ajright avatar image
ajright asked
Dex Protector and app submission
We tried to submit our app and was put in pending approval, with the explanation that our app was unable to ingested by their ingestions systems.. and they sent a rezipped apk. Is there any process we can do this ourselves? how are we supposed to release updates to the app, and does amazon have an issue with dexprotector?
fire tabletsubmission testing distribution
DougM@Amazon avatar image
DougM@Amazon answered
Hello ajright, Yes, you can do this yourself if you wish. The easiest way is if you have a system with Zip 3.x . You can validate your APK's Zip structure by using the "zip -T " command on your APK file. What this does is runs a test to see if the ZIP file is valid. If it shows errors you can run the following commands to fix any ZIP formatting issues within your apk.     unzip example.apk -d destDirectory/     cd destDirectory     zip -r ../example_rezipped.apk * What this will do is rezip your APK file to allow for submission. We would of course, recommend you run zip -T to verify that it was rezipped successfully. However, you would have to engage Licel directly if their tool is causing the ZIP formatting to break.
ajright answered
Thank you for the response, which program are you referring to for the command line?
zip and unzip are a part of the standard distribution on Mac OS X and Linux systems. On Windows you would, of course have to install the program yourself if that is your platform of choice. For UnZip : http://www.info-zip.org/UnZip.html Zip: http://www.info-zip.org/Zip.html
ajright answered
Thanks Doug ill look into those!
