jonsnow6082 avatar image
jonsnow6082 asked
Share token between client and server
Can I share the token received by Mobile with Server and then server access the cloud drive data ? Do I have to register the server along with the client in developer console ?
amazon drive
Jamie Grossman avatar image
Jamie Grossman answered
Hi there, Thanks for posting! I will get back to you on this as soon as I have more information on the matter. Regards, Jamie
Hi there, Thanks for posting. Though this is technically feasible (as long as the transmision of the token between both the client and server are secure), you should be able to get seprate tokens for both sides simply using the same profile. Hope this helps, Jamie
