regulus-lionheart avatar image
regulus-lionheart asked
Sign In to Game Circle Failed
I just integrated Amazon Game Circle to my android app using Unity and was about to do some testing before launching it in the Amazon Market. But the problem is, when I tapped the button "Connect to Game Circle", the dialog closed immediately and the following errors showed up in the log: 04-30 23:22:45.253: E/GC_WebViewFactory(1121): JS(line 2): Uncaught ReferenceError: SocialHandler is not defined 04-30 23:22:45.503: E/GC_WebViewFactory(1121): JS(line 2): Uncaught ReferenceError: hostinterface is not defined With the errors, I was unable to sign in (I was logged in as a guest), and thus unable to test the Game Circle. I have searched through Google but found nothing like this, so I would really appreciate some help. Thank you.
Jamie Grossman avatar image
Jamie Grossman answered
Hi there, Apologies that you have experienced this. Is this issue only present in your own project? Have you tried implementing GameCircle in a sample project to see if it works there? The issue may be local only to your own project. Also, would you be able to post more from your log cat? There may be more clues as to why this is not working buried in there. Regards, Jamie
