mobivention GmbH avatar image
mobivention GmbH asked
In-App purchase switch from Entitlement to consumable
How can I change the in-app purchase item from entitlement to consumable? Is there a possibility to delete the wrong in-app purchase item and register it new? Thank you. Bibiana
amazon appstore
Dixith@Amazon avatar image
Dixith@Amazon answered
After submission of IAP items, its not possible to delete those IAP items. But we can re-use the same SKU for consumable items to Entitlement or subscription items by following the below steps. Steps: ------ 1) Move Consumable IAP Items to Pending state. 2) Change the SKU of consumable IAP Items to some other name. 3) Create new IAP Items with original SKU of the right type. Hope this information helps you.
David avatar image
David answered
Hello Is there a way to switch an existing set of consumables to entitlements? They were set to consumable by mistake . Users who deleted the app can't restore the purchase because it was set as consumable. Is there a way to switch it and resolve their problem without causing problems go existing users? Best Michael
Hi, Thank you for your post. You can change an existing set of consumables to entitlements by following the steps mentioned in the earlier response in this forum thread . As per the IAP items behavior, consumable items information is stored on the device and clearing data or uninstalling the app would clear the consumable item. Hence we cannot restore consumable items once removed from device.
