Race Fan avatar image
Race Fan asked
File amazon/DefaultTestUser.xml contains a path separator
We've just been integrating the IAP code into our App and are running into some difficulties. On startup, shortly after registering for IAP messages we get a onPurchaseUpdatesResponse() response through which is shortly followed by the exception: "java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException: File amazon/DefaultTestUser.xml contains a path separator" We've got the SDK test apk installed and have the json file sat on the SD card. We've also tried changing the user via the SDK test App to a username which actually exists but we're still seeing the same issue. Anyone have any ideas? Thanks.
iap
Race Fan answered
Sachin@Amazon avatar image
Sachin@Amazon answered
Hi Alex, Glad to know that your issue has been resolved. It will be really helpful if you can post your solution so that it can help other developers as well who are facing similar issues.
