stephenhw avatar image
stephenhw asked
Amazon Mobile App SDK Eclipse Plugin Installation Problem
When I'm trying to install the plugin, Eclipse says "There are no categorized items". I'm in China, and I don't use proxy when doing that. Because when I use a proxy, the error will be 'org.eclipse.equinox.p2.core.ProvisionException'. All other plugins like ADT work well. Does anyone know what's the problem? Thanks a lot!
fire tablet
ErinG@Amazon avatar image
ErinG@Amazon answered
Hi! Is there a 'Group items by category' checkbox in the Install New Software window of Eclipse? If so, try un-checking this checkbox.
nadine10 avatar image
nadine10 answered
> Hi! Is there a 'Group items by category' checkbox in > the Install New Software window of Eclipse? If so, > try un-checking this checkbox. In the instructions, it says I should only check "Make sure that the Show only the latest versions of available software check box is selected.". I did just that, no other checkboxes were checked (although i did try checking other boxes too.) but same problem, nothing is available. So I don't think this is a checkbox issue. Do you have other suggestions? :) I tried changing http:// to https:// too. It also didn't work. Thank you very much!
Bipin@Amazon avatar image
Bipin@Amazon answered
Make sure the location is correct: http://developer.amazon.com/eclipse Secondly if this is already installed. In eclipse, Right Click on the any project. Click on Properties ( To the bottom of Contextual menu) Properties for opens up You can check if there is Amazon Mobile App, option on the left side to choose.
