redbarngames avatar image
redbarngames asked
GameCircle CANNOT_INITIALIZE
GameCircle is failing to initialize with status = CANNOT_INITIALIZE on a generic device running Android 2.3.5. The only messages that seem to be of any value in the logs are 06-18 09:40:49.264: D/KindleFireIPCProxy(3070): Device does not appear to be a Kindle Fire. 06-18 09:40:49.274: D/KindleFireIPCProxy(3070): Changing Status from:INITIALIZING to: UNIVERSAL_NOT_SUPPORTED This works on an Android tablet (Acer) running Android 4.2.2 as well as on Kindle Fire 1st Gen. I'm using GameCircle API version 2.4.0. Anyone else run into this?
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi, The earliest version of Android OS we support is 10 (2.3.3) for GameCircle SDK. So you should be good to go. Can you paste the full logs. The logs you have printed that appears for all non Amazon devices and that's not the reason of CANNOT_INITIALIZE.
redbarngames answered
Ya I know it should be supported, but for some reason not working. I don't think it's a problem with configuration as this works on both kindle devices and newer non Amazon devices. Here's the log. 06-19 06:02:34.647: W/wonderful(6598): Initializing Game Circle 06-19 06:02:34.697: D/DATA(305): [DC cid = -1]DcActivatingState msg.what=EVENT_SETUP_DATA_CONNECTION_DONE 06-19 06:02:34.697: D/DATA(305): [DC cid = -1]DataConnection Init failed com.android.internal.telephony.CommandException: GENERIC_FAILURE 06-19 06:02:34.697: D/DATA(305): [DC cid = -1]DataConnection setup result='Other error' on cid=-1 06-19 06:02:34.697: D/DATA(305): [DC cid = -1]DcInactiveState: setEnterNoticationParams cp,cause 06-19 06:02:34.727: D/DATA(305): [DC cid = -1]DcInactiveState: enter notifyConnectCompleted 06-19 06:02:34.727: D/DATA(305): [DC cid = -1]notifyConnection at 1403172154738 cause=UNKNOWN 06-19 06:02:34.727: D/DATA(305): [DC cid = -1]notifyConnectCompleted() mWakeLock.release 06-19 06:02:34.727: I/DATA(305): [DCT] -------------------------- 06-19 06:02:34.727: I/DATA(305): [DCT] Data call setup : FAILED 06-19 06:02:34.727: I/DATA(305): [DCT] service type : SERVICE_TYPE_DEFAULT 06-19 06:02:34.727: I/DATA(305): [DCT] data profile : CDMA NAI 06-19 06:02:34.727: I/DATA(305): [DCT] ip version : IPV4 06-19 06:02:34.727: I/DATA(305): [DCT] fail cause : UNKNOWN 06-19 06:02:34.727: I/DATA(305): [DCT] -------------------------- 06-19 06:02:34.727: V/DATA(305): [DCT] Data call setup failure cause unknown / temporary failure. 06-19 06:02:34.727: D/DATA(305): [DCT] Scheduling next attempt on SERVICE_TYPE_DEFAULT for 1802s. Retry count = 10 06-19 06:02:34.727: V/DATA(305): [DCT] onUpdateDataConnections: reason=roamingOn 06-19 06:02:34.727: V/DATA(305): [DCT] ---dc list--- 06-19 06:02:34.727: V/DATA(305): [DCT] ---ds list--- 06-19 06:02:34.727: V/DATA(305): [DCT] ds= SERVICE_TYPE_DEFAULT, enabled = true, active = v4:WAITING_ALARM v6:IDLE 06-19 06:02:34.727: V/DATA(305): [DCT] ds= SERVICE_TYPE_MMS, enabled = false, active = v4:IDLE v6:IDLE 06-19 06:02:34.727: V/DATA(305): [DCT] ds= SERVICE_TYPE_SUPL, enabled = false, active = v4:IDLE v6:IDLE 06-19 06:02:34.727: V/DATA(305): [DCT] ds= SERVICE_TYPE_DUN, enabled = false, active = v4:IDLE v6:IDLE 06-19 06:02:34.727: V/DATA(305): [DCT] ds= SERVICE_TYPE_HIPRI, enabled = false, active = v4:IDLE v6:IDLE 06-19 06:02:34.727: D/DATA(305): [MMDataConnectionTracker] getDataOnDunEnabled 06-19 06:02:34.727: I/DATA(305): [DCT] Ready for data : 06-19 06:02:34.727: I/DATA(305): [DCT] getDesiredPowerState() = true 06-19 06:02:34.727: I/DATA(305): [DCT] mCm.getRadioState() = RADIO_ON 06-19 06:02:34.727: I/DATA(305): [DCT] [DataRadioTech = RADIO_TECH_1xRTT, data network state = 0, mMasterDataEnabled = true, is Roaming = true, dataOnRoamingEnable = true, isPsRestricted = false, desiredPowerState = true, mSIMRecords = , cdmaSubSource = 1/311220, mRuimRecords = ] 06-19 06:02:34.727: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=DataConnection 06-19 06:02:34.867: W/dalvikvm(6598): Link of class 'Lcom/amazon/ags/client/LifecycleCallbacks;' failed 06-19 06:02:34.867: E/dalvikvm(6598): Could not find class 'com.amazon.ags.client.LifecycleCallbacks', referenced from method com.amazon.ags.api.AmazonGamesClient.initialize_internal 06-19 06:02:34.867: W/dalvikvm(6598): VFY: unable to resolve new-instance 213 (Lcom/amazon/ags/client/LifecycleCallbacks;) in Lcom/amazon/ags/api/AmazonGamesClient; 06-19 06:02:34.917: W/dalvikvm(6598): No implementation found for native Lcom/amazon/ags/jni/AGSJniHandler;.isLoaded ()V 06-19 06:02:34.917: I/AGSJniHandler(6598): AmazonGamesJni is not loaded, trying to load library 06-19 06:02:34.977: W/AGSJniHandler(6598): AmazonGamesJni not found. Java Native Interface will not be available 06-19 06:02:35.027: W/InputManagerService(147): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4056dc78 06-19 06:02:35.057: D/GameCircleClient(6598): SDK Version: 2.4.0 06-19 06:02:35.107: D/com.amazon.identity.auth.device.utils.MAPLog.PII(6598): Extracting verison incremental: 06-19 06:02:35.107: D/com.amazon.identity.auth.device.utils.MAPLog.PII(6598): Incremental version '%s' was in invalid format.: 06-19 06:02:35.107: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(6598): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: 06-19 06:02:35.107: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): Options bundle is null 06-19 06:02:35.107: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:35.107: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:35.107: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:35.107: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:35.257: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:35.257: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:35.257: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:35.817: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:35.817: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:35.817: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:35.847: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:35.847: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:35.847: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:35.847: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getAppId 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:35.847: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:35.847: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:35.867: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:35.867: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:35.867: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:35.867: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:35.867: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:35.867: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:35.867: I/GameCircleClient(6598): AmazonGamesClient not yet initialized. Initializing. 06-19 06:02:36.037: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(6598): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: 06-19 06:02:36.037: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): Options bundle is null 06-19 06:02:36.037: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:36.037: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:36.037: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:36.037: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:36.047: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:36.047: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:36.047: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:36.047: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:36.047: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:36.047: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:36.047: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:02:36.047: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:36.057: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:36.057: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:36.057: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:36.067: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:36.067: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:36.067: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:36.067: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:36.067: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:36.067: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:36.067: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getAppId 06-19 06:02:36.067: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:36.067: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:36.077: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:36.077: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:36.087: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:36.087: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:36.087: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:36.097: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:36.097: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:36.097: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:36.117: V/AmazonInsightsSDK(6598): Firing Session Event: _session.start 06-19 06:02:36.127: I/AmazonInsightsSDK(6598): Amazon Insights SDK(2.1.26.0) initialization successfully completed 06-19 06:02:36.177: D/GameCircleClient(6598): initialize_internal() executing on thread:pool-1-thread-1 06-19 06:02:36.197: D/GC_Whispersync(6598): Initial load from disk started 06-19 06:02:36.197: W/GC_Whispersync(6598): Retrieved an empty document from disk 06-19 06:02:36.197: W/GC_Whispersync(6598): GameDataMap - Unable to merge from an invalid/unset GameDataMap null 06-19 06:02:36.197: D/GC_Whispersync(6598): Initial load from disk completed in 3 msec. 06-19 06:02:36.207: I/AmazonInsightsSDK(6598): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' 06-19 06:02:36.227: D/StatusBarPolicy(290): iconIndex = 0 iconMode = 0 06-19 06:02:36.277: I/AmazonInsightsSDK(6598): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache 06-19 06:02:36.347: I/AmazonInsightsSDK(6598): Event: '_sess...' recorded to local filestore 06-19 06:02:36.407: I/AmazonInsightsSDK(6598): Event: 'WHISP...' recorded to local filestore 06-19 06:02:37.107: I/AmazonInsightsSDK(6598): Resolved variation: 'Test' for project: 'Universal Experiment List' from server 06-19 06:02:37.197: I/AmazonInsightsSDK(6598): Event: '_http...' recorded to local filestore 06-19 06:02:37.197: I/AmazonInsightsSDK(6598): Attempting to retrieve variation(s) for project(s):'ManifestSrc','InitSigninAlertTest' 06-19 06:02:37.207: I/ActivityManager(147): Process com.google.android.apps.uploader (pid 6533) has died. 06-19 06:02:37.287: I/ActivityManager(147): Process com.samsung.DM (pid 6550) has died. 06-19 06:02:37.357: I/AmazonInsightsSDK(6598): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache 06-19 06:02:37.357: I/AmazonInsightsSDK(6598): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache 06-19 06:02:37.497: I/AmazonInsightsSDK(6598): Resolved variation: 'Control' for project: 'ManifestSrc' from server 06-19 06:02:37.497: I/AmazonInsightsSDK(6598): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server 06-19 06:02:37.517: I/AmazonInsightsSDK(6598): Event: '_http...' recorded to local filestore 06-19 06:02:37.637: I/GC_ContentManager(6598): Upgrade zip does not exist. 06-19 06:02:37.637: D/GC_ContentManager(6598): Current JavaScript content version: 2.4.0 06-19 06:02:37.637: D/GC_ContentManager(6598): Default JavaScript content version: 2.4.0 06-19 06:02:37.637: D/GC_ContentManager(6598): Upgrade JavaScript content version: -1.-1.-1 06-19 06:02:37.997: I/ActivityManager(147): Process com.amazon.venezia (pid 6559) has died. 06-19 06:02:38.157: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(6598): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: 06-19 06:02:38.157: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): Options bundle is null 06-19 06:02:38.157: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:38.157: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:38.157: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:38.157: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:38.217: V/DATA(305): [DCT] onDataCallListChanged: 06-19 06:02:38.217: V/DATA(305): [DCT] ---dc state list--- 06-19 06:02:38.217: V/DATA(305): [DCT] ---dc list--- 06-19 06:02:39.367: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=ServiceStateTracker 06-19 06:02:39.356: I/ActivityManager(147): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=6623 uid=10047 gids={} 06-19 06:02:39.876: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=ServiceStateTracker 06-19 06:02:39.976: D/StatusBarPolicy(290): iconIndex = 0 iconMode = 0 06-19 06:02:40.526: I/ActivityThread(6623): Pub com.android.deskclock: com.android.deskclock.AlarmProvider 06-19 06:02:40.946: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:40.966: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:40.966: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:40.966: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:40.976: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:40.976: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:41.406: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=Checkin Handoff 06-19 06:02:41.446: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=Checkin Service 06-19 06:02:41.446: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=Checkin Handoff 06-19 06:02:41.506: D/BatteryService(147): updateBattery level:75 scale:100 status:2 health:2 present:true voltage: 4018 temperature: 73 technology: Li-ion AC powered:false USB powered:true icon:17302192 06-19 06:02:41.516: D/StatusBarPolicy(290): updateBattery level=75 plugged=true mBatteryPlugged=true mBatteryLevel=75 mBatteryFirst=false 06-19 06:02:41.516: I/StatusBarPolicy(290): BAT. status:2 health:2 06-19 06:02:41.566: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=*wifi* 06-19 06:02:41.566: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=*wifi* 06-19 06:02:41.596: I/webclipboard(6598): clipservice: android.sec.clipboard.ClipboardExManager@4306cca0 06-19 06:02:41.996: I/webclipboard(6598): clipservice: android.sec.clipboard.ClipboardExManager@4306cca0 06-19 06:02:42.146: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:02:42.146: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:42.146: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:42.176: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=Checkin Service 06-19 06:02:42.206: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:42.226: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:42.236: I/GC_FileUtils(6598): Beginning download of /data/data/com.redbarngames.wonderful/files/.ags/download/agsmanifest.txt 06-19 06:02:42.266: I/GC_FileUtils(6598): Download of /data/data/com.redbarngames.wonderful/files/.ags/download/agsmanifest.txt was successful: true 06-19 06:02:42.276: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:42.286: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:42.286: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:42.296: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:42.296: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:42.296: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:42.296: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getAppId 06-19 06:02:42.296: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:42.296: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:42.306: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:42.306: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:42.356: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:42.356: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:42.366: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:42.376: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:42.376: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:42.376: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:42.406: D/KindleFireIPCProxy(6598): Device does not appear to be a Kindle Fire. 06-19 06:02:42.406: D/KindleFireIPCProxy(6598): Changing Status from:INITIALIZING to: UNIVERSAL_NOT_SUPPORTED 06-19 06:02:51.455: D/BatteryService(147): updateBattery level:76 scale:100 status:2 health:2 present:true voltage: 4016 temperature: 84 technology: Li-ion AC powered:false USB powered:true icon:17302192 06-19 06:02:51.455: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=*wifi* 06-19 06:02:51.455: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=*wifi* 06-19 06:02:51.465: D/StatusBarPolicy(290): updateBattery level=76 plugged=true mBatteryPlugged=true mBatteryLevel=75 mBatteryFirst=false 06-19 06:02:51.465: I/StatusBarPolicy(290): BAT. status:2 health:2 06-19 06:02:52.425: W/wonderful(6598): Amazon Games Client NOT Ready, status = CANNOT_INITIALIZE 06-19 06:02:52.425: W/GC_AsynchronousReplyMessenger(6598): Request 1bbfaeb4-c3d3-4e42-b46e-ba5a9271dc69 timed out. 06-19 06:02:52.485: I/AmazonInsightsSDK(6598): Event: 'GameC...' recorded to local filestore 06-19 06:02:54.325: D/GC_NativeKindleFireStateCallHandler(6598): Processing request [backgroundwebview-5] for call type [isKindle] 06-19 06:02:54.335: D/GC_NativeKindleFireStateCallHandler(6598): Returning reply [{"value":false}] for request [backgroundwebview-5] 06-19 06:02:54.355: D/GC_NativeKindleFireStateCallHandler(6598): Processing request [backgroundwebview-6] for call type [isKindleRegistered] 06-19 06:02:54.355: V/KindleFireIPCProxy(6598): synchronousBinder:null serviceMessengerClient:null 06-19 06:02:54.355: D/GC_NativeKindleFireStateCallHandler(6598): Returning reply [{"value":false}] for request [backgroundwebview-6] 06-19 06:02:54.375: D/GC_NativeKindleFireStateCallHandler(6598): Processing request [backgroundwebview-7] for call type [isGCServiceReady] 06-19 06:02:54.385: D/GC_NativeKindleFireStateCallHandler(6598): Returning reply [{"value":false}] for request [backgroundwebview-7] 06-19 06:02:54.385: D/GC_NativeKindleFireStateCallHandler(6598): Processing request [backgroundwebview-8] for call type [hasOptedIn] 06-19 06:02:54.385: V/KindleFireIPCProxy(6598): transact() was called while disconnected 06-19 06:02:54.395: D/GC_NativeKindleFireStateCallHandler(6598): Returning reply [{"value":false}] for request [backgroundwebview-8] 06-19 06:02:54.885: D/GC_HttpNetworkClient(6598): Request: GET https://ags-ext.amazon.com/services/featuredetection/getFeaturesUsage?GameId=amzn1.application.64519b84b805449bbed6cb5b6e13952f&locale=en_US&gameId=amzn1.application.64519b84b805449bbed6cb5b6e13952f 06-19 06:02:55.335: D/GC_HttpNetworkClient(6598): Request: PUT https://ags-ext.amazon.com/service/achievements/getAchievementsPublic 06-19 06:02:55.465: D/GC_HttpNetworkClient(6598): Request: PUT https://ags-ext.amazon.com/service/leaderboards/getLeaderboardsForGamePublic 06-19 06:02:55.755: D/GC_HttpNetworkClient(6598): Result:HTTP/1.1 200 OK 06-19 06:02:55.845: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getToken : scopes=[game_circle:game_data] 06-19 06:02:55.865: E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(6598): Running get on Future with timeout=10000unit=MILLISECONDS 06-19 06:02:55.865: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:02:55.865: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:55.865: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:55.875: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:55.875: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:55.885: I/AmazonInsightsSDK(6598): Event: 'GameC...' recorded to local filestore 06-19 06:02:55.935: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:55.935: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:55.935: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:55.935: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:55.945: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:55.945: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:55.965: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken pkg=com.redbarngames.wonderful scopes=[game_circle:game_data]: 06-19 06:02:55.965: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:55.975: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:55.975: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:55.975: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:56.055: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:56.055: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:56.055: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:56.055: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:56.055: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:56.065: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:56.065: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Vending out token: appId=amzn1.application.64519b84b805449bbed6cb5b6e13952f, scopes=[game_circle:game_data]: 06-19 06:02:56.085: D/com.amazon.identity.auth.device.datastore.DatabaseHelper.PII(6598): DatabaseHelper created: 06-19 06:02:56.145: W/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): RequestedScope shouldn't be null!!!! - null, but continuing anyway... 06-19 06:02:56.145: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common access token for requested scopes 06-19 06:02:56.165: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common refresh token for requested scopes 06-19 06:02:56.205: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Updating existing token: 06-19 06:02:56.215: D/GC_HttpNetworkClient(6598): Result:HTTP/1.1 200 OK 06-19 06:02:56.225: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Inside getRemoteAndroidService AsyncTask - Attempting remote service 06-19 06:02:56.225: D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): getAuthorizationServiceInstance 06-19 06:02:56.235: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of services found : 0 06-19 06:02:56.235: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of MAP services to compare = 0 06-19 06:02:56.235: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Returning no service to use 06-19 06:02:56.235: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Unbinding Highest Versioned Service 06-19 06:02:56.235: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken: 06-19 06:02:58.415: I/AmazonInsightsSDK(6598): Event: 'GameC...' recorded to local filestore 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): Exception encountered while executing request: com.amazon.ags.AGSClientException: Network request requires authentication 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): com.amazon.ags.AGSClientException: Network request requires authentication 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.comm.HttpNetworkClient.addLWATokenHeader(HttpNetworkClient.java:165) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.comm.HttpNetworkClient.addAuthenticationHeaders(HttpNetworkClient.java:155) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.comm.HttpNetworkClient.execute(HttpNetworkClient.java:89) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.comm.NetworkCallFactory.handleServiceRequest(NetworkCallFactory.java:152) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.comm.NetworkCallFactory.handleMessage(NetworkCallFactory.java:114) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.javascript.CallHandlerBase.handleMessage(CallHandlerBase.java:61) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at com.amazon.ags.html5.javascript.domain.JavascriptInterface$8.run(JavascriptInterface.java:254) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1088) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:581) 06-19 06:02:58.415: E/GC_NetworkCallFactory(6598): at java.lang.Thread.run(Thread.java:1019) 06-19 06:02:58.525: D/GC_HttpNetworkClient(6598): Result:HTTP/1.1 200 OK 06-19 06:02:58.645: I/AmazonInsightsSDK(6598): Event: 'GameC...' recorded to local filestore 06-19 06:02:59.025: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getToken : scopes=[game_circle:game_data] 06-19 06:02:59.025: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:02:59.025: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:59.025: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:59.025: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:59.035: E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(6598): Running get on Future with timeout=10000unit=MILLISECONDS 06-19 06:02:59.035: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:59.075: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:59.075: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:59.075: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:59.085: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:59.085: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:59.085: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:59.085: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken pkg=com.redbarngames.wonderful scopes=[game_circle:game_data]: 06-19 06:02:59.085: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:02:59.085: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:02:59.095: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:02:59.105: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:02:59.135: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:02:59.145: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:02:59.145: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:02:59.145: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:02:59.155: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:02:59.155: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:02:59.155: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Vending out token: appId=amzn1.application.64519b84b805449bbed6cb5b6e13952f, scopes=[game_circle:game_data]: 06-19 06:02:59.165: W/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): RequestedScope shouldn't be null!!!! - null, but continuing anyway... 06-19 06:02:59.165: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common access token for requested scopes 06-19 06:02:59.175: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common refresh token for requested scopes 06-19 06:02:59.185: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Updating existing token: 06-19 06:02:59.185: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Inside getRemoteAndroidService AsyncTask - Attempting remote service 06-19 06:02:59.185: D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): getAuthorizationServiceInstance 06-19 06:02:59.185: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of services found : 0 06-19 06:02:59.185: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of MAP services to compare = 0 06-19 06:02:59.185: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Returning no service to use 06-19 06:02:59.185: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Unbinding Highest Versioned Service 06-19 06:02:59.185: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken: 06-19 06:02:59.195: D/GC_NativeAuthCallHandler(6598): Logged in: false 06-19 06:02:59.995: D/PowerManagerService(147): acquireWakeLock flags=0x1 tag=AlarmManager 06-19 06:03:00.025: D/PowerManagerService(147): releaseWakeLock flags=0x1 tag=AlarmManager 06-19 06:03:00.145: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(6598): com.redbarngames.wonderful calling getToken : scopes=[game_circle:game_data] 06-19 06:03:00.145: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): isAPIKeyValid : packageName=com.redbarngames.wonderful 06-19 06:03:00.145: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:03:00.145: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:03:00.145: E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(6598): Running get on Future with timeout=10000unit=MILLISECONDS 06-19 06:03:00.145: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:03:00.155: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:03:00.195: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:03:00.195: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:03:00.195: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:03:00.205: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:03:00.205: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:03:00.205: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:03:00.205: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken pkg=com.redbarngames.wonderful scopes=[game_circle:game_data]: 06-19 06:03:00.215: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): getAppInfo : packageName=com.redbarngames.wonderful 06-19 06:03:00.215: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(6598): Finding API Key for com.redbarngames.wonderful 06-19 06:03:00.215: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(6598): Attempting to parse API Key from assets directory 06-19 06:03:00.215: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): Begin decoding API Key for packageName=com.redbarngames.wonderful 06-19 06:03:00.245: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): APIKey: 06-19 06:03:00.255: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): num sigs = 1 06-19 06:03:00.255: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Signature checking.: 06-19 06:03:00.255: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(6598): Fingerpirint checking: 06-19 06:03:00.265: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): scopes has no mapping in json, returning null array 06-19 06:03:00.265: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(6598): perm has no mapping in json, returning null array 06-19 06:03:00.265: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Vending out token: appId=amzn1.application.64519b84b805449bbed6cb5b6e13952f, scopes=[game_circle:game_data]: 06-19 06:03:00.265: W/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): RequestedScope shouldn't be null!!!! - null, but continuing anyway... 06-19 06:03:00.275: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common access token for requested scopes 06-19 06:03:00.275: I/com.amazon.identity.auth.device.endpoint.TokenVendor(6598): Try finding a common refresh token for requested scopes 06-19 06:03:00.285: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(6598): Updating existing token: 06-19 06:03:00.285: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Inside getRemoteAndroidService AsyncTask - Attempting remote service 06-19 06:03:00.285: D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): getAuthorizationServiceInstance 06-19 06:03:00.295: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of services found : 0 06-19 06:03:00.295: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Number of MAP services to compare = 0 06-19 06:03:00.295: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Returning no service to use 06-19 06:03:00.295: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(6598): Unbinding Highest Versioned Service 06-19 06:03:00.295: D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(6598): GetToken: 06-19 06:03:00.295: D/GC_NativeAuthCallHandler(6598): Logged in: false 06-19 06:03:00.545: W/GC_AsynchronousReplyMessenger(6598): No pending message found for message id 1bbfaeb4-c3d3-4e42-b46e-ba5a9271dc69
Thanks for the log. Forwarding it to concerned team. I will get back to you shortly.
Thanks Sujoy, any updates on this?
Not yet. I will let you know once I hear back from the team. Thanks.
Kirkules avatar image
Kirkules answered
I'm having the same problem, among others.
Hi Kirkules, Which device are you testing on and what is the Android version in it? The person who created this thread had problem with Android 2.3.5.
