schreida avatar image
schreida asked
Capture Play Button in ActionScript
Hi, is it possible to capture the media buttons rewind, play and fast forward in an app created with Flash / ActionScript. I had no problems with left, right, up, down, enter, back and option by using KeyboardEvent.KEY_DOWN . The app plays video so it would be nice to make use of the media buttons. thx + greets
fire tv
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Schreida, Before forwarding this to concerned team I need little information from you. Could you please share your code that how you are using to detect left, right, up, down and option button pressed event. I have tried with this public function ActionScriptAndroidTest() { super(); // support autoOrients stage.align = StageAlign.TOP_LEFT; stage.scaleMode = StageScaleMode.NO_SCALE; myText = new TextField(); addChild(myText); setText("Republic of Code"); NativeApplication.nativeApplication.addEventListener(KeyboardEvent.KEY_DOWN, onKeyDown, false, 0, true) } protected function onKeyDown(event:KeyboardEvent):void { if( event.keyCode == Keyboard.BACK ) { event.preventDefault(); event.stopImmediatePropagation(); //handle the button press here. setText( "KeyboardEvent:" + event.keyCode); } } It only can detect back on X button pressed in controller.
schreida answered
Hi, i just used the KEY_DOWN event on my stage. Rewind, Play and Fastforward are not covered. public class Test extends Sprite { public function Test() { (stage) ? addedToStageHandler():addEventListener(Event.ADDED_TO_STAGE, addedToStageHandler); } private function addedToStageHandler(e:Event = null):void { if (e) removeEventListener(Event.ADDED_TO_STAGE, addedToStageHandler); stage.align = StageAlign.TOP_LEFT; stage.scaleMode = StageScaleMode.NO_SCALE; stage.addEventListener(KeyboardEvent.KEY_DOWN, keyDownHandler); } public function keyDownHandler(e:KeyboardEvent):void { switch(e.keyCode) { case 16777238: trace("back"); break; case 16777234: trace("menu"); break; case 13: trace("enter"); break; case 37: trace("left"); break; case 38: trace("up"); break; case 39: trace("right"); break; case 40: trace("down"); break; } } } greets
Thanks for the code. I have forwarded it to the concerned team. I will get back soon.
