Mahdouch avatar image
Mahdouch asked
How to handle spaces in filter values?
Is there a specific format for handling spaces in node names. For example, the following filter nodes/ /children?filters=kind:FOLDER AND name:My Folder doesn't return the expected folder. if I change it to name:My* then it returns a result, but I would prefer a more deterministic direct lookup approach. I've tried urlencoding the filter, putting it between parenthesis but that it didn't work. This should be documented in the filter section. The documentation is a bit scarce in my opinion.
amazon drive
Sean Callahan avatar image
Sean Callahan answered
Thank you for your post. For file names with spaces, you will have to escape it. Example: For filename, "test Photo”, in the request: {"filters": "name:test\ Photo”}
