DENIS avatar image
DENIS asked
Achievenent integration trouble
Hi! Make everything by the tutorial but achievement integration not working. Have Errors in logs.Please help! 11-23 16:34:12.299: I/Unity(19689): Language.SendMonoMessage ChangedLanguage 11-23 16:34:12.299: I/Unity(19689): 11-23 16:34:12.299: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:12.349: W/SensorService(928): sensor 00000000 already enabled in connection 0x6410e408 (ignoring) 11-23 16:34:17.079: I/VideoInit(19689): preparing activity for video surface 11-23 16:34:17.139: I/TapjoyLog(19689): enableLogging: false 11-23 16:34:18.119: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:18.159: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:18.169: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:18.179: W/dalvikvm(19689): No implementation found for native Lcom/amazon/ags/jni/AGSJniHandler;.isLoaded:()V 11-23 16:34:18.179: I/AGSJniHandler(19689): AmazonGamesJni is not loaded, trying to load library 11-23 16:34:18.179: W/AGSJniHandler(19689): AmazonGamesJni not found. Java Native Interface will not be available 11-23 16:34:18.179: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:18.179: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:34:18.179: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.179: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.189: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.189: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.189: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.199: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.199: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.199: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.209: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.209: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.209: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.209: I/GameCircleClient(19689): AmazonGamesClient not yet initialized. Initializing. 11-23 16:34:18.219: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:34:18.219: E/wpa_supplicant(5222): ath6kl: vif 0 time 1448281354 11-23 16:34:18.219: E/wpa_supplicant(5222): bmiss 35 con 1 discon 0 11-23 16:34:18.219: E/wpa_supplicant(5222): averssi -63 lrssi 3 roam 1 11-23 16:34:18.219: E/wpa_supplicant(5222): ath6kl: vif 0 time 1448282007 11-23 16:34:18.219: E/wpa_supplicant(5222): bmiss 40 con 1 discon 0 11-23 16:34:18.219: E/wpa_supplicant(5222): averssi -62 lrssi 3 roam 1 11-23 16:34:18.219: E/wpa_supplicant(5222): ath6kl: vif 0 time 1448282031 11-23 16:34:18.219: E/wpa_supplicant(5222): bmiss 44 con 1 discon 0 11-23 16:34:18.219: E/wpa_supplicant(5222): averssi -60 lrssi 3 roam 1 11-23 16:34:18.249: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.249: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.259: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.269: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.269: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.269: I/AmazonInsightsSDK(19689): Amazon Insights SDK(2.1.16.0) initialization successfully completed 11-23 16:34:18.269: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:34:18.279: I/AmazonInsightsSDK(19689): Event: '_sess...' recorded to local filestore 11-23 16:34:18.279: W/GC_Whispersync(19689): Retrieved an empty document from disk 11-23 16:34:18.279: W/GC_Whispersync(19689): GameDataMap - Unable to merge from an invalid/unset GameDataMap null 11-23 16:34:18.279: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:34:18.279: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.279: I/AmazonInsightsSDK(19689): Attempting to retrieve variation(s) for project(s):'Universal Experiment List' 11-23 16:34:18.279: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.279: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.289: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 11 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 12 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 13 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 14 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 15 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 16 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 17 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 18 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 19 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 20 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 21 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 22 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 23 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 24 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 25 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 26 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 27 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 28 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 29 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 30 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 31 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 32 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 33 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 34 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 35 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 36 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 37 11-23 16:34:18.289: I/AmazonInsightsSDK(19689): Event: '_sess...' recorded to local filestore 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 38 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 39 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 40 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 41 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 42 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 43 11-23 16:34:18.289: I/AmazonInsightsSDK(19689): Resolved expired variation: 'TEST' for project: 'Universal Experiment List' from cache 11-23 16:34:18.289: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 44 11-23 16:34:18.289: I/dalvikvm(19689): Total arena pages for JIT: 45 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.299: I/AmazonInsightsSDK(19689): Event: 'WHISP...' recorded to local filestore 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.299: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.299: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.309: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:34:18.309: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:34:18.309: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:34:18.309: I/GameCircleClient(19689): AmazonGamesClient.initialize() has already been called. Reinitializing. 11-23 16:34:18.309: W/Whispersync(19689): WhispersyncClient has already been initialized 11-23 16:34:18.309: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:18.319: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:19.009: I/AmazonInsightsSDK(19689): Resolved variation: 'Test' for project: 'Universal Experiment List' from server 11-23 16:34:19.009: I/AmazonInsightsSDK(19689): Attempting to retrieve variation(s) for project(s):'ManifestSrc','InitSigninAlertTest' 11-23 16:34:19.009: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 46 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 47 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 48 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 49 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 50 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 51 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 52 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 53 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 54 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 55 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 56 11-23 16:34:19.009: I/dalvikvm(19689): Total arena pages for JIT: 57 11-23 16:34:19.019: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 58 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 59 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 60 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 61 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 62 11-23 16:34:19.019: I/AmazonInsightsSDK(19689): Resolved expired variation: 'CONTROL' for project: 'ManifestSrc' from cache 11-23 16:34:19.019: I/AmazonInsightsSDK(19689): Resolved expired variation: 'TEST' for project: 'InitSigninAlertTest' from cache 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 63 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 64 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 65 11-23 16:34:19.019: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:34:19.019: I/dalvikvm(19689): Total arena pages for JIT: 66 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 67 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 68 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 69 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 70 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 71 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 72 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 73 11-23 16:34:19.029: I/dalvikvm(19689): Total arena pages for JIT: 74 11-23 16:34:19.049: I/AmazonInsightsSDK(19689): Successful submission of 4 events 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 75 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 76 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 77 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 78 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 79 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 80 11-23 16:34:19.059: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 81 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 82 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 83 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 84 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 85 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 86 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 87 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 88 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 89 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 90 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 91 11-23 16:34:19.059: I/dalvikvm(19689): Total arena pages for JIT: 92 11-23 16:34:19.069: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:34:19.209: I/AmazonInsightsSDK(19689): Resolved variation: 'Control' for project: 'ManifestSrc' from server 11-23 16:34:19.209: I/AmazonInsightsSDK(19689): Resolved variation: 'Test' for project: 'InitSigninAlertTest' from server 11-23 16:34:19.209: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:34:19.229: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:19.229: E/GC_FileUtils(19689): An error occurred while attempting to access resource: amazon_gc_prototype 11-23 16:34:19.229: E/GC_FileUtils(19689): android.content.res.Resources$NotFoundException: Resource ID #0x0 11-23 16:34:19.229: E/GC_FileUtils(19689): at android.content.res.Resources.getValue(Resources.java:1130) 11-23 16:34:19.229: E/GC_FileUtils(19689): at android.content.res.Resources.openRawResource(Resources.java:1045) 11-23 16:34:19.229: E/GC_FileUtils(19689): at android.content.res.Resources.openRawResource(Resources.java:1022) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.FileUtils.copyResourceContentIntoDirectory(FileUtils.java:71) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager.revertToDefaultContent(ContentManager.java:135) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager.fullContentInitialization(ContentManager.java:197) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager.access$000(ContentManager.java:28) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager$1.onRefreshCompleted(ContentManager.java:169) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:84) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:71) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.insights.core.DefaultInsightsHandler.onComplete(DefaultInsightsHandler.java:43) 11-23 16:34:19.229: E/GC_FileUtils(19689): at com.amazon.insights.abtest.DefaultABTestClient$1.run(DefaultABTestClient.java:197) 11-23 16:34:19.229: E/GC_FileUtils(19689): at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422) 11-23 16:34:19.229: E/GC_FileUtils(19689): at java.util.concurrent.FutureTask.run(FutureTask.java:237) 11-23 16:34:19.229: E/GC_FileUtils(19689): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) 11-23 16:34:19.229: E/GC_FileUtils(19689): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) 11-23 16:34:19.229: E/GC_FileUtils(19689): at java.lang.Thread.run(Thread.java:841) 11-23 16:34:19.239: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:19.239: W/GC_ContentManager(19689): Content initialization problem encountered 11-23 16:34:19.239: W/GC_ContentManager(19689): android.content.res.Resources$NotFoundException: Resource ID #0x0 11-23 16:34:19.239: W/GC_ContentManager(19689): at android.content.res.Resources.getValue(Resources.java:1130) 11-23 16:34:19.239: W/GC_ContentManager(19689): at android.content.res.Resources.openRawResource(Resources.java:1045) 11-23 16:34:19.239: W/GC_ContentManager(19689): at android.content.res.Resources.openRawResource(Resources.java:1022) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.ContentVersion.createVersionFromDefaultContentRawResource(ContentVersion.java:170) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.ContentManager.fullContentInitialization(ContentManager.java:200) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.ContentManager.access$000(ContentManager.java:28) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.ContentManager$1.onRefreshCompleted(ContentManager.java:169) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:84) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:71) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.insights.core.DefaultInsightsHandler.onComplete(DefaultInsightsHandler.java:43) 11-23 16:34:19.239: W/GC_ContentManager(19689): at com.amazon.insights.abtest.DefaultABTestClient$1.run(DefaultABTestClient.java:197) 11-23 16:34:19.239: W/GC_ContentManager(19689): at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422) 11-23 16:34:19.239: W/GC_ContentManager(19689): at java.util.concurrent.FutureTask.run(FutureTask.java:237) 11-23 16:34:19.239: W/GC_ContentManager(19689): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) 11-23 16:34:19.239: W/GC_ContentManager(19689): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) 11-23 16:34:19.239: W/GC_ContentManager(19689): at java.lang.Thread.run(Thread.java:841) 11-23 16:34:19.259: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:19.259: E/GC_FileUtils(19689): An error occurred while attempting to access resource: amazon_gc_prototype 11-23 16:34:19.259: E/GC_FileUtils(19689): android.content.res.Resources$NotFoundException: Resource ID #0x0 11-23 16:34:19.259: E/GC_FileUtils(19689): at android.content.res.Resources.getValue(Resources.java:1130) 11-23 16:34:19.259: E/GC_FileUtils(19689): at android.content.res.Resources.openRawResource(Resources.java:1045) 11-23 16:34:19.259: E/GC_FileUtils(19689): at android.content.res.Resources.openRawResource(Resources.java:1022) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.FileUtils.copyResourceContentIntoDirectory(FileUtils.java:71) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager.revertToDefaultContent(ContentManager.java:135) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager.access$400(ContentManager.java:28) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.ContentManager$1.onRefreshCompleted(ContentManager.java:174) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:84) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.ags.html5.content.GCVariationManager$1$1.onComplete(GCVariationManager.java:71) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.insights.core.DefaultInsightsHandler.onComplete(DefaultInsightsHandler.java:43) 11-23 16:34:19.259: E/GC_FileUtils(19689): at com.amazon.insights.abtest.DefaultABTestClient$1.run(DefaultABTestClient.java:197) 11-23 16:34:19.259: E/GC_FileUtils(19689): at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422) 11-23 16:34:19.259: E/GC_FileUtils(19689): at java.util.concurrent.FutureTask.run(FutureTask.java:237) 11-23 16:34:19.259: E/GC_FileUtils(19689): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) 11-23 16:34:19.259: E/GC_FileUtils(19689): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) 11-23 16:34:19.259: E/GC_FileUtils(19689): at java.lang.Thread.run(Thread.java:841) 11-23 16:34:19.269: I/AmazonInsightsSDK(19689): Successful submission of 3 events 11-23 16:34:19.289: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:34:19.319: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:19.329: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:21.319: I/Unity(19689): INIT FB 11-23 16:34:21.319: I/Unity(19689): 11-23 16:34:21.319: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.339: I/Unity(19689): Using Unity SDK v7.2.0 11-23 16:34:21.339: I/Unity(19689): 11-23 16:34:21.339: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.339: I/Facebook.Unity.FBDebug(19689): Using Unity SDK v7.2.0 11-23 16:34:21.399: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.399: W/Unity(19689): 11-23 16:34:21.399: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.409: W/Unity(19689): Foranj.SDK.Networking.LoadedFile must be instantiated using the ScriptableObject.CreateInstance method instead of new LoadedFile. 11-23 16:34:21.409: W/Unity(19689): 11-23 16:34:21.409: W/Unity(19689): (Filename: Line: 547) 11-23 16:34:21.419: I/Unity(19689): C#: TapjoySample start and adding Tapjoy Delegates 11-23 16:34:21.419: I/Unity(19689): 11-23 16:34:21.419: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.439: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:21.449: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:21.479: I/AmazonIapV2(19689): Start Amazon IAP V2 - Version 1.0.0, Build 9999.9.9.9 11-23 16:34:21.479: I/AmazonIapV2(19689): cpt iap plugin initialized 11-23 16:34:21.499: W/DrmManagerService(Native)(267): One client died!!! Looking for it for proper termination 11-23 16:34:21.499: I/ActivityManager(928): Process com.amazon.avod (pid 17329) has died. 11-23 16:34:21.529: I/AmazonIapV2(19689): getProductData called 11-23 16:34:21.529: I/AmazonIapV2(19689): getProductData for skus:gem_600.com.amazonforanj.farmparadise,gem_1500.com.amazonforanj.farmparadise,gem_130.com.amazonforanj.farmparadise,coin_500.com.amazonforanj.farmparadise,gem_50.com.amazonforanj.farmparadise,gem99.com.amazonforanj.farmparadise,gem_4000.com.amazonforanj.farmparadise,coin_15000.com.amazonforanj.farmparadise,coin_2750.com.amazonforanj.farmparadise,gem_275.com.amazonforanj.farmparadise,coin_6000.com.amazonforanj.farmparadise,coin_40000.com.amazonforanj.farmparadise,coin_1300.com.amazonforanj.farmparadise,gold99.com.amazonforanj.farmparadise, 11-23 16:34:21.539: I/AmazonIapV2(19689): onProductDataResponse:(com.amazon.device.iap.model.ProductDataResponse@41abb348, requestId: "8756cbd2-89df-44dc-be81-c2c430256161", unavailableSkus: [], requestStatus: "SUCCESSFUL", productData: {}) 11-23 16:34:21.539: I/AmazonIapV2(19689): GetProductDataResult:8756cbd2-89df-44dc-be81-c2c430256161/SUCCESSFUL/0 11-23 16:34:21.549: I/Unity(19689): AmazonIapV2UnityAndroid: Successfully called native code in 41 ms 11-23 16:34:21.549: I/Unity(19689): 11-23 16:34:21.549: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.569: I/Unity(19689): Using Unity SDK v7.2.0 with FBAndroidSDK/4.7.0 11-23 16:34:21.569: I/Unity(19689): 11-23 16:34:21.569: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.569: I/Facebook.Unity.FBDebug(19689): Using Unity SDK v7.2.0 with FBAndroidSDK/4.7.0 11-23 16:34:21.599: I/Unity(19689): C#: Handle Connect Failure 11-23 16:34:21.599: I/Unity(19689): 11-23 16:34:21.599: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.609: I/Unity(19689): AmazonIapV2UnityAndroid: eventReceived 11-23 16:34:21.609: I/Unity(19689): 11-23 16:34:21.609: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:21.629: I/ActivityManager(928): Process com.amazon.kindle (pid 15909) has died. 11-23 16:34:21.639: I/Unity(19689): Hash [] 11-23 16:34:21.639: I/Unity(19689): 11-23 16:34:21.639: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:22.449: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:22.459: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:23.949: I/ActivityManager(928): Waited long enough for: ServiceRecord{43490d38 u0 com.amazon.venezia/com.amazon.sdk.availability.AvailabilityService} 11-23 16:34:26.459: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:26.489: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:31.359: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:31.369: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:31.379: I/Unity(19689): C#: Handle Connect Failure 11-23 16:34:31.379: I/Unity(19689): 11-23 16:34:31.379: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:32.369: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:32.399: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:36.399: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:36.409: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:41.389: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:41.399: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:41.409: I/Unity(19689): C#: Handle Connect Failure 11-23 16:34:41.409: I/Unity(19689): 11-23 16:34:41.409: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: general 11-23 16:34:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: gps 11-23 16:34:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: fused 11-23 16:34:42.399: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: network 11-23 16:34:42.399: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: geofence 11-23 16:34:42.399: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: passive 11-23 16:34:42.399: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:42.439: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:46.439: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:46.449: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:51.389: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:51.409: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:51.409: I/Unity(19689): C#: Handle Connect Failure 11-23 16:34:51.409: I/Unity(19689): 11-23 16:34:51.409: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:34:52.409: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:52.419: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:34:56.419: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:34:56.449: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:01.429: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:01.459: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:01.479: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:01.479: I/Unity(19689): 11-23 16:35:01.479: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:02.459: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:02.469: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:06.489: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:06.489: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:08.619: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:08.619: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:08.619: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:08.629: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:08.629: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:08.629: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:08.629: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:08.639: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:08.639: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:08.639: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:08.639: I/GameCircleClient(19689): AmazonGamesClient.initialize() has already been called. Reinitializing. 11-23 16:35:08.639: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:35:08.639: W/Whispersync(19689): WhispersyncClient has already been initialized 11-23 16:35:10.009: W/GameCircleClient(19689): AmazonGamesClient is not ready. Please wait for the callback before attempting to retrieve the instance. 11-23 16:35:10.009: W/AC_AchievementsClientProxyImpl(19689): AmazonGamesClient is not initialized. Will not show achievements overlay. 11-23 16:35:11.499: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:11.509: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:11.529: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:11.529: I/Unity(19689): 11-23 16:35:11.529: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:12.509: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:12.519: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:16.519: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:16.539: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:19.249: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:19.249: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:19.259: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:35:19.259: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:35:19.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:35:19.259: I/GameCircleClient(19689): AmazonGamesClient.initialize() has already been called. Reinitializing. 11-23 16:35:19.269: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:35:19.269: W/Whispersync(19689): WhispersyncClient has already been initialized 11-23 16:35:21.569: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:21.579: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:21.599: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:21.599: I/Unity(19689): 11-23 16:35:21.599: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:22.579: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:22.599: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:26.599: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:26.609: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:31.619: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:31.629: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:31.639: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:31.639: I/Unity(19689): 11-23 16:35:31.639: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:32.629: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:32.649: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:33.019: I/ActivityManager(928): Process com.amazon.whisperlink.core.android (pid 14636) has died. 11-23 16:35:33.019: E/WifiService(928): Multicaster binderDied 11-23 16:35:33.019: W/ActivityManager(928): Scheduling restart of crashed service com.amazon.whisperlink.core.android/.WhisperLinkCoreService in 1000ms 11-23 16:35:33.019: W/ActivityManager(928): Scheduling restart of crashed service com.amazon.whisperlink.activityview.android/.service.NotificationService in 11000ms 11-23 16:35:34.019: W/SharedAssetStorage(928): Launching com.amazon.whisperlink.core.android (32069) with AMZ_APP_GID 11-23 16:35:34.029: I/ActivityManager(928): Start proc com.amazon.whisperlink.core.android for service com.amazon.whisperlink.core.android/.WhisperLinkCoreService: pid=20163 uid=32069 gids={72069, 3003, 1028, 1015, 3002, 3001, 9001} 11-23 16:35:34.139: W/ActivityThread(20163): ClassLoader.loadClass: The class loader returned by Thread.getContextClassLoader() may fail for processes that host multiple applications. You should explicitly specify a context class loader. For example: Thread.setContextClassLoader(getClass().getClassLoader()); 11-23 16:35:35.049: I/ActivityManager(928): Process com.audible.application.kindle (pid 14648) has died. 11-23 16:35:35.049: W/ActivityManager(928): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.AudibleContentManagementService in 1000ms 11-23 16:35:35.049: W/ActivityManager(928): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.services.PlayerService in 11000ms 11-23 16:35:35.049: W/ActivityManager(928): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.media.AudioPlayerService in 11000ms 11-23 16:35:35.049: W/ActivityManager(928): Scheduling restart of crashed service com.audible.application.kindle/com.audible.application.download.service.DownloadManagerService in 20999ms 11-23 16:35:36.049: W/SharedAssetStorage(928): Launching com.audible.application.kindle (32007) with AMZ_APP_GID 11-23 16:35:36.049: I/ActivityManager(928): Start proc com.audible.application.kindle for service com.audible.application.kindle/com.audible.application.AudibleContentManagementService: pid=20265 uid=32007 gids={72007, 3003, 1028, 1015, 3002, 9001} 11-23 16:35:36.199: E/SessionManagerService(3305): Calling Audio System Proxy disable 11-23 16:35:36.199: W/AudioPolicyManager(297): setDeviceConnectionState() device not connected: 40000 11-23 16:35:36.199: W/ContextImpl(3305): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1460 android.content.ContextWrapper.sendBroadcast:400 com.qualcomm.wfd.service.SessionManagerService.broadcastWifiDisplayVideoEnabled:989 com.qualcomm.wfd.service.SessionManagerService.teardown:825 com.qualcomm.wfd.service.SessionManagerService. :134 11-23 16:35:36.219: I/ActivityManager(928): Process com.android.email (pid 14965) has died. 11-23 16:35:36.219: W/ActivityManager(928): Scheduling restart of crashed service com.android.email/.service.ServiceController in 1000ms 11-23 16:35:36.389: W/linker(20265): libAAX_SDK.so has text relocations. This is wasting memory and is a security risk. Please fix. 11-23 16:35:36.639: W/SharedAssetStorage(928): Launching com.amazon.kindle (32034) with AMZ_APP_GID 11-23 16:35:36.649: I/ActivityManager(928): Start proc com.amazon.kindle for content provider com.amazon.kindle/com.audible.hushpuppy.service.db.HushpuppyStorageProvider: pid=20331 uid=32034 gids={72034, 1028, 1015, 3003, 9001} 11-23 16:35:36.649: I/ActivityManager(928): CPR:ContentProviderRecord{42ad1008 u0 com.amazon.kindle/com.audible.hushpuppy.service.db.HushpuppyStorageProvider}, wait begins for proc20265 nCountWaiting=1 11-23 16:35:36.649: I/ActivityManager(928): CPR: ContentProviderRecord{42ad1008 u0 com.amazon.kindle/com.audible.hushpuppy.service.db.HushpuppyStorageProvider} long wait begins for proc20265 11-23 16:35:36.659: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:36.659: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:36.679: I/ActivityManager(928): Process com.amazon.kindle.kso (pid 18100) has died. 11-23 16:35:36.699: I/ThermalEngine(306): vdd_dig_sw_mode_request: Defer call until KTM work loop is disabled, mode 2 NORMAL. 11-23 16:35:36.819: I/ActivityManager(928): Process com.amazon.dcp:OTAService (pid 15449) has died. 11-23 16:35:37.009: I/ActivityManager(928): CPR: ContentProviderRecord{42ad1008 u0 com.amazon.kindle/com.audible.hushpuppy.service.db.HushpuppyStorageProvider} continue to wait after long wait 11-23 16:35:37.219: W/SharedAssetStorage(928): Launching com.android.email (32024) with AMZ_APP_GID 11-23 16:35:37.229: I/ActivityManager(928): Start proc com.android.email for service com.android.email/.service.ServiceController: pid=20354 uid=32024 gids={72024, 3003, 1028, 1015, 9001} 11-23 16:35:37.309: I/ActivityManager(928): Process com.amazon.dcp (pid 18540) has died. 11-23 16:35:37.699: W/SharedAssetStorage(928): Launching com.android.email (32024) with AMZ_APP_GID 11-23 16:35:37.719: I/ActivityManager(928): Start proc com.android.email:Sync for service com.android.email/.service.pop3.Pop3ProtocolService: pid=20425 uid=32024 gids={72024, 3003, 1028, 1015, 9001} 11-23 16:35:37.719: W/ActivityManager(928): Unable to start service Intent { cmp=com.android.email/.service.AttachmentDownloadService } U=0: not found 11-23 16:35:37.809: I/ActivityManager(928): Process com.amazon.kindle.unifiedSearch (pid 18511) has died. 11-23 16:35:41.649: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:41.659: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:41.659: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:41.659: I/Unity(19689): 11-23 16:35:41.659: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: general 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: gps 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: fused 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: network 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: geofence 11-23 16:35:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: passive 11-23 16:35:42.659: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:42.689: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:43.249: I/ThermalEngine(306): vdd_dig_sw_mode_request: Defer call until KTM work loop is disabled, mode 0 AUTO. 11-23 16:35:46.699: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:46.709: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:49.529: I/ActivityManager(928): Waited long enough for: ServiceRecord{42af9af8 u0 com.amazon.whisperplay.cds/.qc.service.WhisperCastServicesHandler} 11-23 16:35:51.669: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:51.679: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:51.709: I/Unity(19689): C#: Handle Connect Failure 11-23 16:35:51.709: I/Unity(19689): 11-23 16:35:51.709: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:35:52.679: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:52.689: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:35:56.689: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:35:56.729: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:01.719: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:01.749: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:01.759: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:01.759: I/Unity(19689): 11-23 16:36:01.759: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:02.749: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:02.759: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:06.779: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:06.789: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:10.249: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): Options bundle is null 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): isAPIKeyValid : packageName=com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:36:10.249: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:36:10.249: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:36:10.259: I/com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager(19689): com.amazonforanj.farmparadise calling getAppId 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): getAppInfo : packageName=com.amazonforanj.farmparadise 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.AbstractAppIdentifier(19689): Finding API Key for com.amazonforanj.farmparadise 11-23 16:36:10.259: I/com.amazon.identity.auth.device.utils.ThirdPartyResourceParser(19689): Attempting to parse API Key from assets directory 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): Begin decoding API Key for packageName=com.amazonforanj.farmparadise 11-23 16:36:10.259: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): num sigs = 1 11-23 16:36:10.269: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): scopes has no mapping in json, returning null array 11-23 16:36:10.269: I/com.amazon.identity.auth.device.appid.APIKeyDecoder(19689): perm has no mapping in json, returning null array 11-23 16:36:10.269: I/GameCircleClient(19689): AmazonGamesClient.initialize() has already been called. Reinitializing. 11-23 16:36:10.269: W/Settings(19689): Setting airplane_mode_on has moved from android.provider.Settings.System to android.provider.Settings.Global, returning read-only value. 11-23 16:36:10.269: W/Whispersync(19689): WhispersyncClient has already been initialized 11-23 16:36:10.939: I/AmazonInsightsSDK(19689): Successful submission of 2 events 11-23 16:36:10.939: I/AmazonInsightsSDK(19689): Event: '_http...' recorded to local filestore 11-23 16:36:11.809: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:11.819: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:11.819: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:11.819: I/Unity(19689): 11-23 16:36:11.819: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:12.819: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:12.829: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:16.829: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:16.859: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:21.819: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:21.829: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:21.849: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:21.849: I/Unity(19689): 11-23 16:36:21.849: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:22.829: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:22.839: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:26.839: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:26.859: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:31.859: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:31.869: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:31.879: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:31.879: I/Unity(19689): 11-23 16:36:31.879: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:32.869: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:32.889: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:36.889: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:36.899: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:41.899: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:41.909: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:41.919: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:41.919: I/Unity(19689): 11-23 16:36:41.919: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: general 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: gps 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: fused 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: network 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: geofence 11-23 16:36:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: passive 11-23 16:36:42.909: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:42.929: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:46.939: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:46.939: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:51.929: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:51.949: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:51.949: I/Unity(19689): C#: Handle Connect Failure 11-23 16:36:51.949: I/Unity(19689): 11-23 16:36:51.949: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:36:52.949: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:52.959: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:36:56.959: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:36:56.999: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:00.079: I/ThermalEngine(306): vdd_dig_sw_mode_request: Defer call until KTM work loop is disabled, mode 2 NORMAL. 11-23 16:37:01.969: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:01.999: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:02.009: I/Unity(19689): C#: Handle Connect Failure 11-23 16:37:02.009: I/Unity(19689): 11-23 16:37:02.009: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:37:02.999: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:03.009: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:07.029: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:07.039: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:12.019: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:12.039: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:12.059: I/Unity(19689): C#: Handle Connect Failure 11-23 16:37:12.059: I/Unity(19689): 11-23 16:37:12.059: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:37:13.039: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:13.049: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:17.069: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:17.079: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:22.069: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:22.079: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:22.119: I/Unity(19689): C#: Handle Connect Failure 11-23 16:37:22.119: I/Unity(19689): 11-23 16:37:22.119: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:37:23.079: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:23.089: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:27.029: W/SharedAssetStorage(928): Launching com.amazon.avod (32000) with AMZ_APP_GID 11-23 16:37:27.029: I/ActivityManager(928): Start proc com.amazon.avod for service com.amazon.avod/.sync.syncadapter.ATVSyncService: pid=20874 uid=32000 gids={72000, 3003, 1028, 1015, 3002, 9001} 11-23 16:37:27.089: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:27.119: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:27.709: I/ActivityManager(928): Process com.amazon.kindle (pid 20331) has died. 11-23 16:37:27.939: W/linker(20874): libamzsspk.so has text relocations. This is wasting memory and is a security risk. Please fix. 11-23 16:37:27.989: E/PlayReady(267): Error: playready_set_header failed and returned ret = -2147024809 11-23 16:37:27.989: E/PRDrmPlugInImp(267): GetLicChallenge:: playready_set_header failed and returns = 0X80070057 11-23 16:37:27.989: E/PRDrmPlugIn(267): PRDrmPlugin::onAcquireDrmInfo, Lic Chall Error 11-23 16:37:27.989: E/PRDrmPlugIn(267): PRDrmPlugin::onAcquireDrmInfo, Lic Chall Error 11-23 16:37:27.999: E/QC-time-services(398): Daemon:genoff_handler: Update is not allowed for offset[1] 11-23 16:37:27.999: E/QC-time-services(509): Receive Passed == base = 0, unit = 0, operation = 0, result = -1 11-23 16:37:27.999: E/QC-time-services(509): Lib: Time Set for Base = 0 failed 11-23 16:37:27.999: E/QC-time-services(398): Daemon: Time-services: Waiting to acceptconnection 11-23 16:37:32.099: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:32.109: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:32.119: I/Unity(19689): C#: Handle Connect Failure 11-23 16:37:32.119: I/Unity(19689): 11-23 16:37:32.119: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:37:33.109: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:33.119: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:37.119: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:37.149: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:42.139: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:42.139: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:42.179: I/Unity(19689): C#: Handle Connect Failure 11-23 16:37:42.179: I/Unity(19689): 11-23 16:37:42.179: I/Unity(19689): (Filename: ./artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 64) 11-23 16:37:42.379: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: general 11-23 16:37:42.389: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: gps 11-23 16:37:42.389: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: fused 11-23 16:37:42.389: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: network 11-23 16:37:42.389: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: geofence 11-23 16:37:42.389: I/LoggerMetricsFactoryImpl(928): record : No valid data points in metrics event. Program: location_manager Soruce: passive 11-23 16:37:43.149: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:43.169: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers 11-23 16:37:47.169: W/ResourceType(19689): No package identifier when getting value for resource number 0x00000000 11-23 16:37:47.179: E/TapjoyConnect(19689): IntegrationException: Tapjoy SDK is disabled because Google Play Services was not found. For more information about including the Google Play services client library visit http://developer.android.com/google/play-services/setup.html or http://tech.tapjoy.com/product-overview/sdk-change-log/tapjoy-and-identifiers
Jamie Grossman avatar image
Jamie Grossman answered
Hi there, I noticed the following in your logs: W/AC_AchievementsClientProxyImpl(19689): AmazonGamesClient is not initialized. Will not show achievements overlay. I also noticed that you seem to be initialising the API multiple times; can you confirm if you're able to get this working using the sample? Thanks!
