Pompi avatar image
Pompi asked
Issues with parsing api_key.txt at the assets. GameCircle.
I have been through all the steps of setting up GameCricle. I have created a debug api_key,txt and in a previous attempt I tried the distribution key. On both cases I am having issues witht he key. I don't exactly know what is the issue, log catr doesn't explain much. I was told on support that: "Looking at the logs it appears your API key may have been incorrectly placed in your APK file. You will need the API key from your game's GameCircle configuration placed in the assets folder of your APK for the package name and signature that you have provided for debugging purposes." I am not sure if it doesn't find the key or the key mismatch, or maybe there is a bad character in the file? Who knows... Maybe you can tell me more what I am doing wrong with this logcat: --------- beginning of main V/GLSActivity( 3705): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService } --------- beginning of system D/PackageManager( 534): Renaming /data/app/vmdl1216337895.tmp to /data/app/pompipompi.ofer.racing.dieselracer2-2 I/ActivityManager( 534): Force stopping pompipompi.ofer.racing.dieselracer2 appid=10144 user=-1: uninstall pkg W/PackageSettings( 534): Skipping PackageSetting{37355bcc com.gravitysensation.sumotori/10040} due to missing metadata I/PackageManager( 534): Package pompipompi.ofer.racing.dieselracer2 codePath changed from /data/app/pompipompi.ofer.racing.dieselracer2-1 to /data/app/pompipompi.ofer.racing.dieselracer2-2; Retaining data and using new I/art ( 534): DexFile_isDexOptNeeded failed to open oat file '/data/dalvik-cache/arm/data@app@pompipompi.ofer.racing.dieselracer2-2@base.apk@classes.dex' for file location '/data/app/pompipompi.ofer.racing.dieselracer2-2/base.apk': Failed to open oat filename for reading: No such file or directory I/art ( 534): DexFile_isDexOptNeeded failed to open oat file '/data/app/pompipompi.ofer.racing.dieselracer2-2/arm/base.odex' for file location '/data/app/pompipompi.ofer.racing.dieselracer2-2/base.apk': Failed to open oat filename for reading: No such file or directory I/PackageManager( 534): Running dexopt on: /data/app/pompipompi.ofer.racing.dieselracer2-2/base.apk pkg=pompipompi.ofer.racing.dieselracer2 isa=arm vmSafeMode=false I/dex2oat (11806): /system/bin/dex2oat --zip-fd=6 --zip-location=/data/app/pompipompi.ofer.racing.dieselracer2-2/base.apk --oat-fd=7 --oat-location=/data/dalvik-cache/arm/data@app@pompipompi.ofer.racing.dieselracer2-2@base.apk@classes.dex --instruction-set=arm --instruction-set-features=div --runtime-arg -Xms64m --runtime-arg -Xmx512m I/dex2oat (11806): dex2oat took 1.977s (threads: 4) W/PackageManager( 534): Code path for pkg : pompipompi.ofer.racing.dieselracer2 changing from /data/app/pompipompi.ofer.racing.dieselracer2-1 to /data/app/pompipompi.ofer.racing.dieselracer2-2 I/ActivityManager( 534): Force stopping pompipompi.ofer.racing.dieselracer2 appid=10144 user=-1: update pkg W/PackageManager( 534): Resource path for pkg : pompipompi.ofer.racing.dieselracer2 changing from /data/app/pompipompi.ofer.racing.dieselracer2-1 to /data/app/pompipompi.ofer.racing.dieselracer2-2 W/PackageSettings( 534): Skipping PackageSetting{37355bcc com.gravitysensation.sumotori/10040} due to missing metadata W/PackageSettings( 534): Skipping PackageSetting{37355bcc com.gravitysensation.sumotori/10040} due to missing metadata I/ActivityManager( 534): Force stopping pompipompi.ofer.racing.dieselracer2 appid=10144 user=0: pkg removed I/art ( 3200): Explicit concurrent mark sweep GC freed 26875(1318KB) AllocSpace objects, 31(544KB) LOS objects, 23% free, 26MB/34MB, paused 549us total 40.832ms I/art ( 2300): Explicit concurrent mark sweep GC freed 45(1712B) AllocSpace objects, 0(0B) LOS objects, 25% free, 9MB/13MB, paused 366us total 25.085ms I/InputReader( 534): Reconfiguring input devices. changes=0x00000010 I/InputReader( 534): Reconfiguring input devices. changes=0x00000010 I/art ( 670): Explicit concurrent mark sweep GC freed 9276(426KB) AllocSpace objects, 7(4MB) LOS objects, 39% free, 15MB/26MB, paused 2.593ms total 49.896ms W/Settings( 534): Setting install_non_market_apps has moved from android.provider.Settings.Global to android.provider.Settings.Secure, returning read-only value. I/InputReader( 534): Reconfiguring input devices. changes=0x00000010 W/ContextImpl( 9086): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1686 android.content.ContextWrapper.startService:515 android.content.ContextWrapper.startService:515 com.android.keychain.KeyChainBroadcastReceiver.onReceive:12 android.app.ActivityThread.handleReceiver:2579 I/art ( 534): Explicit concurrent mark sweep GC freed 49957(2MB) AllocSpace objects, 25(448KB) LOS objects, 33% free, 23MB/35MB, paused 1.525ms total 123.687ms D/BackupManagerService( 534): Received broadcast Intent { act=android.intent.action.PACKAGE_REMOVED dat=package:pompipompi.ofer.racing.dieselracer2 flg=0x4000010 (has extras) } D/JobSchedulerService( 534): Receieved: android.intent.action.PACKAGE_REMOVED I/art ( 534): WaitForGcToComplete blocked for 80.657ms for cause Explicit E/NetworkScheduler.SchedulerReceiver( 3705): Invalid parameter app E/NetworkScheduler.SchedulerReceiver( 3705): Invalid package name : Perhaps you didn't include a PendingIntent in the extras? D/PackageBroadcastService( 4014): Received broadcast action=android.intent.action.PACKAGE_REMOVED and uri=pompipompi.ofer.racing.dieselracer2 I/ConfigService( 3705): onCreate W/InputMethodInfo( 534): Duplicated subtype definition found: , voice I/ConfigService( 3705): onBind for Intent { act=com.google.android.gms.config.UPDATE pkg=com.google.android.gms } action com.google.android.gms.config.UPDATE I/ConfigService( 3705): onBind returning update interface I/ConfigFetchService( 4014): onStartCommand Intent { act=android.intent.action.PACKAGE_REMOVED dat=package:pompipompi.ofer.racing.dieselracer2 cmp=com.google.android.gms/.config.ConfigFetchService (has extras) } I/ConfigService( 3705): onBind for Intent { act=com.google.android.gms.config.START pkg=com.google.android.gms } action com.google.android.gms.config.START I/ConfigService( 3705): onBind returning service broker I/ConfigFetchService( 4014): service connected D/BackupManagerService( 534): Received broadcast Intent { act=android.intent.action.PACKAGE_ADDED dat=package:pompipompi.ofer.racing.dieselracer2 flg=0x4000010 (has extras) } W/BackupManagerService( 534): Removing schedule queue dupe of pompipompi.ofer.racing.dieselracer2 I/UpdateIcingCorporaServi( 2300): Updating corpora: APPS=pompipompi.ofer.racing.dieselracer2, CONTACTS=MAYBE D/PackageBroadcastService( 4014): Received broadcast action=android.intent.action.PACKAGE_ADDED and uri=pompipompi.ofer.racing.dieselracer2 I/art ( 534): Explicit concurrent mark sweep GC freed 9517(466KB) AllocSpace objects, 0(0B) LOS objects, 33% free, 24MB/36MB, paused 2.166ms total 156.311ms I/ConfigFetchService( 4014): onStartCommand Intent { act=android.intent.action.PACKAGE_ADDED dat=package:pompipompi.ofer.racing.dieselracer2 cmp=com.google.android.gms/.config.ConfigFetchService (has extras) } I/ActivityManager( 534): Delay finish: com.amazon.venezia/com.amazon.mas.client.install.foreground.PackageAddedReceiver I/ConfigFetchService( 4014): launchTask I/ActivityManager( 534): Resuming delayed broadcast I/ActivityManager( 534): Delay finish: com.amazon.venezia/.notification.NotificationEventReceiver I/ConfigFetchService( 4014): service connected I/ActivityManager( 534): Resuming delayed broadcast I/com.amazon.identity.auth.device.authorization.PackageIntentReceiver( 4390): Package Intent Received. Clearing Service Data. action=android.intent.action.PACKAGE_ADDED I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper( 4390): Clearing Highest Versioned Service V/ConfigFetchTask( 4014): ConfigFetchTask getDeviceDataVersionInfo(): ABFEt1UJt09rx9ynAn80AmnVY7Htk9hmkd4xZiT1C7v12VIpbj4CULGmHeB0hwtkM2IS5VAzdfqnYy4ZW1-ePmrC2Kg-79zTqt7ir2qtGKs7Cr46YBvQe3G_GsqMwHWQGspiJwPnKvSuMdLFPnEiZXXuawag0NU9NOohzhUFmvAehm8iFfuGziaGimqG3DHVBBUx4JMK-KV2WesGf2uTEkZjZrAH6nIE2xaL0u_KbQXHMtsMaPD3-AfNbq56kBEbfa-H8jUvXF5jAbVgHWcMDlMYNo6jTYavKfcqVzDVZ9FoLez6azo898g D/ConfigFetchService( 4014): ConfigApi connection successful. E/NetworkScheduler.SchedulerReceiver( 3705): Invalid parameter app E/NetworkScheduler.SchedulerReceiver( 3705): Invalid package name : Perhaps you didn't include a PendingIntent in the extras? D/UpgradeReceiver( 4671): got upgrade intent D/MoblinTracker( 4671): old app version: -1 D/MoblinTracker( 4671): new app version: 19 W/ResourcesManager( 1057): Asset path '/system/framework/com.google.android.media.effects.jar' does not exist or contains no resources. I/ActivityManager( 534): Delay finish: com.amazon.venezia/com.amazon.mas.client.licensing.LicensingBroadcastReceiver D/PackageBroadcastService( 4014): Received broadcast action=android.intent.action.PACKAGE_REPLACED and uri=pompipompi.ofer.racing.dieselracer2 I/ActivityManager( 534): Resuming delayed broadcast W/ResourcesManager( 1057): Asset path '/system/framework/com.google.android.maps.jar' does not exist or contains no resources. I/ActivityManager( 534): Delay finish: com.amazon.venezia/com.amazon.mas.client.analytics.TailwindBroadcastReceiver I/ActivityManager( 534): Resuming delayed broadcast I/ActivityManager( 534): Delay finish: com.amazon.venezia/com.amazon.mas.client.licensing.LicensingBroadcastReceiver I/ActivityManager( 534): Resuming delayed broadcast I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true D/AndroidRuntime(11702): Shutting down VM I/art (11702): Debugger is no longer active I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared(null) - using H:f5d46c4387dd1b00efbdf61e6a8c95ed I/AmazonAppstore.AccountSummaryProviderImpl( 3959): isAccountPrepared() - using H:f5d46c4387dd1b00efbdf61e6a8c95ed, returning true I/ApplicationLogger( 2300): canRun() : Opted Out I/UpdateIcingCorporaServi( 2300): UpdateCorporaTask done [took 294 ms] updated apps [took 294 ms] I/AvailabilitySDK( 3959): putMeasurement - gamelab W/Settings( 3959): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AvailabilitySDK( 3959): putMeasurement - venezia-metrics W/Settings( 3959): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/ConfigFetchService( 4014): fetch service done; releasing wakelock I/ConfigFetchService( 4014): stopping self D/AndroidRuntime(11878): D/AndroidRuntime(11878): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<< D/AndroidRuntime(11878): CheckJNI is OFF D/AndroidRuntime(11878): Calling main entry com.android.commands.am.Am I/ActivityManager( 534): Force stopping pompipompi.ofer.racing.dieselracer2 appid=10144 user=-1: set debug app I/ActivityManager( 534): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=pompipompi.ofer.racing.dieselracer2/.Racer2Activity} from uid 2000 on display 0 D/AndroidRuntime(11878): Shutting down VM I/art (11878): Debugger is no longer active I/ActivityManager( 534): Start proc pompipompi.ofer.racing.dieselracer2 for activity pompipompi.ofer.racing.dieselracer2/.Racer2Activity: pid=11894 uid=10144 gids={50144, 9997, 3003} abi=armeabi I/art (11894): Late-enabling -Xcheck:jni W/ActivityThread(11894): Application pompipompi.ofer.racing.dieselracer2 is waiting for the debugger on port 8100... I/System.out(11894): Sending WAIT chunk I/art (11894): Debugger is active I/OpenGLRenderer( 534): Initialized EGL, version 1.4 I/Icing ( 4014): Indexing 034F0DA3682459750888E0D869C38B4D8CE528D4 from com.google.android.googlequicksearchbox I/Icing ( 4014): Indexing done 034F0DA3682459750888E0D869C38B4D8CE528D4 I/System.out(11894): Debugger has connected I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): waiting for debugger to settle... I/System.out(11894): debugger has settled (1469) E/ActivityThread(11894): Failed to find provider info for tv.ouya.controllerdata E/ActivityThread(11894): Failed to find provider info for tv.ouya.controllerdata E/ActivityThread(11894): Failed to find provider info for tv.ouya.controllerdata E/ActivityThread(11894): Failed to find provider info for tv.ouya.controllerdata W/libOpenSLES(11894): class OutputMix interface 0 requested but unavailable MPH=33 D/Racer2Activity(11894): View added E/art (11894): No implementation found for void com.amazon.ags.jni.AGSJniHandler.isLoaded() (tried Java_com_amazon_ags_jni_AGSJniHandler_isLoaded and Java_com_amazon_ags_jni_AGSJniHandler_isLoaded__) I/AGSJniHandler(11894): AmazonGamesJni is not loaded, trying to load library W/AGSJniHandler(11894): AmazonGamesJni not found. Java Native Interface will not be available D/GameCircleClient(11894): SDK Version: 2.4.2 D/com.amazon.identity.auth.device.utils.MAPLog.PII(11894): Extracting verison incremental: D/com.amazon.identity.auth.device.utils.MAPLog.PII(11894): Extracting flavor: D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(11894): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/GameCircleClient(11894): AmazonGamesClient not yet initialized. Initializing. D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(11894): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array V/AmazonInsightsSDK(11894): Firing Session Event: _session.stop V/AmazonInsightsSDK(11894): Firing Session Event: _session.start I/AmazonInsightsSDK(11894): Amazon Insights SDK(2.1.26.0) initialization successfully completed D/GameCircleClient(11894): initialize_internal() executing on thread:pool-1-thread-1 W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AmazonInsightsSDK(11894): Event: '_sess...' recorded to local filestore I/AmazonInsightsSDK(11894): Event: '_sess...' recorded to local filestore D/GC_Whispersync(11894): Initial load from disk started I/AmazonInsightsSDK(11894): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' V/GC_Whispersync(11894): Retrieved JSON string [{"gameData":{}}] of game data map from disk W/GC_Whispersync(11894): GameDataMap - Unable to merge from an invalid/unset GameDataMap com.amazon.ags.client.whispersync.GameDataSingleMap@3e379994 D/GC_Whispersync(11894): Initial load from disk completed in 6 msec. I/AmazonInsightsSDK(11894): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AmazonInsightsSDK(11894): Event: 'WHISP...' recorded to local filestore D/OpenGLRenderer(11894): Render dirty regions requested: true D/Atlas (11894): Validating map... I/Adreno-EGL(11894): : QUALCOMM Build: 10/28/14, c33033c, Ia6306ec328 I/OpenGLRenderer(11894): Initialized EGL, version 1.4 D/OpenGLRenderer(11894): Enabling debug mode 0 D/MainOpenGL(11894): Surface is being created W/Adreno-ES20(11894): : GL_INVALID_ENUM D/MainOpenGL(11894): Max texture size:4096 I/ActivityManager( 534): Displayed pompipompi.ofer.racing.dieselracer2/.Racer2Activity: +2s477ms W/Adreno-ES20(11894): : GL_INVALID_ENUM I/AmazonInsightsSDK(11894): Resolved variation: 'Test' for project: 'Universal Experiment List' from server I/AmazonInsightsSDK(11894): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK(11894): Attempting to retrieve variation(s) for project(s):'InitSigninAlertTest','ManifestSrc' I/AmazonInsightsSDK(11894): Successful submission of 17 events I/AmazonInsightsSDK(11894): Event: '_http...' recorded to local filestore I/AmazonInsightsSDK(11894): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache I/AmazonInsightsSDK(11894): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AmazonInsightsSDK(11894): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server I/AmazonInsightsSDK(11894): Resolved variation: 'Control' for project: 'ManifestSrc' from server I/AmazonInsightsSDK(11894): Event: '_http...' recorded to local filestore I/GC_ContentManager(11894): Upgrade zip does not exist. D/GC_ContentManager(11894): Current JavaScript content version: 2.4.3 D/GC_ContentManager(11894): Default JavaScript content version: 2.4.2 D/GC_ContentManager(11894): Upgrade JavaScript content version: -1.-1.-1 D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(11894): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/WebViewFactory(11894): Loading com.google.android.webview version 37 (1649326-arm) (code 113701) I/LibraryLoader(11894): Loading: webviewchromium I/LibraryLoader(11894): Time to load native libraries: 12 ms (timestamps 9032-9044) I/LibraryLoader(11894): Expected native library version number "",actual native library version number "" V/WebViewChromiumFactoryProvider(11894): Binding Chromium to main looper Looper (main, tid 1) {54a249a} I/LibraryLoader(11894): Expected native library version number "",actual native library version number "" I/chromium(11894): [INFO: library_loader_hooks.cc(106)] Chromium logging enabled: level = 0, default verbosity = 0 I/BrowserStartupController(11894): Initializing chromium process, renderers=0 W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/chromium(11894): [WARNING: resource_bundle.cc(315)] locale_file_path.empty() I/chromium(11894): [INFO: aw_browser_main_parts.cc(63)] Load from apk succesful, fd=62 off=83288 len=3846 I/chromium(11894): [INFO: aw_browser_main_parts.cc(78)] Loading webviewchromium.pak from, fd:63 off:229484 len:643667 W/AudioManagerAndroid(11894): Requires BLUETOOTH permission W/art ( 3200): Suspending all threads took: 8.972ms W/chromium(11894): [WARNING: proxy_service.cc(901)] PAC support disabled because there is no system implementation W/chromium(11894): [WARNING: data_reduction_proxy_settings.cc(403)] SPDY proxy OFF at startup W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/AwContents(11894): onDetachedFromWindow called when already detached. Ignoring W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/AwContents(11894): onDetachedFromWindow called when already detached. Ignoring W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/KindleFireIPCProxy(11894): Device does not appear to be a Kindle Fire. D/KindleFireIPCProxy(11894): Changing Status from:INITIALIZING to: UNIVERSAL_NOT_SUPPORTED I/GC_FileUtils(11894): Beginning download of /data/data/pompipompi.ofer.racing.dieselracer2/files/.ags/download/agsmanifest.txt I/GC_FileUtils(11894): Download of /data/data/pompipompi.ofer.racing.dieselracer2/files/.ags/download/agsmanifest.txt was successful: true I/chromium(11894): [INFO:SkUtilsArm.cpp(179)] Device supports ARM NEON instructions! I/chromium(11894): I/ConfigService( 3705): onDestroy D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-5] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-5] D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-6] for call type [isKindleRegistered] V/KindleFireIPCProxy(11894): synchronousBinder:null serviceMessengerClient:null D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-6] D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-7] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-7] D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-8] for call type [hasOptedIn] V/KindleFireIPCProxy(11894): transact() was called while disconnected D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-8] D/GC_HttpNetworkClient(11894): Request: GET https://ags-ext.amazon.com/services/featuredetection/getFeaturesUsage?gameId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5&GameId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5&locale=iw_IL D/GC_HttpNetworkClient(11894): Request: PUT https://ags-ext.amazon.com/service/achievements/getAchievementsPublic D/GC_HttpNetworkClient(11894): Request: PUT https://ags-ext.amazon.com/service/leaderboards/getLeaderboardsForGamePublic I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(11894): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(11894): Running get on Future with timeout=10000unit=MILLISECONDS D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken pkg=pompipompi.ofer.racing.dieselracer2 scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Vending out token: appId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5, scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken pkg=pompipompi.ofer.racing.dieselracer2 scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.datastore.DatabaseHelper.PII(11894): DatabaseHelper created: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Vending out token: appId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5, scopes=[game_circle:game_data]: W/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): RequestedScope shouldn't be null!!!! - null, but continuing anyway... W/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): RequestedScope shouldn't be null!!!! - null, but continuing anyway... I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common access token for requested scopes I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common access token for requested scopes I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common refresh token for requested scopes I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Updating existing token: D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Updating existing token: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken: E/GC_NetworkCallFactory(11894): Exception encountered while executing request: com.amazon.ags.AGSClientException: Network request requires authentication E/GC_NetworkCallFactory(11894): com.amazon.ags.AGSClientException: Network request requires authentication E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.comm.HttpNetworkClient.addLWATokenHeader(HttpNetworkClient.java:165) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.comm.HttpNetworkClient.addAuthenticationHeaders(HttpNetworkClient.java:155) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.comm.HttpNetworkClient.execute(HttpNetworkClient.java:89) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.comm.NetworkCallFactory.handleServiceRequest(NetworkCallFactory.java:152) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.comm.NetworkCallFactory.handleMessage(NetworkCallFactory.java:114) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.javascript.CallHandlerBase.handleMessage(CallHandlerBase.java:61) E/GC_NetworkCallFactory(11894): at com.amazon.ags.html5.javascript.domain.JavascriptInterface$8.run(JavascriptInterface.java:254) E/GC_NetworkCallFactory(11894): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) E/GC_NetworkCallFactory(11894): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) E/GC_NetworkCallFactory(11894): at java.lang.Thread.run(Thread.java:818) D/GC_NativeAuthCallHandler(11894): Logged in: false D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-22] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-22] I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(11894): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken pkg=pompipompi.ofer.racing.dieselracer2 scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Vending out token: appId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5, scopes=[game_circle:game_data]: W/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): RequestedScope shouldn't be null!!!! - null, but continuing anyway... I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common access token for requested scopes I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Updating existing token: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken: D/GC_NativeAuthCallHandler(11894): Logged in: false D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-28] for call type [isGCServiceReady] D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-28] D/GC_HttpNetworkClient(11894): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK(11894): Event: 'GameC...' recorded to local filestore D/GC_HttpNetworkClient(11894): Result:HTTP/1.1 200 OK D/GC_HttpNetworkClient(11894): Result:HTTP/1.1 200 OK I/AmazonInsightsSDK(11894): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK(11894): Event: 'GameC...' recorded to local filestore I/AGSJniHandler(11894): Initializing Native Handlers I/AmazonInsightsSDK(11894): Event: 'GameC...' recorded to local filestore I/AmazonInsightsSDK(11894): Session Resume Failed: Session is already running. D/GC_Whispersync(11894): Starting write to file system V/GC_Whispersync(11894): GameDataMap - Deep copy of GameDataMap with name: null V/GC_Whispersync(11894): GameDataMap copy took 0 msec. V/GC_Whispersync(11894): Writing game data to disk: [{"gameData":{}}] D/GC_Whispersync(11894): Completed write of 25 bytes to file system D/GC_Whispersync(11894): posting event: DISK_WRITE_COMPLETE D/GC_ClickableToastImpl(11894): Entering addToWindow... D/GC_Whispersync(11894): Never synced from cloud. Attempting initial download and merge. D/GC_Whispersync(11894): Checking whether Whispersync is enabled I/AmazonInsightsSDK(11894): Event: 'PageV...' recorded to local filestore D/GC_NativeKindleFireStateCallHandler(11894): Processing request [backgroundwebview-51] for call type [isKindle] D/GC_NativeKindleFireStateCallHandler(11894): Returning reply [{"value":false}] for request [backgroundwebview-51] D/GC_Whispersync(11894): Whispersync is DISABLED D/GC_Whispersync(11894): Cannot sync with cloud because Whispersync is disabled D/GC_Whispersync(11894): posting event: DISABLED D/GC_ClickableToastImpl(11894): Entering runnable for hide() I/AmazonInsightsSDK(11894): Event: 'Objec...' recorded to local filestore I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(11894): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken pkg=pompipompi.ofer.racing.dieselracer2 scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Vending out token: appId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5, scopes=[game_circle:game_data]: W/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): RequestedScope shouldn't be null!!!! - null, but continuing anyway... I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common access token for requested scopes I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common refresh token for requested scopes D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Updating existing token: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken: D/GC_NativeAuthCallHandler(11894): Logged in: false I/ActivityManager( 534): START u0 {act=1425635614857 flg=0x14010000 cmp=pompipompi.ofer.racing.dieselracer2/com.amazon.ags.html5.overlay.GameCircleUserInterface (has extras)} from uid 10144 on display 0 I/AmazonInsightsSDK(11894): Session Paused. V/AmazonInsightsSDK(11894): Firing Session Event: _session.pause V/GC_ClickableToastImpl(11894): Tried to remove toast but none was attached. D/AGSWorkerThread(11894): Worker thread died. I/AmazonInsightsSDK(11894): Session Pause Failed: Session is already paused. V/GC_ClickableToastImpl(11894): Tried to remove toast but none was attached. W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AmazonInsightsSDK(11894): Event: '_sess...' recorded to local filestore I/AmazonInsightsSDK(11894): Event: 'GameS...' recorded to local filestore W/SurfaceFlinger( 178): couldn't log to binary event log: overflow. W/ActivityManager( 534): Activity pause timeout for ActivityRecord{373d8f22 u0 pompipompi.ofer.racing.dieselracer2/.Racer2Activity t442} E/libEGL (11894): call to OpenGL ES API with no current context (logged once per thread) I/AKMD2 (11563): AKMD_Release: Memory free. W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/AwContents(11894): onDetachedFromWindow called when already detached. Ignoring W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring W/art (11894): Attempt to remove local handle scope entry from IRT, ignoring D/GC_GameCircleUserInterface(11894): View size set to width: 960 height: 883 I/ActivityManager( 534): Displayed pompipompi.ofer.racing.dieselracer2/com.amazon.ags.html5.overlay.GameCircleUserInterface: +203ms E/GC_WebViewFactory(11894): JS(line 2): refreshScrollBounds called without first calling scrollify:8 E/GC_WebViewFactory(11894): JS(line 5): Uncaught TypeError: Cannot read property 'style' of null I/AmazonInsightsSDK(11894): Event: 'Objec...' recorded to local filestore D/GameCircleClient(11894): SDK Version: 2.4.2 D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(11894): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getToken : scopes=[game_circle:game_data] E/com.amazon.identity.auth.device.thread.MAPCallbackFuture(11894): Running get on Future with timeout=10000unit=MILLISECONDS I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken pkg=pompipompi.ofer.racing.dieselracer2 scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Vending out token: appId=amzn1.application.388b906f47ed437f8d4e4a719f6e30d5, scopes=[game_circle:game_data]: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory W/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): RequestedScope shouldn't be null!!!! - null, but continuing anyway... I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common access token for requested scopes I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/GameCircleClient(11894): AmazonGamesClient.initialize() has already been called. Reinitializing. W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/com.amazon.identity.auth.device.endpoint.TokenVendor(11894): Try finding a common refresh token for requested scopes V/AmazonInsightsSDK(11894): Firing Session Event: _session.resume I/AmazonInsightsSDK(11894): Session Resumed. W/Whispersync(11894): WhispersyncClient has already been initialized D/com.amazon.identity.auth.device.endpoint.TokenVendor.PII(11894): Updating existing token: I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance D/GameCircleClient(11894): SDK Version: 2.4.2 D/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager.PII(11894): AmazonAuthorizationManager:sdkVer=1.0.0 libVer=3.3.0: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): Options bundle is null I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.TokenHelper.PII(11894): GetToken: I/AmazonInsightsSDK(11894): Event: '_sess...' recorded to local filestore I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/GC_NativeAuthCallHandler(11894): Logged in: false D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling getAppId I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/GameCircleClient(11894): AmazonGamesClient.initialize() has already been called. Reinitializing. I/AmazonInsightsSDK(11894): Session Resume Failed: Session is already running. W/Whispersync(11894): WhispersyncClient has already been initialized W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. W/Adreno-ES20(11894): : GL_INVALID_ENUM D/MainOpenGL(11894): Max texture size:4096 W/GC_AsynchronousReplyMessenger(11894): No pending message found for message id 96d1b9c4-cc93-4305-a1fc-30b09800e8c9 I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(11894): pompipompi.ofer.racing.dieselracer2 calling authorize with Activity: scopes=[game_circle:game_data] I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): isAPIKeyValid : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): getAppInfo : packageName=pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(11894): Finding API Key for pompipompi.ofer.racing.dieselracer2 I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(11894): Attempting to parse API Key from assets directory I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): Begin decoding API Key for packageName=pompipompi.ofer.racing.dieselracer2 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): APIKey: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): num sigs = 1 D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Signature checking.: D/com.amazon.identity.auth.device.appid.APIKeyDecoder.PII(11894): Fingerpirint checking: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): scopes has no mapping in json, returning null array I/com.amazon.identity.auth.device.appid.APIKeyDecoder(11894): perm has no mapping in json, returning null array I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Inside getRemoteAndroidService AsyncTask - Attempting remote service D/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): getAuthorizationServiceInstance I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of services found : 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Number of MAP services to compare = 0 I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Returning no service to use I/com.amazon.identity.auth.device.authorization.ThirdPartyServiceHelper(11894): Unbinding Highest Versioned Service D/com.amazon.identity.auth.device.authorization.AuthorizationHelper.PII(11894): Created UUID for request: D/com.amazon.identity.auth.device.authorization.AuthorizationHelper.PII(11894): Generating Redirect URI: D/com.amazon.identity.auth.device.authorization.AuthorizationHelper.PII(11894): Generating OAUTH2 URL: I/com.amazon.identity.auth.device.authorization.AuthorizationHelper(11894): Starting External Browser I/ActivityManager( 534): START u0 {act=android.intent.action.VIEW dat= https://www.amazon.com/ap/oa?response_type=code&redirect_uri=amzn://pompipompi.ofer.racing.dieselracer2&client_id=amzn1.application-oa2-client.995635ed36e7495f9bb87b4dcd31d780&amzn_respectRmrMeAuthState=1&amzn_showRmrMe=1&amzn_rmrMeDefaultSelected=1&state=clientId=amzn1.application-oa2-client.995635ed36e7495f9bb87b4dcd31d780&redirectUri=amzn://pompipompi.ofer.racing.dieselracer2&clientRequestId=ff0fba8d-4301-4f90-a3d9-162660610413&scope=game_circle:game_data flg=0x40000000 cmp=com.android.chrome/com.google.android.apps.chrome.Main} from uid 10144 on display 0 I/AmazonInsightsSDK(11894): Session Paused. V/AmazonInsightsSDK(11894): Firing Session Event: _session.pause V/GC_ClickableToastImpl(11894): Tried to remove toast but none was attached. D/AGSWorkerThread(11894): Worker thread died. I/AmazonInsightsSDK(11894): Session Pause Failed: Session is already paused. W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. V/GC_ClickableToastImpl(11894): Tried to remove toast but none was attached. W/Settings(11894): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. I/AmazonInsightsSDK(11894): Event: '_sess...' recorded to local filestore I/AmazonInsightsSDK(11894): Event: 'GameS...' recorded to local filestore W/SurfaceFlinger( 178): couldn't log to binary event log: overflow. W/ActivityManager( 534): Activity pause timeout for ActivityRecord{373d8f22 u0 pompipompi.ofer.racing.dieselracer2/.Racer2Activity t442} I/ActivityManager( 534): START u0 {act=android.intent.action.VIEW dat= https://www.amazon.com/ap/oa?response_type=code&redirect_uri=amzn://pompipompi.ofer.racing.dieselracer2&client_id=amzn1.application-oa2-client.995635ed36e7495f9bb87b4dcd31d780&amzn_respectRmrMeAuthState=1&amzn_showRmrMe=1&amzn_rmrMeDefaultSelected=1&state=clientId=amzn1.application-oa2-client.995635ed36e7495f9bb87b4dcd31d780&redirectUri=amzn://pompipompi.ofer.racing.dieselracer2&clientRequestId=ff0fba8d-4301-4f90-a3d9-162660610413&scope=game_circle:game_data flg=0x14002000 cmp=com.android.chrome/com.google.android.apps.chrome.ChromeTabbedActivity} from uid 10009 on display 0 I/LibraryLoader(11653): Loading chrome.2214.109 I/LibraryLoader(11653): Time to load native libraries: 85 ms (timestamps 6367-6452) I/LibraryLoader(11653): Expected native library version number "40.0.2214.109",actual native library version number "40.0.2214.109" I/chromium(11653): [INFO: library_loader_hooks.cc(108)] Chromium logging enabled: level = 0, default verbosity = 0 I/LibraryLoaderHelper(11653): Deleting obsolete libraries in /data/data/com.android.chrome/app_fallback I/LibraryLoaderHelper(11653): Deleting obsolete libraries in /data/data/com.android.chrome/app_lib I/LibraryLoaderHelper(11653): Deleted /data/data/com.android.chrome/app_fallback I/LibraryLoaderHelper(11653): Deleted /data/data/com.android.chrome/app_lib D/OpenGLRenderer(11653): Render dirty regions requested: true D/Atlas (11653): Validating map... D/ChildProcessLauncher(11653): Allocator allocated a connection, sandbox: true, slot: 0 I/ActivityManager( 534): Start proc com.android.chrome:sandboxed_process0 for service com.android.chrome/org.chromium.content.app.SandboxedProcessService0: pid=12067 uid=99015 gids={} abi=armeabi-v7a I/Adreno-EGL(11653): : QUALCOMM Build: 10/28/14, c33033c, Ia6306ec328 I/OpenGLRenderer(11653): Initialized EGL, version 1.4 D/OpenGLRenderer(11653): Enabling debug mode 0 I/ChildProcessService(12067): Creating new ChildProcessService pid=12067 I/BrowserStartupController(11653): Initializing chromium process, singleProcess=false W/art (11653): Attempt to remove local handle scope entry from IRT, ignoring I/ActivityManager( 534): Displayed com.android.chrome/com.google.android.apps.chrome.ChromeTabbedActivity: +633ms (total +704ms) W/AudioManagerAndroid(11653): Requires BLUETOOTH permission V/GLSActivity( 3705): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService } W/chromium(11653): [WARNING: data_reduction_proxy_settings.cc(328)] SPDY proxy OFF at startup W/art (11653): Attempt to remove local handle scope entry from IRT, ignoring D/ChildProcessLauncher(11653): Setting up connection to process: slot=0 D/ChildProcessLauncher(11653): on connect callback, pid=12067 context=-1347350392 V/GLSActivity( 3705): AuthDelegateWrapperCreated with selected intent: Intent { cmp=com.google.android.gms/.auth.DefaultAuthDelegateService } I/LibraryLoader(12067): Loading chrome.2214.109 E/chromium_android_linker(12067): UseSharedRelro: Could not use shared RELRO for libchrome.2214.109.so: No pages were swapped into RELRO ashmem W/chromium_android_linker(12067): Could not use shared RELRO section for libchrome.2214.109.so I/LibraryLoader(12067): Time to load native libraries: 41 ms (timestamps 7324-7365) I/LibraryLoader(12067): Expected native library version number "40.0.2214.109",actual native library version number "40.0.2214.109" I/chromium(12067): [INFO: library_loader_hooks.cc(108)] Chromium logging enabled: level = 0, default verbosity = 0 W/art (12067): Attempt to remove local handle scope entry from IRT, ignoring W/art (12067): Attempt to remove local handle scope entry from IRT, ignoring W/KnoxSettingsProvider(11653): Permission to read device policy denied. W/KnoxSettingsProvider(11653): Device policy content provider not found.
Pompi avatar image
Pompi answered
I have resolved the issue. It's very simple. The issue was that when I pressed sign in, the app would pause and then my app crashed so the browser log in didn't function. Once I fixed the app and it no longer crashed the logging in worked fine!
Jamie Grossman avatar image
Jamie Grossman answered
Hello Pompi, Glad that you were able to resolve the issue. If you have any other issues, feel free to raise another thread. Thanks, Jamie
