trays-so-close avatar image
trays-so-close asked
Emulator Limitations
Hello! Can I test ADM on emulator of Fire Phone? Thanks
fire phone
Benjamin_Caro avatar image
Benjamin_Caro answered
Unfortunately the API Simulator tool is limited to two set of APIs as per the documentation ( https://developer.amazon.com/public/solutions/devices/fire-phone/docs/using-the-api-simulator-tool) which states: "An app that uses only the side panel and hero widget APIs. The testing setup does not support any other APIs, including other Amazon APIs. If your app makes use of other Amazon APIs, you’ll need to make sure those APIs are not exercised while testing the side panel or hero widget portions of your app. The API Simulator does support testing side panels and hero widgets at the same time." You should be able to test ADM on other Amazon Kindle Fire devices that support it (all of them except the first generation Kindle Fire if I remember correctly) though. Thanks, Benjamin
