Quentin M Randolph avatar image
Quentin M Randolph asked
Raspberry Pi - Alexa can hear me but not respond :(
Hi, Got the sample program running on my Raspberry Pi and it is successfully sending the voice command, verifiable by checking the echo app. The problem is that the audio response from Alexa is not playing :( I have confirmed that I can get audio out of the raspberry pi just not alexa. Please help! Thanks for your help Message was edited by: Quentin M Randolph
alexa voice service
Bobby@Amazon avatar image
Bobby@Amazon answered
Hi Quentin, Per the other thread, please try the following: The app is designed to use the default audio output of the system. You may need to change this setting on your Raspberry Pi depending on whether you want the audio to go out via HDMI or the line out. You can do this in the terminal: sudo amixer cset numid=3 can be: 0 = Auto 1 = Line Out 2 = HDMI
