rboswell avatar image
rboswell asked
Cannot connect ADB to FireStick via wifi.
After connecting ADB via wifi with no problem in the past, it no longer connects. I keep getting the same msg, "unable to connect". Anyone, please assist. Thanking you in advance.
fire tv
Nick Gardner avatar image
Nick Gardner answered
Can you check to make sure that Settings>System>Developer Options>ADB Debugging is set to on on the Fire TV Stick? Also make sure that you are on the same wifi network as the Fire TV Stick, and that the Stick is connected to the network itself. Thanks, Nick
