JeReT avatar image
JeReT asked
Unity: CANNOT_INITIALIZE if not using default main activity
Hi, I implemented GameCircle in my game and tested it. I always received CANNOT_INITIALIZE errors. After a lot of trials I discovered the source of the problem: My main activity is not the default unity-activity. I use a bluetooth plugin which needs to be the main activity... Is there a way to use GameCircle with an individual main activity? I have the source of the Bluetooth plugin. Maybe I can add something which is needed by the GameCircle plugin?
JeReT avatar image
JeReT answered
I found a solution for the problem. I now use the prime31 activity sharing system. The main activity should look like this then: Maybe the sharing system was not the solution for the problem but the "ForwardNativeEventsToDalvik" meta-data node. It was previously set to false...
