skinnymojo avatar image
skinnymojo asked
Specifically for Flash CS5
I use Flash CS5 and Actionscript to create my apps - for now at least. I'm basically new to this entire process, and would appreciate, if possible, instructions on how I could implement in-app "consumables" and the like. Many thanks.
iap
StephenC@Amazon avatar image
StephenC@Amazon answered
Hi -- As you've probably seen, the IAP library is distributed as a Java *.jar file. If you can implement a Java interface and call Java classes from your environment, you're all set. Several developers have written IAP apps using the Adobe Air distribution present on the Kindle Fire. We can help you with the API, but perhaps another forum member (Flash Developers?) can hep point you in the right direction.
