Gordon S. avatar image
Gordon S. asked
AmazonSDKTester Failing
I'm having an issue with the SDK Tester returning "FAILED" to onPurchaseResponse. I've tracked it down to onPause being called in the PurchaseActivity of the tester. It seems onPause gets called even though my own app should already be paused by the time this action occurs. As a result of onPause being called the initial transaction fails and a new requestId is issued without informing me. Is there a way to prevent his onPause from firing? As it happens in the test SDK there is very little I can do on that end.
fire tablet
Girish@Amazon avatar image
Girish@Amazon answered
Hi D. Slogar , We are following up on this and we will get back to you once we got an update. Thank you.
Mudeem@Amazon avatar image
Mudeem@Amazon answered
Can you please provide the logs. Thanks
