lcebula avatar image
lcebula asked
API for Country Code BR
Hello Guys! Amazon has started running in Brazil. I would like to run item searches like I use to do in other countries using the API, but I not been able to find the Country Code I suppose to search for. For instance, running searches against the USA book database, I use the command: $amazonEcs = new AmazonECS(AWS_API_KEY, AWS_API_SECRET_KEY, 'com', AWS_ASSOCIATE_TAG) But if I replace the "com" with "BR" it does not work. Do you guys know if amazon didnt implemented the Brazil country code in the API yet? Appreciate any comments. Luciano
mobile associates
Sujoy@Amazon avatar image
Sujoy@Amazon answered
You should ask this question here : https://forums.aws.amazon.com/index.jspa
