Tester Three avatar image
Tester Three asked
GetProductDataResponse is empty in IAP v2 Unity plugin
Hello! I implemented IAP v2 as in documentation ( https://developer.amazon.com/public/apis/earn/in-app-purchasing/docs-v2/using-the-iap-plugin-for-unity), I have installed last App Tester from store and I have amazon.sdktester.json file in root of sd-card. _iapService.GetUserData() working well and return correct data of selected user in App Tester. But if I call _iapService.GetProductData(request); where request have all of available skus, I received answer with correct status and requestId but ProductDataMap and UnavailableSkus is empty. Can anyone explain what is problem?
iap
Tester Three answered
Sorry, maybe need more information about implementation or something else? If it's a local problem, but in live all will be work correctly, so I should not worry. Please, help me. Thx.
Nick Gardner avatar image
Nick Gardner answered
Hi, I would suggest trying live app testing to see if this is a local issue. https://developer.amazon.com/public/resources/development-tools/live-app-testing You can use this to make sure there aren't any issues with your local configuration. Based on what you've said, the most likely issue is a mismatch between what is in the sdktester.json file and what skus your app is looking for. Thanks, Nick
