clive247 avatar image
clive247 asked
Android MediaPlayer GetDuration is 0
Hi, I am testing a video using the android mediaplayer object, while trying play this i am also trying to get the Duration of the clip using the getDuration method after the video is prepared. I tested with a HTTP progressive download file and in that case I am getting the correct value. I am getting 0 value for HLS streams. (m3u8 feed).... the same HLS stream on other android devices I am getting correct value. Only on Fire TV I am getting this 0 value. I am not sure if this Hardware/Firmware issue. Can someone give some thoughts. Thanks in advance Larry
fire tv
Sujoy@Amazon avatar image
Sujoy@Amazon answered
HLS media streaming is officially supported on Fire TV by VisualOn SDK. By using VisualOn SDK you will be able be informed about the correct duration of HLS media streams. . In order to get access of the SDK you need to file a ContactUs ( https://developer.amazon.com/help/contactus.html ) with the below details from your developer account. 1. You company name 2. Contact Info 3. App name 4. The plan on using DIAL Thanks.
Lawrence Paranidharan avatar image
Lawrence Paranidharan answered
Hi, I did send a note to the email you mentioned..but still there is no response.. It's been a week now.. Can you please advise. Thanks, Larry
Sorry for the inconvenience. We will reply to your case shortly.
