venkatam avatar image
venkatam asked
Amazon Sandbox testing
Hi All, I am used sample code provided in sdk of amazon and done testing with AmazonSdkTester.apk and it works after that i just installed the amazon client and removed the amazonsdktester.apk and singed in using the account i have creted for sandbox in amazon .. my problem is when i run the same code using amazon client and the sample apk provided for ANDROID it does not work what is the problem i m struck ..the code i have used is ButtonClicker provided from sdk ...can any one plz tell what i m missing here when i install the amazon client ....
iap
Dixith@Amazon avatar image
Dixith@Amazon answered
Hi, Thank you for your post. When your app is published through distribution portal, then IAP API will exchange data with the Amazon Client. If the API detects that the app has not been published through distribution portal, then it will exchange data with SDK Tester. Hope this info helps.
