tassine avatar image
tassine asked
problem with simple example in implementation of Mobile Ads
hi Everyone, I would test my app, after I integrated Mobile Ads , but i don't know, if i should add obligatory this instruction in mode test or not: AdRegistration.setAppKey("0123456789ABCDEF0123456789ABCDEF"); Knowing that I don't publish my app up to now, so i haven't appkey. for more information about my error , seeLogCat error : https://docs.google.com/file/d/0B0xYk7NLFSEpTktEWFU1VFJuZUU/edit?usp=sharing My AndroidManifest : https://docs.google.com/file/d/0B0xYk7NLFSEpU21CYVhabThLOVk/edit?usp=sharing My activity : https://docs.google.com/file/d/0B0xYk7NLFSEpOTkxdDNvRERwd1U/edit?usp=sharing and thinks for all.
mobile ads
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Assine, Thank you for posting. Application key must be set in order to get Mobile Ads working. If you create an app in Amazon Developer Portal, an unique key would be assigned to your app and you should use that in the code. Please note that if you create an app in the portal, it wont be published unless you submit your app to us after completion of development/QA and we complete our app verification process. If you need to integrate Amazon SDKs into your app you must be having your app defined in the developer portal. Please create one! Hope this helps.
tassine answered
