vrs123 avatar image
vrs123 asked
Executing Sample of Fire-Phone SDK
I am trying to run the sample of Fire-Phone SDK in Eclipse and Android Studio but in the XML file give the Error. Error is "[b]No Resource Identifier found for 'headerTitle','actionMenu','headerSubtitle', etc. in amazon [/b]" i will follow the all step which is described in the given link https://developer.amazon.com/public/solutions/devices/fire-phone/docs/implementing-headernavigationbar in amazon developer site..... Please Help Me....
fire phone
Kevin@Amazon avatar image
Kevin@Amazon answered
Hi Vrs123, Note that as with any of the Foundation Controls for Fire Phone, they need to be used with a Gradle build – Android Studio (not Eclipse / ANT builds). For these controls specifically, you will be integrating the ‘eaclibrary’ (the source of the Resource Identifier error you are seeing). You will need to follow the Fire Phone SDK Add-on instructions here: https://developer.amazon.com/public/solutions/devices/fire-phone/docs/setup Then follow the instructions for configuring your app for the Fire Phone here: https://developer.amazon.com/public/solutions/devices/fire-phone/docs/configuring-your-app-for-fire-phone
vrs123 avatar image
vrs123 answered
Hi Kevin@Amazon if you have any Demo Application of The Amazon Fire Phone then please give me link to that page and Which version is use for the Android Studio to Develop the Fire Phone Application..
Hi Vrs123, Note that the Fire Phone SDK contains several samples designed to give you an idea of how the various APIs function. To run the sample apps without an actual device you will need to use the API Simulator. As only the actual Fire Phone has the run-time to run most of the samples, APIs other than the side panel, app widget, and standard Android are the only samples that will run without the actual Fire Phone device. We would recommend installing the Fire Phone SDK via Add-on: https://developer.amazon.com/public/solutions/devices/fire-phone/docs/setup#Installing%20the%20Fire%20Phone%20SDK%20Add-on You can find a link to the API Simulator here: https://developer.amazon.com/public/solutions/devices/fire-phone/docs/using-the-api-simulator-tool If you would like to know if your app will run on an actual Fire Phone you can use our App Testing Service. We will run your APK on an actual device and e-mail the results, stacktraces and screenshots back to you in a hour or so. https://developer.amazon.com/public/resources/development-tools/app-testing-service
