davewf avatar image
davewf asked
Sample code and Ubuntu - crash due to security certificates?
I am trying to get the sample AVS code running under Ubuntu. I've followed the instructions and everything is ok up until the point I press "start listening" and I receive a JAVA crash. I believe I have created my cacerts file successfully. Can anyone help explain what I am doing wrong? [INFO] Scanning for projects... [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building Alexa Voice Service Sample Java Client 1.0 [INFO] ------------------------------------------------------------------------ [INFO] [INFO] >>> exec-maven-plugin:1.2.1:java (default-cli) @ sample-java-client >>> [INFO] [INFO] <<< exec-maven-plugin:1.2.1:java (default-cli) @ sample-java-client <<< [INFO] [INFO] --- exec-maven-plugin:1.2.1:java (default-cli) @ sample-java-client --- Requesting Access Token {"access":"Atza|IQEBLjAsAhQtvUUpP4gR-8_d8eAcScqor1ytRgIUFNUoXi4hUSz8Ebnnwy8v7gAB1CqrXnBVXjeDcZFEnZNpXrxvB_Lzxt3kC2xKmb7vy6zg7ZzDdjB8Txwy637RgnxyHARFh4djk89upOrSL2Xl3L4hYCZer_feHTlfKZQRiEHsMeZPdfnXyZHmk0lDDFB2Da7JkxCwLdXt1KoycuVYuMnlspyZoY0qITgS8-OyWN-UGWCHVbjeU-uEJGyn4fcIei8RBxTk3YPgZE8-X0Fc60RCKLlCHlgHEm8Ac3RuCm4QFLpengdW96HBtvPPWdL2jnF7m9aydoLt3l95s0lpgL3VL8l0rpeNuuxC1U9oUcFxBbVQLJ2sQZzu-fWIo6YvuTUg3UkXVGvEnXE2AYOfrcMVDgzaicoPxXRzrL3O0dpkUr4","expires":3600} java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.util.concurrent.FutureTask.report(FutureTask.java:122) at java.util.concurrent.FutureTask.get(FutureTask.java:192) at javax.swing.SwingWorker.get(SwingWorker.java:602) at com.amazon.alexa.avs.AVSApp$1$1.done(AVSApp.java:83) at javax.swing.SwingWorker$5.run(SwingWorker.java:737) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(SwingWorker.java:832) at sun.swing.AccumulativeRunnable.run(AccumulativeRunnable.java:112) at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker.java:842) at javax.swing.Timer.fireActionPerformed(Timer.java:313) at javax.swing.Timer$DoPostEvent.run(Timer.java:245) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75) at java.awt.EventQueue.dispatchEvent(EventQueue.java:726) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1497) at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:212) at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979) at sun.security.ssl.Handshaker.process_record(Handshaker.java:914) at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387) at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:563) at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1282) at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1257) at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:250) at com.amazon.alexa.avs.AVSClient.startRequest(AVSClient.java:118) at com.amazon.alexa.avs.AVSController.startRecording(AVSController.java:63) at com.amazon.alexa.avs.AVSApp$1$1.doInBackground(AVSApp.java:76) at com.amazon.alexa.avs.AVSApp$1$1.doInBackground(AVSApp.java:73) at javax.swing.SwingWorker$1.call(SwingWorker.java:295) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at javax.swing.SwingWorker.run(SwingWorker.java:334) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387) at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292) at sun.security.validator.Validator.validate(Validator.java:260) at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1479) ... 22 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:145) at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:131) at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382) ... 28 more
alexa voice service
davewf avatar image
davewf answered
hmmm. My cacerts file had a problem and was missing many of the standard symantec certificates. Re-installing java has fixed it.
