andyhast81 avatar image
andyhast81 asked
Setting my app to Live IAP's
Hello, When submitting my app I'm confused as to how to set the App to live for in app purchasing. I'm using the unity plugin. So to set it to live does the param in the onSdkAvailableEvent need to be equal to 0 or 1? Thanks, Andy
iap
Dixith@Amazon avatar image
Dixith@Amazon answered
You do not need to put any value in onSdkAvailable event in the IAP code . The IAP API libraries will detect whether your app has been published through the Distribution Portal. If it has, the API will exchange data with the Amazon Client. If the API detects that the app has not been published through the Distribution Portal, the API will exchange data with SDK Tester. If your IAP app is working fine with SDK Tester, please submit your app, IAP items in the developer portal .
