tejaspatel12 avatar image
tejaspatel12 asked
Map Stopped Displaying in live and registered application
Hello, I have implemented Amazon Api for maps and have uploaded two application with Map integration. At that time the maps were perfectly working but now the same application is not showing maps and again its registration key is removed. Also I tried to generate new registration key but no solutions. Rest all the applications registered earlier are also facing the same issues.
amazon appstore
Bipin@Amazon avatar image
Bipin@Amazon answered
Registration provides access to map tiles and geocoding services. Registration is specific to each app, and separate registration is required for debug and release builds. In order to load map tiles during testing, you must register the debug build of your app. https://developer.amazon.com/public/apis/engage/maps/doc/building-and-testing-your-maps-app#Registering%20Your%20App%20to%20Use%20the%20Amazon%20Maps%20API if the problem is after submitting to appstore. give us more details in Contact Us( https://developer.amazon.com/help/contactus.html ) like app name and copy this link in the message. We need to make sure the key's MD5 is linking and your app is registered. Release registration is a separate process and occurs automatically when you submit your app, if you have already created a debug registration.
