Ian Engleback avatar image
Ian Engleback asked
Fire TV Stick has slow or delayed response to remote
I have an intermittent problem with the Fire TV Stick, the response to the remote command is slow and delayed,. For example if I press the select button it will take anything up to 30 seconds to respond. Normally I press it repeatedly and then the multiple button presses are responded to in quick succession after a delay. The connection between the remote and the stick is not an issue, neither are the batteries. The same result can be achieved using the Android App, the commands are delayed as with the remote. I have reset and unplugged the stick with no solution. Playback is not a problem, I never get a playback issue, but if I try and pause the playback then it will be delayed (often I pause twice and then it pauses/unpauses after a delay). This problem is intermittent, but mainly happens when I first wake up the device, there are periods where the stick responds perfectly. Thanks. Ian
fire tv
Levon@Amazon avatar image
Levon@Amazon answered
Hi Ian, Thank you for posting in the forums. Please note that this a forum for Amazon Appstore developers. For assistance with the Amazon Fire TV Stick as an end user, please contact Amazon Customer Service for support ( http://www.amazon.com/customerservice) or post in the Fire forums ( http://www.amazon.com/forum/fire/) Thanks!
