 1397): Code path for pkg : com.ReignStudios.ReignUnityPlugin changed. W/PackageManager( 1397): Resource path for pkg : com.ReignStudios.ReignUnityPlugin changed. W/PackageManager( 1397): Unknown permission com.android.vending.BILLING in package com.ReignStudios.ReignUnityPlugin I/ActivityManager( 1397): Force stopping package com.ReignStudios.ReignUnityPlugin uid=10023 W/RecognitionManagerService( 1397): no available voice recognition services found D/VoldCmdListener( 1286): asec unmount com.ReignStudios.ReignUnityPlugin-2 force D/VoldCmdListener( 1286): asec destroy com.ReignStudios.ReignUnityPlugin-2 force D/ActivityManager( 1397): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity } from pid 3610 I/ActivityManager( 1397): Start proc com.ReignStudios.ReignUnityPlugin for activity com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity: pid=3618 uid=10023 gids={3003, 1015} I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed I/LAB126 ( 1551): don't set softkey config for 'Starting...' window I/LAB126 ( 1551): StatusBarService hears intent. action: com.lab126.intent.TOP_WINDOW_CHANGED I/LAB126 ( 1551): window changed --------- beginning of /dev/log/main D/AudioResampler( 1290): forcing AudioResampler quality to 2 D/Omap4ALSA( 1290): open called for devices 00000002 in mode 0 channels 00000000... I/Omap4ALSA( 1290): Using ping-pong! I/Omap4ALSA( 1290): Buffer size: 4096 I/Omap4ALSA( 1290): Latency: 92879 I/Omap4ALSA( 1290): Initialized ALSA PLAYBACK device 'plughw:0,0' E/AudioHardwareALSA( 1290): RE-OPEN AFTER STANDBY:: took 116 msecs I/dalvikvm( 3618): Failed resolving Lcom/amazon/ags/client/LifecycleCallbacks; interface 15 'Landroid/app/Application$ActivityLifecycleCallbacks;' W/dalvikvm( 3618): Link of class 'Lcom/amazon/ags/client/LifecycleCallbacks;' failed E/dalvikvm( 3618): Could not find class 'com.amazon.ags.client.LifecycleCallbacks', referenced from method com.amazon.ags.api.AmazonGamesClient.initialize_internal W/dalvikvm( 3618): VFY: unable to resolve new-instance 339 (Lcom/amazon/ags/client/LifecycleCallbacks;) in Lcom/amazon/ags/api/AmazonGamesClient; D/dalvikvm( 3618): VFY: replacing opcode 0x22 at 0x0078 D/dalvikvm( 3618): VFY: dead code 0x007a-0080 in Lcom/amazon/ags/api/AmazonGamesClient;.initialize_internal (Lcom/amazon/ags/api/AmazonGamesCallback;Landroid/app/Activity;ZLcom/amazon/ags/storage/StringObfuscator;Ljava/util/EnumSet;)V W/dalvikvm( 3618): No implementation found for native Lcom/amazon/ags/jni/AGSJniHandler;.isLoaded ()V I/AGSJniHandler( 3618): AmazonGamesJni is not loaded, trying to load library D/dalvikvm( 3618): Trying to load lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libAmazonGamesJni.so 0x40512b10 D/dalvikvm( 3618): Added shared lib /mnt/asec/com.ReignStudios.ReignUnityPlugin-1/lib/libAmazonGamesJni.so 0x40512b10 D/AGSJni ( 3618): JNI_OnLoad called D/AGSLeaderboardJni( 3618): JNI_OnLoad called D/LeaderboardToJavaInterface( 3618): initializeClient - called D/LeaderboardToJavaInterface( 3618): initializeMethodIDs - called D/LeaderboardToJavaInterface( 3618): initializeMethodIDs - initialized D/AGSAchievementJni( 3618): JNI_OnLoad called D/AchievementToJavaInterface( 3618): initializeClient - called D/AchievementToJavaInterface( 3618): initializeMethodIDs - called D/AchievementToJavaInterface( 3618): initializeMethodIDs - initialized D/AGSProfileJni( 3618): JNI_OnLoad called D/ProfileToJavaInterface( 3618): initializeClient - called D/ProfileToJavaInterface( 3618): initializeMethodIDs - called D/ProfileToJavaInterface( 3618): initializeMethodIDs - initialized D/GC_Whispersync( 3618): JNI_OnLoad called D/GC_Whispersync( 3618): initializeMethodIDs - called D/GameCircleToJavaInterface( 3618): initializeClient - called D/GameCircleToJavaInterface( 3618): initializeMethodIDs - called D/GameCircleToJavaInterface( 3618): initializeMethodIDs - initialized D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3618): Extracting verison incremental: D/com.amazon.identity.auth.device.utils.MAPLog.PII( 3618): Extracting flavor: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/GameCircleClient( 3618): AmazonGamesClient not yet initialized. Initializing. D/dalvikvm( 3618): GC_CONCURRENT freed 523K, 50% free 3032K/5959K, external 849K/1181K, paused 2ms+3ms D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array V/AmazonInsightsSDK( 3618): Firing Session Event: _session.start I/AmazonInsightsSDK( 3618): Amazon Insights SDK(2.1.16.0) initialization successfully completed I/AmazonInsightsSDK( 3618): Event: '_sess...' recorded to local filestore I/dalvikvm( 3618): Total arena pages for JIT: 11 D/GC_Whispersync( 3618): Initial load from disk started V/GC_Whispersync( 3618): Retrieved JSON string [{"gameData":{}}] of game data map from disk D/GameCircleClient( 3618): initialize_internal() executing on thread:pool-2-thread-1 W/GC_Whispersync( 3618): GameDataMap - Unable to merge from an invalid/unset GameDataMap com.amazon.ags.client.whispersync.GameDataSingleMap@4059fe00 D/GC_Whispersync( 3618): Initial load from disk completed in 10 msec. I/AmazonInsightsSDK( 3618): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' I/AmazonInsightsSDK( 3618): Event: 'WHISP...' recorded to local filestore D/dalvikvm( 3618): GC_CONCURRENT freed 462K, 49% free 3080K/5959K, external 849K/1181K, paused 3ms+3ms I/AmazonInsightsSDK( 3618): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache D/dalvikvm( 3618): GC_CONCURRENT freed 402K, 48% free 3177K/6023K, external 849K/1181K, paused 2ms+2ms D/dalvikvm( 3618): GC_CONCURRENT freed 416K, 47% free 3288K/6151K, external 849K/1181K, paused 1ms+2ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 307K, 47% free 3304K/6151K, external 849K/1181K, paused 22ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 39K, 46% free 3440K/6279K, external 849K/1181K, paused 22ms I/AmazonInsightsSDK( 3618): Resolved variation: 'Test' for project: 'Universal Experiment List' from server I/AmazonInsightsSDK( 3618): Attempting to retrieve variation(s) for project(s):'ManifestSrc','InitSigninAlertTest' I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3618): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache I/AmazonInsightsSDK( 3618): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK( 3618): Successful submission of 16 events D/dalvikvm( 3618): GC_CONCURRENT freed 273K, 43% free 3662K/6407K, external 849K/1181K, paused 1ms+2ms I/AmazonInsightsSDK( 3618): Resolved variation: 'Control' for project: 'ManifestSrc' from server I/AmazonInsightsSDK( 3618): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server I/AmazonInsightsSDK( 3618): Event: '_http...' recorded to local filestore D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII( 3618): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): isAPIKeyValid : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: D/dalvikvm( 3618): GC_CONCURRENT freed 645K, 46% free 3667K/6727K, external 1016K/1181K, paused 2ms+3ms I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager( 3618): com.ReignStudios.ReignUnityPlugin calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): getAppInfo : packageName=com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier( 3618): Finding API Key for com.ReignStudios.ReignUnityPlugin I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser( 3618): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): Begin decoding API Key for packageName=com.ReignStudios.ReignUnityPlugin D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII( 3618): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder( 3618): perm has no mapping in json, returning null array D/KindleFireIPCProxy( 3618): Device appears to be a Kindle Fire. Attempting to connect to Amazon Game Services D/KindleFireIPCProxy( 3618): binding result:true V/KindleFireIPCProxy( 3618): synchronousBinder:null serviceMessengerClient:android.os.Messenger@40660c38 D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Device has compatible version of Amazon Game Services. D/KindleFireIPCProxy( 3618): Attempting to Authorize D/KindleFireIPCProxy( 3618): Handling authorize callback D/KindleFireIPCProxy( 3618): authResult: AUTHORIZED D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Attempting to check is authenticated D/KindleFireIPCProxy( 3618): Changing Status from:INITIALIZING to: SERVICE_CONNECTED D/dalvikvm( 3618): GC_CONCURRENT freed 535K, 44% free 3842K/6791K, external 1016K/1181K, paused 1ms+3ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 17473536, New space, used: 130776, Old pointers, used: 104504, Old data space, used: 51684, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 40960 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 32764, Old pointers, used: 152244, Old data space, used: 51692, Code space, used: 118208, Map space, used: 10848, Cell space, used: 3992, Large object space, used: 86016 D/dalvikvm( 3618): GC_FOR_MALLOC freed 187K, 43% free 4008K/6983K, external 1016K/1181K, paused 22ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 17649664, New space, used: 131052, Old pointers, used: 172188, Old data space, used: 69024, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 86016 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 17670144, New space, used: 32764, Old pointers, used: 218920, Old data space, used: 86372, Code space, used: 118688, Map space, used: 22368, Cell space, used: 4008, Large object space, used: 106496 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 131072, Old pointers, used: 302108, Old data space, used: 149052, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 65524, Old pointers, used: 315100, Old data space, used: 166120, Code space, used: 629792, Map space, used: 30976, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18784256, New space, used: 262132, Old pointers, used: 330948, Old data space, used: 172972, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 65524, Old pointers, used: 429364, Old data space, used: 191220, Code space, used: 691520, Map space, used: 47776, Cell space, used: 4008, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 18915328, New space, used: 262140, Old pointers, used: 471316, Old data space, used: 194712, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 19046400, New space, used: 131068, Old pointers, used: 538588, Old data space, used: 202864, Code space, used: 729728, Map space, used: 71072, Cell space, used: 8016, Large object space, used: 303104 E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 19251200, New space, used: 523952, Old pointers, used: 563716, Old data space, used: 228988, Code space, used: 837024, Map space, used: 115744, Cell space, used: 8120, Large object space, used: 376832 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 19247104, New space, used: 0, Old pointers, used: 593080, Old data space, used: 220160, Code space, used: 661888, Map space, used: 64928, Cell space, used: 7608, Large object space, used: 372736 D/dalvikvm( 3618): GC_FOR_MALLOC freed 394K, 43% free 4138K/7239K, external 1016K/1181K, paused 24ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 20533248, New space, used: 523136, Old pointers, used: 859468, Old data space, used: 519484, Code space, used: 1150144, Map space, used: 93184, Cell space, used: 16736, Large object space, used: 479232 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 20795392, New space, used: 131064, Old pointers, used: 1006256, Old data space, used: 525016, Code space, used: 1150144, Map space, used: 93184, Cell space, used: 16736, Large object space, used: 479232 D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-5] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-5] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-6] for call type [isKindleRegistered] D/KindleFireIPCProxy( 3618): Client is bound to service D/KindleFireIPCProxy( 3618): Attempting to check is authenticated D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-6] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-7] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-7] D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-8] for call type [hasOptedIn] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":false}] for request [backgroundwebview-8] D/GC_HttpNetworkClient( 3618): Request: GET https://ags-ext.amazon.com/services/featuredetection/getFeaturesUsage?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21008384, New space, used: 524288, Old pointers, used: 1018712, Old data space, used: 535412, Code space, used: 1306848, Map space, used: 101728, Cell space, used: 16880, Large object space, used: 561152 E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 21098496, New space, used: 0, Old pointers, used: 1147660, Old data space, used: 529632, Code space, used: 1139296, Map space, used: 92224, Cell space, used: 16368, Large object space, used: 520192 D/GC_HttpNetworkClient( 3618): Request: PUT https://ags-ext.amazon.com/service/achievements/getAchievementsPublic D/dalvikvm( 3618): GC_CONCURRENT freed 855K, 45% free 4098K/7367K, external 1016K/1181K, paused 2ms+5ms D/GC_HttpNetworkClient( 3618): Request: PUT https://ags-ext.amazon.com/service/leaderboards/getLeaderboardsForGamePublic D/GC_HttpNetworkClient( 3618): Request: POST https://ags-ext.amazon.com/services/ux/v1/getQueryData?GameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf&locale=en_US&gameId=amzn1.application.597fd90ae3414a7f83f966a7d739ffdf D/dalvikvm( 3618): GC_FOR_MALLOC freed 482K, 46% free 3984K/7367K, external 1016K/1181K, paused 29ms I/dalvikvm-heap( 3618): Grow heap (frag case) to 7.324MB for 87396-byte allocation D/dalvikvm( 3618): GC_FOR_MALLOC freed 40K, 47% free 4029K/7495K, external 1016K/1181K, paused 22ms D/dalvikvm( 3618): GC_FOR_MALLOC freed 75K, 44% free 4254K/7495K, external 1016K/1181K, paused 22ms I/dalvikvm-heap( 3618): Grow heap (frag case) to 7.587MB for 87396-byte allocation D/dalvikvm( 3618): GC_FOR_MALLOC freed 8K, 44% free 4331K/7623K, external 1016K/1181K, paused 24ms D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/dalvikvm( 3618): GC_FOR_MALLOC freed 712K, 42% free 4465K/7623K, external 1016K/1181K, paused 29ms D/dalvikvm( 3618): GC_CONCURRENT freed 65K, 41% free 4579K/7751K, external 1016K/1181K, paused 2ms+4ms D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_HttpNetworkClient( 3618): Result:HTTP/1.1 200 OK I/AGSJniHandler( 3618): Initializing Native Handlers I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore D/GC_Whispersync( 3618): Starting write to file system I/AmazonInsightsSDK( 3618): Event: 'GameC...' recorded to local filestore V/GC_Whispersync( 3618): GameDataMap - Deep copy of GameDataMap with name: null V/GC_Whispersync( 3618): GameDataMap copy took 1 msec. V/GC_Whispersync( 3618): Writing game data to disk: [{"gameData":{}}] D/GC_Whispersync( 3618): Completed write of 25 bytes to file system D/GC_Whispersync( 3618): posting event: DISK_WRITE_COMPLETE D/GC_Whispersync( 3618): Never synced from cloud. Attempting initial download and merge. D/GC_Whispersync( 3618): Checking whether Whispersync is enabled I/KindleFireSoftkeyBeachballManager( 3618): Failed to enable softkey button: java.lang.ClassNotFoundException: com.amazon.ags.app.util.SoftkeyBarWrapper I/AmazonInsightsSDK( 3618): Session Resume Failed: Session is already running. D/GC_ClickableToastImpl( 3618): Entering addToWindow... I/AmazonInsightsSDK( 3618): Event: 'PageV...' recorded to local filestore D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-35] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-35] E/GC_PlayerClientImpl( 3618): Request player failure response: {"REQUEST_ID":"ad5dbfd9-e0ea-4278-8612-fef6fa445b07","RESPONSE_CODE":"6"} I/Reign_Amazon_GameCircle( 3618): GameCircleGetPlayerAlias ERROR: AUTHENTICATION_ERROR I/Unity ( 3618): Authenticated: False I/Unity ( 3618): I/Unity ( 3618): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) I/Unity ( 3618): E/Unity ( 3618): AUTHENTICATION_ERROR E/Unity ( 3618): E/Unity ( 3618): (Filename: ./artifacts/AndroidManagedGenerated/UnityEngineDebug.cpp Line: 49) E/Unity ( 3618): D/dalvikvm( 3618): GC_CONCURRENT freed 666K, 40% free 4836K/7943K, external 1016K/1181K, paused 2ms+3ms D/GC_NativeKindleFireStateCallHandler( 3618): Processing request [backgroundwebview-39] for call type [isWhispersyncEnabled] D/KindleFireIPCProxy( 3618): Checking isWhispersyncEnabled: true D/GC_NativeKindleFireStateCallHandler( 3618): Returning reply [{"value":true}] for request [backgroundwebview-39] D/GC_Whispersync( 3618): Whispersync is DISABLED D/GC_Whispersync( 3618): Cannot sync with cloud because Whispersync is disabled D/GC_Whispersync( 3618): posting event: DISABLED D/GC_ClickableToastImpl( 3618): Entering runnable for hide() I/InputQueue-JNI( 3618): Sending finished signal for input channel '407e8a98 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity (client)' since it is being unregistered while an input message is still in progress. I/InputQueue-JNI( 3618): Ignoring finish signal on channel that is no longer registered. D/KindleFireIPCProxy( 3618): Checking isOverlaysSupported: false D/PhoneWindow( 3618): couldn't save which view has focus because the focused view android.view.SurfaceView@405304e8 has no id. D/ActivityManager( 1397): Starting: Intent { act=1403634582514 flg=0x14010000 cmp=com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras) } from pid 3618 D/Reign ( 3618): onPause called! I/AmazonInsightsSDK( 3618): Event: 'Objec...' recorded to local filestore W/ActivityManager( 1397): Activity pause timeout for HistoryRecord{4055e5b8 com.ReignStudios.ReignUnityPlugin/com.reignstudios.reignnative.ReignUnityActivity} E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21868544, New space, used: 739864, Old pointers, used: 1180128, Old data space, used: 550784, Code space, used: 1490976, Map space, used: 103872, Cell space, used: 16384, Large object space, used: 1028096 D/GC_GameCircleUserInterface( 3618): View size set to width: 512 height: 480 I/ActivityManager( 1397): Displayed com.ReignStudios.ReignUnityPlugin/com.amazon.ags.html5.overlay.GameCircleUserInterface: +220ms E/v8 ( 3618): < Heap::CollectGarbage Memory allocator, used: 20983808, New space, used: 0, Old pointers, used: 1149508, Old data space, used: 540476, Code space, used: 1231744, Map space, used: 95872, Cell space, used: 16384, Large object space, used: 536576 D/dalvikvm( 3618): GC_CONCURRENT freed 648K, 37% free 5265K/8327K, external 1064K/1181K, paused 16ms+4ms E/v8 ( 3618): > Heap::CollectGarbage Memory allocator, used: 21950464, New space, used: 1047780, Old pointers, used: 1315796, Old data space, used: 683856, Code space, used: 1777408, Map space, used:
