John Vincent Fiel avatar image
John Vincent Fiel asked
Integration Help
Hello, do we have a step by step tutorial for GameCircle - cocos2d-x integration? Particularly on implementing Leaderboard. Thanks.
John Vincent Fiel answered
I followed the docs.. im stuck having java.lang.UnsatisfiedLinkError: Couldn't load AmazonGamesJni...
DougM@Amazon avatar image
DougM@Amazon answered
Hello John, One thing you may want to try is checking your Android.mk under the JNI folder of your pro.android folder and making sure that the following line is at the top: APP_ABI := armeabi-v7a As it appears that otherwise by default cocos2d-x tends to build for general ARM and will not be compatible with GameCircle for C++.
hi, can we also have a working example for c++?
