Sega of America avatar image
Sega of America asked
Crash, need help
Hi, I've set up Game circle and the JNI follwing your instructions and I have a crash. My init code in java: AmazonGamesCallback agsGameCallback = new AmazonGamesCallback() { @Override public void onServiceReady() { Log.d(TAG, "onServiceReady" ); AmazonGamesClient.getInstance().initializeJni(); } @Override public void onServiceNotReady(AmazonGamesStatus reason) { } }; public void onCreate() { System.loadLibrary("AmazonGamesJni"); AmazonGamesClient.initialize(this, agsGameCallback, AmazonGamesFeature.all()); ... } This seems to initialise correctly as the calling [b]AmazonGames::LeaderboardsClientInterface::showLeaderboardOverlay( leaderboard.c_str() );[/b] will bring up the game circle popup showing the correct leaderboards. However, if I call [b]AmazonGames::HandleWrapper handle = AmazonGames::ProfilesClientInterface::getLocalPlayerProfile();[/b] the game crashes with the following output: 02-08 00:58:21.651: D/ProfileToJavaInterface(32530): requestLocalPlayerProfileHandle - called 02-08 00:58:21.651: D/PROFILES_ProfilesServiceProxy(32530): Request Local Player Profile called Asynchronously with handle. 02-08 00:58:21.651: D/GC_BaseReplyMessengerFactory(32530): Constructing a ServiceHandleHandler for the outgoing asynchronous event 02-08 00:58:21.651: W/System.err(32530): java.lang.NoClassDefFoundError: com/amazon/ags/api/AGResponseHandle 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.NativeStart.run(Native Method) 02-08 00:58:21.651: W/System.err(32530): Caused by: java.lang.ClassNotFoundException: com.amazon.ags.api.AGResponseHandle 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:61) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:501) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:461) 02-08 00:58:21.651: W/System.err(32530): ... 1 more 02-08 00:58:21.651: W/System.err(32530): java.lang.NoClassDefFoundError: com/amazon/ags/api/RequestResponse 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.NativeStart.run(Native Method) 02-08 00:58:21.651: W/System.err(32530): Caused by: java.lang.ClassNotFoundException: com.amazon.ags.api.RequestResponse 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:61) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:501) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:461) 02-08 00:58:21.651: W/System.err(32530): ... 1 more 02-08 00:58:21.651: W/System.err(32530): java.lang.NoClassDefFoundError: com/amazon/ags/api/AGHandleStatus 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.NativeStart.run(Native Method) 02-08 00:58:21.651: W/System.err(32530): Caused by: java.lang.ClassNotFoundException: com.amazon.ags.api.AGHandleStatus 02-08 00:58:21.651: W/System.err(32530): at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:61) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:501) 02-08 00:58:21.651: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:461) 02-08 00:58:21.651: W/System.err(32530): ... 1 more 02-08 00:58:21.659: W/System.err(32530): java.lang.NoClassDefFoundError: com/amazon/ags/api/ErrorCode 02-08 00:58:21.659: W/System.err(32530): at dalvik.system.NativeStart.run(Native Method) 02-08 00:58:21.659: W/System.err(32530): Caused by: java.lang.ClassNotFoundException: com.amazon.ags.api.ErrorCode 02-08 00:58:21.659: W/System.err(32530): at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:61) 02-08 00:58:21.659: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:501) 02-08 00:58:21.659: W/System.err(32530): at java.lang.ClassLoader.loadClass(ClassLoader.java:461) 02-08 00:58:21.659: W/System.err(32530): ... 1 more 02-08 00:58:21.659: A/libc(32530): Fatal signal 11 (SIGSEGV) at 0x0000002c (code=1) 02-08 00:58:21.839: I/AudioPolicyManagerBase(108): stopOutput() output 1, stream 3, session 927 02-08 00:58:21.956: I/DEBUG(32365): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** 02-08 00:58:21.956: I/DEBUG(32365): Build fingerprint: 'Android/jem/jem:4.0.4/IMM76D/8.1.4_user_1413620:user/release-keys' 02-08 00:58:21.956: I/DEBUG(32365): pid: 32530, tid: 32559 >>> com.sonicjump.sonicjump <<< 02-08 00:58:21.956: I/DEBUG(32365): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0000002c 02-08 00:58:21.956: I/DEBUG(32365): r0 00000000 r1 00000000 r2 00fc0760 r3 5b68b9b0 02-08 00:58:21.956: I/DEBUG(32365): r4 00000000 r5 5b68b9b0 r6 5b68b9bc r7 00fc0760 02-08 00:58:21.956: I/DEBUG(32365): r8 5c01fb07 r9 01d1ffb8 10 43c0006d fp 00000006 02-08 00:58:21.956: I/DEBUG(32365): ip 00f8e378 sp 5c01fac0 lr 4088956d pc 4088956c cpsr 60000030 02-08 00:58:21.956: I/DEBUG(32365): d0 00000001000b0101 d1 56beca6000000000 02-08 00:58:21.956: I/DEBUG(32365): d2 56e251d800000000 d3 0000010000000000 02-08 00:58:21.956: I/DEBUG(32365): d4 6c702e646f76612e d5 542e6b6361627961 02-08 00:58:21.956: I/DEBUG(32365): d6 6279616c50657461 d7 7149f2ca00000000 02-08 00:58:21.956: I/DEBUG(32365): d8 0000000000000000 d9 0000000000000000 02-08 00:58:21.956: I/DEBUG(32365): d10 0000000000000000 d11 0000000000000000 02-08 00:58:21.956: I/DEBUG(32365): d12 0000000000000000 d13 0000000000000000 02-08 00:58:21.956: I/DEBUG(32365): d14 0000000000000000 d15 0000000000000000 02-08 00:58:21.956: I/DEBUG(32365): d16 0000000700000000 d17 bee88ae6b8ef131c 02-08 00:58:21.956: I/DEBUG(32365): d18 bf29fd6b7e09f3b8 d19 3ec6cd878c3b46a7 02-08 00:58:21.956: I/DEBUG(32365): d20 bf7f88899559ff08 d21 3f58e7e1306ad06f 02-08 00:58:21.956: I/DEBUG(32365): d22 3ff0000000000000 d23 3fede16b9c24a98f 02-08 00:58:21.956: I/DEBUG(32365): d24 3ef99342e0ee5069 d25 0000000000000000 02-08 00:58:21.956: I/DEBUG(32365): d26 ffffffffffffffff d27 3ef99342e0ee5069 02-08 00:58:21.956: I/DEBUG(32365): d28 0000002100000021 d29 ffffffffffffffff 02-08 00:58:21.956: I/DEBUG(32365): d30 00e6008800870067 d31 00e6008800870067 02-08 00:58:21.956: I/DEBUG(32365): scr 20000012 02-08 00:58:22.019: I/DEBUG(32365): #00 pc 0005856c /system/lib/ libdvm.so 02-08 00:58:22.019: I/DEBUG(32365): #01 pc 000164a0 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN15JniBuilderUtils11getMethodIDEP7_JNIEnvRP10_jmethodIDP7_jclassPKcS8_) 02-08 00:58:22.019: I/DEBUG(32365): #02 pc 00015d22 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN18IAGSResponseHandle17setResponseHandleEP7_JavaVMP8_jobject) 02-08 00:58:22.019: I/DEBUG(32365): #03 pc 0001eaee /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN34RequestLocalPlayerProfileOperation7executeEP7_JavaVMP7_JNIEnv) 02-08 00:58:22.019: I/DEBUG(32365): #04 pc 00015ae8 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN19BaseToJavaInterface16executeOperationEP14IJavaOperation) 02-08 00:58:22.019: I/DEBUG(32365): #05 pc 0001ed1a /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN22ProfileToJavaInterface31requestLocalPlayerProfileHandleEi) 02-08 00:58:22.019: I/DEBUG(32365): #06 pc 0001679c /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so (_ZN11AmazonGames23ProfilesClientInterface21getLocalPlayerProfileEi) 02-08 00:58:22.019: I/DEBUG(32365): #07 pc 00209032 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN2sl12gamification13getPlayerNameEv) 02-08 00:58:22.019: I/DEBUG(32365): #08 pc 002090e0 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN2sl12gamification11getPlayerIDEv) 02-08 00:58:22.019: I/DEBUG(32365): #09 pc 002573c8 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN2sl16LeaderboardEntry13isLocalPlayerEv) 02-08 00:58:22.019: I/DEBUG(32365): #10 pc 002cfc02 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UILeaderboard16buildLeaderBoardEPN2sl11LeaderboardE) 02-08 00:58:22.019: I/DEBUG(32365): #11 pc 002cfd6c /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UILeaderboard6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #12 pc 002d728c /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame14updateChildrenEf) 02-08 00:58:22.019: I/DEBUG(32365): #13 pc 002d729a /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #14 pc 002d728c /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame14updateChildrenEf) 02-08 00:58:22.019: I/DEBUG(32365): #15 pc 002d729a /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #16 pc 002cc02a /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN26UIHorizontalFocusListFrame6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #17 pc 002d728c /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame14updateChildrenEf) 02-08 00:58:22.019: I/DEBUG(32365): #18 pc 002d729a /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13UIScrollFrame6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #19 pc 002c1d50 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN12UIScreenBase6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #20 pc 002c3148 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN10ZoneSelect6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #21 pc 002a90d4 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN19InfiniteLevelSelect6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #22 pc 002f101e /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_ZN13ScreenManager6updateEf) 02-08 00:58:22.019: I/DEBUG(32365): #23 pc 002f19e2 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (_Z9appUpdatef) 02-08 00:58:22.019: I/DEBUG(32365): #24 pc 00204506 /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so (android_main) 02-08 00:58:22.019: I/DEBUG(32365): #25 pc 002f656c /data/data/com.sonicjump.sonicjump/lib/libsonicjumpgame.so 02-08 00:58:22.019: I/DEBUG(32365): #26 pc 00012d1c /system/lib/ libc.so (__thread_entry) 02-08 00:58:22.019: I/DEBUG(32365): #27 pc 00012870 /system/lib/ libc.so (pthread_create) 02-08 00:58:22.019: I/DEBUG(32365): code around pc: 02-08 00:58:22.019: I/DEBUG(32365): 4088954c bf004770 41ffe92d 460c4607 4639a803 pG..-..A.F.F..9F 02-08 00:58:22.019: I/DEBUG(32365): 4088955c 4615461e fe32f7fb 98034621 f866f7fd .F.F..2.!F....f. 02-08 00:58:22.026: I/DEBUG(32365): 4088956c 46046ac3 d0572b07 fa64f01e e053b1b0 .j.F.+W...d...S. 02-08 00:58:22.026: I/DEBUG(32365): 4088957c 46294620 f01f4632 4607fc2f d1432800 F)F2F../..F.(C. 02-08 00:58:22.026: I/DEBUG(32365): 4088958c 69a24b27 681b447b 92004926 f8d34479 'K.i{D.h&I..yD.. 02-08 00:58:22.026: I/DEBUG(32365): code around lr: 02-08 00:58:22.026: I/DEBUG(32365): 4088954c bf004770 41ffe92d 460c4607 4639a803 pG..-..A.F.F..9F 02-08 00:58:22.026: I/DEBUG(32365): 4088955c 4615461e fe32f7fb 98034621 f866f7fd .F.F..2.!F....f. 02-08 00:58:22.026: I/DEBUG(32365): 4088956c 46046ac3 d0572b07 fa64f01e e053b1b0 .j.F.+W...d...S. 02-08 00:58:22.026: I/DEBUG(32365): 4088957c 46294620 f01f4632 4607fc2f d1432800 F)F2F../..F.(C. 02-08 00:58:22.026: I/DEBUG(32365): 4088958c 69a24b27 681b447b 92004926 f8d34479 'K.i{D.h&I..yD.. 02-08 00:58:22.026: I/DEBUG(32365): stack: 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa80 00000001 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa84 5c01fb07 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa88 01d1ffb8 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa8c 43c0006d /dev/ashmem/dalvik-heap (deleted) 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa90 00000006 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa94 4089da6d /system/lib/ libdvm.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa98 5c01facc 02-08 00:58:22.026: I/DEBUG(32365): 5c01fa9c 5b68b9b0 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01faa0 5b68b9bc /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01faa4 40885201 /system/lib/ libdvm.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01faa8 5c01facc 02-08 00:58:22.026: I/DEBUG(32365): 5c01faac 00fc0760 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fab0 00000000 02-08 00:58:22.026: I/DEBUG(32365): 5c01fab4 5b68b9b0 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01fab8 df0027ad 02-08 00:58:22.026: I/DEBUG(32365): 5c01fabc 00000000 02-08 00:58:22.026: I/DEBUG(32365): #00 5c01fac0 00fc0760 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fac4 00000000 02-08 00:58:22.026: I/DEBUG(32365): 5c01fac8 5b68b9b0 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01facc 00f8e358 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fad0 00fc0760 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fad4 40889551 /system/lib/ libdvm.so 02-08 00:58:22.026: I/DEBUG(32365): 5c01fad8 01d1ffd8 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01fadc 00000006 02-08 00:58:22.026: I/DEBUG(32365): 5c01fae0 5c01fb07 02-08 00:58:22.026: I/DEBUG(32365): 5c01fae4 5b67f4a3 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so 02-08 00:58:22.026: I/DEBUG(32365): #01 5c01fae8 01d1ffb4 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01faec 00fc0760 [heap] 02-08 00:58:22.026: I/DEBUG(32365): 5c01faf0 fffffffc 02-08 00:58:22.026: I/DEBUG(32365): 5c01faf4 5b67ed27 /data/data/com.sonicjump.sonicjump/lib/libAmazonGamesJni.so please help Thanks Andy
Sega of America answered
also, here is the output when during startup if that helps. 02-08 01:01:54.800: D/AGSJni(32642): JNI_OnLoad called 02-08 01:01:54.800: D/AGSLeaderboardJni(32642): JNI_OnLoad called 02-08 01:01:54.808: D/LeaderboardToJavaInterface(32642): initializeClient - called 02-08 01:01:54.808: D/LeaderboardToJavaInterface(32642): initializeMethodIDs - called 02-08 01:01:54.808: D/LeaderboardToJavaInterface(32642): initializeMethodIDs - initialized 02-08 01:01:54.808: D/AGSAchievementJni(32642): JNI_OnLoad called 02-08 01:01:54.808: D/AchievementToJavaInterface(32642): initializeClient - called 02-08 01:01:54.808: D/AchievementToJavaInterface(32642): initializeMethodIDs - called 02-08 01:01:54.808: D/AchievementToJavaInterface(32642): initializeMethodIDs - initialized 02-08 01:01:54.808: D/AGSWhisperSyncJni(32642): JNI_OnLoad called 02-08 01:01:54.808: D/WhisperSyncToJavaInterface(32642): initializeClient - called 02-08 01:01:54.808: D/WhisperSyncToJavaInterface(32642): initializeMethodIDs - called 02-08 01:01:54.808: D/WhisperSyncToJavaInterface(32642): initializeMethodIDs - initialized 02-08 01:01:54.808: D/AGSProfileJni(32642): JNI_OnLoad called 02-08 01:01:54.808: D/ProfileToJavaInterface(32642): initializeClient - called 02-08 01:01:54.808: D/ProfileToJavaInterface(32642): initializeMethodIDs - called 02-08 01:01:54.808: D/ProfileToJavaInterface(32642): initializeMethodIDs - initialized 02-08 01:01:54.815: D/AGC_ServiceProxy(32642): binding result:true 02-08 01:01:55.151: I/PurchasingManager(32642): Purchasing Framework initialization complete. Build ID 1.0.3 02-08 01:01:55.151: D/SandboxRequestHandler(32642): In App Purchasing SDK - Sandbox Mode: sendGetUserIdRequest 02-08 01:01:55.175: D/SandboxRequestHandler(32642): In App Purchasing SDK - Sandbox Mode: sendGetUserIdRequest 02-08 01:01:55.190: D/AGC_ServiceProxy(32642): synchronousBinder:null serviceMessengerClient:android.os.Messenger@41909ec0 02-08 01:01:55.190: D/AGC_ServiceProxy(32642): synchronousBinder:null serviceMessengerClient:android.os.Messenger@41909ec0 02-08 01:01:55.190: D/AGC_ServiceProxy(32642): Client is bound to service 02-08 01:01:55.190: D/AGC_ServiceProxy(32642): Session Id:31bcc5af-8382-4363-8036-6df9ed9892b6 02-08 01:01:55.190: D/BillingAmazon(32642): onSdkAvailable recieved: Response -true 02-08 01:01:55.190: D/SandboxRequestHandler(32642): In App Purchasing SDK - Sandbox Mode: sendGetUserIdRequest 02-08 01:01:55.261: D/AGC_ServiceProxy(32642): Handling authorize callback 02-08 01:01:55.261: D/AGC_ServiceProxy(32642): authResult: AUTHORIZED 02-08 01:01:55.261: D/AGC_ServiceProxy(32642): Client is bound to service 02-08 01:01:55.261: D/AGC_AuthenticationService(32642): Attempting to check is authenticated 02-08 01:01:55.261: D/SandboxResponseHandler(32642): In App Purchasing SDK - Sandbox Mode: handleResponse 02-08 01:01:55.261: D/AGC_ServiceProxy(32642): Game received broadcast from service with opt-in status [OPTED_IN] 02-08 01:01:55.261: D/AGC_ServiceProxy(32642): Client is bound to service 02-08 01:01:55.261: D/AGC_AuthenticationService(32642): Attempting to check is authenticated 02-08 01:01:55.269: D/AGC_ServiceProxy(32642): Client is bound to service 02-08 01:01:55.269: D/AGC_ServiceProxy(32642): Changing Status from:INITIALIZING to: SERVICE_CONNECTED 02-08 01:01:55.284: D/SandboxResponseHandler(32642): In App Purchasing SDK - Sandbox Mode: Running Runnable for userIdResponse with requestId: 472ccb10-6061-4675-b79d-c7ca7367b9b8 02-08 01:01:55.284: I/AGC_AmazonGamesStatusHandler(32642): Game received status update of: SERVICE_CONNECTED
Hi, From my own experimentation it seems that the handles just don't work for me. They make the calls to java and return a handle, but after this, the amazon C++ code try to do something (what I don't know) that creates a classdefnotfound exception which crashes the application. I switched to using the callbacks.
Dixith@Amazon avatar image
Dixith@Amazon answered
Hi Andy, Thank you for your post. We are working with concerned team on this issue and will get back to you once we have an update.
xfhe avatar image
xfhe answered
I encounter the same problem using latest App-SDK, It turns out OK when using callbacks instead of HandleWrapper . :( Please fix it.
DougM@Amazon avatar image
DougM@Amazon answered
Hello xfhe, We cannot actually reproduce the crash that you are experiencing using the current HandleWrapper methods that are exposed. However, please open a new thread with the exact methods that you are attempting to use at the time of the crash since to this post's thread since it was opened in 2012, the interface that the original post doesn't exist as of the latest version of the GameCircle SDK.
